Question about Whirlpool ED2FHSS Side by Side Refrigerator
First my refrigerator side stopped getting cold ,now my freezer isnt working the best , also theres frost in my freezer
    President:
  • 1,891 Answers
You found frost in the freezer on the back wall . this caused no air flow through the coil. what has hapened is / the defrost system has failed . and the ref side gets to warm and next the ice cream will melt . look for bad heater or defrost terminator . and the defrost timer . . most compn problem .. mm
Posted on Jul 04, 2010
Kenmore side by side freezer is working and air flow is ok with freezer door open...when close freezer door cold air flow to fridge stops
fan sometime runs when doors open only. if freezer is set too cold then a little door leading to refrigerated compartment freezes shut with frost and then the cold air cant get from freezer to refrigerator. good luck
May 07, 2011 | Refrigerators
The lower refrigerator section is not cold anymore
check to see if the fan motor in the freezer is running. all the cooling happens in the freezer and the fan is what circulates the cold air down to the refrigerator.. if the fan isnt running ,it could be a bad connection or a bad fan motor..on some models the doors need to be closed before the fan comes on so just push on the door switch to check .if the fan is running then a defrost problem may be the problem.. you mentioned you defrosted the unit. if the auto defrost isnt working, you would notice frost on the back of the freezer. there would be a lot more frost behind that panel that could block the airflow down to the frig. you would have to remove rear panel of freezer to clear all the frost and restore proper airflow..remember to unplug the frig before doing any work..
Mar 25, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
My freezer all of sudden isnt keeping things frozen..and the fridge isnt staying cold
ck in back of freezer for ice build up . if so the defrost system has failed . if may need a heater or timer( control ) to correct problem . the frost in the back of freezer blocks air flow and the fresh food area does not get any cold . and then the freezer gets warmer . and ice cream is not hard .. hopt this helped ****
Feb 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My refrigerator isnt as cold as it should be. The freezer works perfect but refrigerator isnt staying as cold.
check your freezer fan, is it working, you may need to hold the door switch in if there is one,
next check your freezer carefuly for frost
then try to see if you can feel air in the refer with the freezer door closed...
Oct 05, 2009 | Kenmore Refrigerators
Freezer froze up, refrigerator compartment warm after hooking up
look in the freezer and see if there is frost on the back wall if so take back panel off and checked defrost t-stat on top of the coil leave it in the ice and cut the wires and ohm it out if there is no ohms it is bad if it is good check the heater
Jan 02, 2009 | Whirlpool ED2FHEXN Side by Side...
Ge side by side not cold enough in fridge or freezer
if there is no frost build up in freezer section sounds like a refrigerant leak
Apr 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frig not cooling and now freezer is frosting
Val sounds like a defrost problem..go ahead and defrost your freezer again... check your evaporator drain your fan motors let let me know and I can help you Krazytech
Mar 27, 2008 | Maytag MZD2766GES Side by Side...
Refrig/Freezer not getting cold
If there is frost on the back wall of the freezer section a defrost is required. Defrost is normally automatic on a timed cycle. If you have frost and you know it is because of the door being open to long with the refrigerator running it could clear the coil automatically in the next 12 hours of operation. If it does not clear the frost from the coil inside the back wall you may require service to check out the timing device, heaters, and defrost thermostat.
Mar 07, 2008 | GE Profile PSW26P Stainless Steel Side by...
Whirlpool ED2FHSS Side by Side Refrigerator Logo
255 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
