Question about Nokia 5310 Cellular Phone
After turning the power switch on, date & time stting screen appears for about 2 seconds then the screen goes off
Nokia 5310 power switch ic tow print damig
Posted on Jul 04, 2010
How do manually reset sansui lifepad to factory default settings
Try this:
1. Hold down power and volume up buttons for 10 seconds, then press volume down button.
Failing that, this:
1. Turn tablet off. Hold down power button until 'Device Option' menu appears.
2. Select 'Power Off' then 'OK'
3. When tablet has switched off, hold the 'Reset' & 'Power' buttons simultaneously for about 10 seconds.
4. Wait for screen display, then press 'reset' button.
5. The 'system recovery' screen should appear.
6. Use 'Home' & 'Menu' buttons to navigate the menu.
7. Select the 'wipe data/factory reset' option & press 'Reset' button.
8. Then select 'Yes- delete all user data' & press 'Reset' button.
9. Press the 'Reset' button to reboot/restart tablet.
Oct 15, 2014 | Computers & Internet
Invicta 6280 , how to set time and does the large second hand move ?
Pull crown to position 1 and change date to yesterdays date , then pull crown to position 2, wind clock untill correct time appears (observe when date switches to observe the clocks am/pm cycle, this is useful to ensure the alarm goes off at the right time of day when set)
Dec 02, 2010 | Invicta Watches
ViewSonic VA1930wm Screen stays on for about 2 seconds, and then goes off. 1) If no computer is connected you get a "no signal" message which stays for about 1 seconds and then goes off; blue...
Very typical of View Sonic. Sounds like a back backlight or inverter. I would go to www.viewsonic.com and open up a RMA. Most view sonic screens have a 3 year warranty. They will repair at no cost ..(if it is within that period) There is a date code on the back of the screen that will help you validate the above information.
Nov 07, 2010 | ViewSonic VA1930WM LCD Monitor
HOW DO I SET TIME AND DATE?
The Date & Time have been reset message appears after the Language screen the first time you turn on the camera. It may also appear if the batteries are removed for an extended time.
  1. SET DATE & TIME is highlighted. Press the OK button.
    (Select CANCEL to set the date and time at a later time.)
  2. Go to Step 4 below, Setting the date & time, anytime..
  1. In any mode, press the Menu button.
  2. Press autourg00205001id1456505.jpg to highlight Setup Menu autourg00205001id1561971.jpg, then press the OK button.
  3. Highlight Date & Time, then press the OK button.
  4. Press autourg00205001id1474816.jpg to adjust the date and time. Press autourg00205001id1474821.jpg to advance to the next setting.
  5. When finished, press the OK button.
  6. Press the Menu button to exit.
Aug 27, 2010 | Kodak Cameras
My Imac crashes. 10.6.4, 2 GB ram, 2 GHz core duo. I've started with a clean install and disabled (one by one) all start up apps. Out of the clear blue, the screen will go black & I have to turn it...
When you say "screen goes black," does the computer power down, or is it still operating? Does the sleep light come on? Does it respond to the keyboard and mouse? (Example: press the power button momentarily, wait a few seconds for the "Do you really want to shut down" message to appear, even though you can't see it, then hit the return key to answer "OK," and see if it shuts down.) Does the screen go black or come out of black if you tap the computer?
While your computer is working, go to System Preferences / Desktop & Screen Saver, the Screen Saver tab, click Hot Corners, and set a corner of your screen to Put Display to Sleep. Then next time your screen goes black, mouse your way into that corner, pause a few seconds, then mouse back out and see if your screen returns.
Jul 10, 2010 | Apple iMac 17" Desktop
I have the test displayed and it dosent matter
There have been 3 versions of Demo Mode used on these appliances.
Version 1(Production to- Date code 39 March 2005)
To Activate
1. From the Default screen of a programme, after switching the appliance on press both Start/Cancel and On/Off buttons together until d On appears in display.
2. Press the Start/Cancel button only and test appears in the screen (Temp & Spin symbols also appear)
To Deactivate
Press the Start/Cancel button until all the console LED's illuminate.
Press both Start/Cancel and On/Off buttons together until
d OFF appears.
The default screen returns and you can select a new programme.
Note:- The default screen information displayed on these models is that of the programme currently selected by the selector knob.
Version 2 ( during Date Code 39 March 2005- to Date Code 42 June 2005)
To Activate
1. Same method as version 1.
To Deactivate
1. Simply press the Cancel button and the appliance returns to default.
Version 3 (During Date Code 43 June 2005 - to date )
To Activate
1. Press On/Off and Start/Cancel together with the top left option button until d On appears.
To Deactivate
1. Press On/Off and Start/Cancel toghether with top left option button until d OF appears.
Feb 24, 2010 | Hotpoint Ultima WF860 Front Load Washer
Sony DSC-W50 camera Error msg E:91:01
Please follow the instructions given below
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
Second step:
1)at setup do a initialize.
2)go to flash function to turn off the flash (must do it fast,b4 the E91:01 appear,if not you need to reset it again )
by now E91:01 will never appear.you can use it like normal,be sure not to turn on your flash again or go to night mode.if not you need to perform step 1 & 2 again.
Let me know, if need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 07, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
CANON MP27D CALCULATOR
1. Set the Power switch to ON and the GT switch to OFF
2. Press the Calendar / Clock button
3. Press and hold the Time Set button for 3 seconds
4. Enter month (2 digits), date (2 digits) and year (4 digits)
5. Press the Time Set button
6. Press the Clear / Clear Entry button
Jun 12, 2008 | Canon MP-25DV Calculator
Dell AXIM Screen
First, to dim/undim the screen, hold down the power button for a few seconds. A quick press will turn it on/off. Also, when dimmed, if you tap the screen, it should be fully lit. FYI...to change the brightness in either the plugged-in or battery mode, hold in the scroll dial on the left-hand side and press the navigation button (big round one on the front) either up (brighter) or down (dimmer). As for the time, tap Start >> Settings >> System (tab) >> Clock and see if your time is off by 12 hours.
Sep 14, 2005 | Dell Axim X50 Pocket PC
Nokia 5310 Cellular Phone Logo
85 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
