Question about Microsoft Xbox 360 Console
E74 Message I turn on my xbox 360 and get just the bottom right light turn red with the E74 message appearing on screen.
  • 79 Answers
An E74 error usually means there is a problem with the AV cable but in rare cases could also mean there is a problem with the GPU. If you can, try and use another AV cable, pick one up second hand and see how it goes.
Please rate if at all useful, thanks!
Posted on Apr 17, 2008
Someone plugged there xbox 360 HDMI cable into the USB port in a laptop. Now they get a E74 and 1 red light lower right side . What can they do now.
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
Jan 14, 2011 | Microsoft Xbox 360 Console
My xbox 360 was saying error e74 now it will just turn on but screen is blank.pls help me
Nov 15, 2010 | Microsoft Xbox 360 Console
When I turned on my system, it had system error contact xbox customer support. There is a red light flashing on the bottom right, around the power button. I don't know what to do. Please help.
Some of us suddenly when we turn on our Xbox 360 console one day we got one red light flashes on the ROL (Ring of Light) around the Xbox 360 power button, and we got an Error message appearing on the TV screen "System error" also might occur with any error code like E66, E67, E68, E71, E74 or E77, all the same.
When you get any of these messages appearing on your screen with one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables.
So, first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more.
If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you.
The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Read more: http://xbox360help.blogspot.com/2007/03/one-red-flashing-light-xbox.html#ixzz14pQlSds6
Nov 09, 2010 | Microsoft Xbox 360 Console
E 74
E74 error appears when you use your Xbox 360 console Article ID : 941377 Last Review : March 10, 2010 Revision : 14.0 On This Page SYMPTOMS Your console displays the following error message in multiple languages on your television screen or monitor: E74. System Error. Contact Xbox Customer Support.If you see a different error message or a code other than E74, your console may be experiencing a different problem. If this is the case, please search the Microsoft Knowledge Base for the error message or for the symptom.
uparrow.gifBack to the top
CAUSE This problem occurs when the Xbox 360 console experiences a hardware failure.
MORE INFORMATION Step 1: Confirm the E74 errorTo verify that your console is displaying the E74 error message, follow these steps: 1. Turn off the console. 2. Turn on the console. 3. Verify that your console displays the E74 error message.
Step 2: Submit a console repair requestIf you are experiencing this problem, you can submit a console-repair request online by using the links in the "Additional support" section.
Additional supportIf your console continues to display the E74 error message, it requires a repair. There are no additional troubleshooting steps. To start the online repair process, click one of the following links: In the United States
http://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repair (http://support.xbox.com/support/en/us/nxe/LiveIDSignIn.aspx?redirectUrl=http://support.xbox.com/support/en/us/nxe/registerdevice.aspx?step=repair)
Outside the United States http://www.xbox.com/support/ (http://www.xbox.com/support/) Note Online console repair service is currently not available in all countries and regions.For more information about how to contact Xbox support directly, please visit the following Web site: http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) Microsoft covers repairs for the E74 error for a period of three (3) years from the original purchase date of the console. If you are outside the initial three-year warranty period, you can still receive console repair service from Microsoft for a fee for the E74 error. For more information about this repair process, click the following article number to view the article in the Microsoft Knowledge Base: 969905 (http://support.microsoft.com/kb/969905/ ) About the E74 warranty extension for Xbox 360 consoles
References/Links If one light around the power button on your Xbox 360 console flashes red, there are additional steps that you can try. For more information, click the following article number to view the article in the Microsoft Knowledge Base: 907536 (http://support.microsoft.com/kb/907536/ ) One light flashes red on your Xbox 360 console
Oct 15, 2010 | Microsoft Xbox 360 Console
The bottom right light is blinking red everytime i turn it on
e74 at the bottom of the screen?if your xbox is less than 3 years old send it back to microsoft as they have extended the warrenty period to 3 years, e74 is code for graphical issues could be the graphics card. hope this helps.
Nov 17, 2009 | Microsoft Xbox 360 Console
My xbox 360 when i turn it on the power button goes red
You've got the Red Ring of Death (RRoD error message).
Connect your 360 to a TV or whatever you normally display it on. Try turning it on, and it should come up with a black screen. On the screen there should be an error message. Look at the code on the bottom. This code is extremely important, so write it down. The code will be an 'E' something, followed by two numbers.
Call Microsoft about it, and they can arrange to collect your Xbox 360 for you and send it off for repair. If the console is within a one year warranty, all repairs are free.
If the error is an E74, and you are out of warranty, don't panic! Microsoft have a 3 year warranty included for free, provided you have the E74 error.
The US Microsoft number is 1-800-MY-XBOX, I think.
Sep 07, 2009 | Microsoft Xbox 360 Console
The flashing red light comes on with message E74
you are seeing one red light on the powerbutton and E74 on the screen?
E74 can only be caused by either the HDD or the console itself,so you might wanna try using a different HDD with your console, if the issue still persists, then most probably, the console is having a hardware failure,there is a possibility that the HDD PORT is not properly woking w/c is causing the e74 error.
if thats the case, try calling xbox support hotline(1-800-4-MYXBOX) to process a repair for the console,it will be free,because Microsoft is extending the warranty of the consoles for 3yrs from the date of purchase for e74 and 3red light issues.
or you can also process a repair online,that is available at service.xbox.com,just click on "repair my console"
hope i'll help you..:-)
May 17, 2009 | Microsoft Halo 3 for Xbox 360
Xbox360, i flashing red light bottom right error message
The cause of E-74 with one red light Error might be overheating of your console and for avoiding such error in future you need to put your machine at an open space. Ensure that it is placed near the window or you can also make some external arrangement for cooling of console such as cooling the machine through a pedestal fan.
But as your Xbox already have E74 with one red light Problem which can be solved by only repairing it, no other alternative.
Either you can send your Xbox to Microsoft (Please note that microsoft is no longer providing extended warranty for E74 with one red lightError) and wait for 3-4 weeks. If you don't want to wait for a month, you can also fix E74 with one red light problem with the help of this DIY Video, the guide will explain step by step approach to fix the problem. Choice is yours........
Apr 07, 2009 | Microsoft Xbox 360 Console
My xbox 360 has error 74
The E74 malfunction is a problem believed to be associated with the system's video output cables and/or hardware scaler chip. The problem involves unusual screen patterns, the appearance of an on-screen error message, and finally a flashing red light in the lower right quadrant of the power ring. When a system suffers from the failure the on-screen message reads "E74 System Error. Contact Xbox Customer Support."
You could send it in to Microsoft of you can follow the steps as outlined in this You Tube video.
Mar 21, 2009 | Microsoft Xbox 360 Console
XBOX ERROR
The official Microsoft KnowledgeBase article is here http://support.microsoft.com/kb/941377/
You need to call 1-800-4MY-XBOX - your Xbox needs repair or replacement. It's now basically useless.
Nov 22, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
