What is a computer that lays side ways called
Do you know what the computers that are horizontal called. A picture ; http://www.laptop007.com/cms/components/com_virtuemart/shop_image/product/fe4de972793e9289f677eabd5f3cf46a.jpg
  • Computers & ... Master
  • 5,660 Answers
Desktop Computer.
It's designed to reside on the computer desktop.
The computer units that are of a Tower design, are designed to reside below the desktop.
If the photo link you gave is more than just an example for reference to it's design, I'll need more information from you.
Tell me what the Letter/Numbers state in the front Right bottom corner.
Go to the back of the unit, and state any letter numbers you see.
You can post this in a Comment.
Posted on Jul 04, 2010
What is a strike-valley?
First, you have to know what a strike is. Picture a flat rock laying on the level ground. Tilt it. The strike is the direction of the rock related to the level ground. The small angle between the rock and the level ground is called the dip.
Now, rocks are often in layers. When that layer is at a tilt to the horizontal plane, that is a strike. It is a tilt but it is underground in this image.
Now, go back up to the first description of strike, the rock tilted against the flat earth. If you had a mirror image of it on the other side, it would form a V. If earth were piled underneath the wings of that V, and each wing was hundred of feet high, you would be looking at a strike valley. The sides of such a valley are layers of rock tilted at an angle to the horizontal (flat) earth. Geologist describe the valley as being parallel to the strike.
Sep 05, 2017 | Cars & Trucks
I need instructions how to remove hard drive
Use the camera function on your cell phone; take picture of all cable connections
disconnect all cables to your computer
disconnect thumbscrews/screws holding computer cabinet shell at the back of computer
slide the cabinet shell forward exposing chasis frame. Lay computer on its side
important: Ground your body to the chassis frame (prevents static discharge damage)
Locate harddrive; with a magic marker ink one side to each of the two plugs and their sockets that are connected to the hard drive.(take picture maybe easer)
This is called making withness marks; it gives you a reference and orientation when you put things back together; the smaller plug is the power plug; the larger plug is for data.
Remove screws that secure harddrive to frame; Ground new harddrive to chasis; replace harddrive.
Nov 24, 2010 | HP Pavilion m7640n PC Desktop
I was taking lots of scenery pictures this weekend and usually turn my camera on its side to get longer/narrower shots. Well, I decided to take a video and turned that on its side. When I dropped the...
Well, if nothing else, you've learned a valuable lesson. Always shoot videos horizontally. There are some expensive editing programs that can rotate the video but with severe loss of quality.
Sep 27, 2010 | Sony Cyber-Shot DSC-W1 Digital Camera
The projected picture is cut off on the right side
It's hard to tell you exactly what you need to do with so little information. If you are connected to a computer, it's possible your computer resolution is too high. I recommend nothing higher than 1024x768. These projectors simply can't support very high resolutions.
Another option is to go into your menu and look for the image settings. The one you need to adjust is called horizontal position.
Aug 09, 2010 | Hitachi CP-X260 LCD Projector
I have a Compaq Q2009 (new). The picture is too wide on the right side, cutting off the image about 1/4".
There are a series of buttons on the monitor. There's probably a Menu button that allows you to change the dimensions and sizes of your picture on the screen. You'll need to open the picture menu, and find the Horizontal picture options. There are normally two options - one changes the horizontal placement, and the other changes the horizontal size. You can play with these two options until you can see your whole screen.
Mar 07, 2010 | Compaq QVision 171FS (White) 17 in.CRT...
Picture messed up for a while when first turned on, then better
How old is the tv overall? The tv can be repaired.
https://eservice.sony.com/webrma/web/index.do
Follow this link and you can inquire about getting service for the tv.
Thank you,
Lee
Nov 05, 2009 | Sony KDL-46XBR4 46 in. LCD Television
Downloading pictures that are sideways...
All you need is some editing software, click here. If this problem is occuring after uploading to a website, try rotating the picture before uploading so the "problem" will actually correct the picture.
Jun 23, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Sides of the picture are encroaching and making watching bothersome. Can this be adjusted by the consumer in some way?
this is most likely a problem with a capacitor going back in the horizontal stage of the tv's circuit. if the tv has a horizontal knob on the front somwhere you may be able to expand the width of the picture for while but eventually the problem will continue in which case if you know someone who knows how to replace electronic components the bad capacitor(s) will need to be replaced or the tv will have to be replaced.
May 31, 2009 | Panasonic CT-32D11 32" TV
How do i remove the cover of a Gateway MFATXPNT NMZ 500SE
I found this:
"Facing front of computer you need to remove the left side cover. cover release is on top of the computer in center of side panel. Press in on button and p[ull top of side cover away."
Don't know if it's useful. If not let me know and I'll keep looking.
Mar 16, 2009 | Gateway Computers & Internet
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
