Question about Husqvarna "Chain Saw - 16" Bar, 3 Hp
Cannot move the chain by hand after the bar has been tightened.
I just purchased the saw this afternoon. I was cutting a 3" tree and as I was just getting through the tree the chain came off. I followed the direction from the manual but after the chain is back on and the clutch cover re-installed per the instructions and ever thing is tightened I cannot get the chain to move by hand.
  • 760 Answers
First be sure the chain is on going in the right direction. When looking at the bottom of the bar the sharp tooth should be going towards the motor. When you put chain back on are the chain teeth properly engaged in the sprocket on the motor. Remove the cover again, check that teeth are in sprocket. Make sure pin from adjuster screw is engaged in the hole in the bar. Before you tighten the cover bolts, make sure chain will turn by hand. If not adjust the adjusting screw. Once adjusted, tighten cover bolts. Check again after tightening bar.
Posted on Jul 04, 2010
How to tighten chain on 4620avx poulan pro
First, RTFM- read the manual. Lost it? No problem, download it from Poulan PRO website page for PP4620avx. Pick a version you like, save and read it. Google is your friend.
Chain Adjustment Part cut and pasted as follows:
Adjusting the tension:
Chain tension is very important. Chain stretches during use. This is especially true during the first few times you use your saw. Always check chain tension each time you use and refuel your saw.
1. Lift lever on bar knob and turn counter-clockwise 1.5-2 turns to loosen clutch cover.
2. Turn adjusting wheel (downward direction) to tension chain until chain solidly contacts bottom of guide bar rail. Lift tip of guide bar while adjusting tension. Tighten chain Adjusting Wheel
3. Use a screwdriver to move chain around guide bar to ensure all links are in bar groove.
4. While lifting tip of guide bar, tighten bar knob securely (clockwise).
Hand tighten only.
Be careful not to destroy the adjustment mechanism. When it breaks, go for a clutch cover with the simple adjuster that needs a "scrench". Longer term, learn how to search this info. Saves time. Now you can work on sharpening chains- very important.
Manual page:
http://www.poulanpro.com/ddoc/PPOO/PPOO2006_USen/PPOO2006_USen_PP4620AVX_952802146.pdf
Jul 21, 2014 | Poulan Pro Chain Saw 46cc 20"
How to take chain off poluan pro saw
Before putting your hands near saw chain cutters, put leather gloves on. Cutters sitting still can still draw some blood.
Loosen the nuts holding the clutch cover, loosen the adjuster, then remove the nuts. Remove the cover. Slide the bar along the studs, free of the adjuster, toward the clutch. Revove the chain from the bar groove, then move it clear of the clutch drive. It's now off. Good time to clean bar grooves and bar-mounting area of dirt & chips.
Reverse the procedure to install a chain, making sure the cutters have their cutting edge facing forward on the top of the bar. Make sure the adjuster is engaged with the bar before tightening the nuts at all.
Holding the bar nose up, tighten the adjuster until the chain touches the bar on the lower side. Tighten nuts.
After short run to clear any debris, recheck the chain tension.
Jan 29, 2014 | Poulan Pro Chain Saw 46cc 20"
My poulan 18 inch chain saws blade turns but only cuts in about an inch and won't go any farther. It's two days old and worked fine cutting the first 2 trees down.
It sounds like the chain does want sharpening, it depends on what you are cutting ( type of timber, dirty timber,burnt timber etc ) as to how long before it needs sharpening, if the chain comes into contact with the ground below the tree it will lose its edge instantly.
Dec 29, 2012 | Poulan Wild Thing 2375 18" Gas Chain Saw...
New Rancher 455. Ran for a few minutes then tried to tighten chain but adjuster was maxed out (completely tight clockwise). Removed cover, now can't get tension adjusting pin in hole in bar....pin sits...
Ok.. with the cover off the clutch you notice the screw and the pin that is suppose to go into the hole.. with the chain on the bar back the screw until the pin sits in the hole of the bar.. The chain should be lose you will see the chain dangle at the bottom of the bar.. put the cover back on with it lose.. hand tighten the two nuts that hold the cover on. with the bar in hand and you pulling the bar up make sure the two nuts are on tight enough so the bar does not move but dont over tighten it. tighten the screw you will notice the chain starting to move, and start to tighten up.. once the chain is in the grove of the bar grab the chain and move the chain with your hand to make sure you have not over tighten it. if the chain moves freely and is not lose ( you can also double check how tight it is by grabbing the chain below the bar and letting it go if it snaps back into the bar and doesnt hang there you are where you need to be.) tighten the two nuts up on the cover and start up the saw. Run the saw to make sure everything is all set and nothing is lose before cutting.. If the chain never get to tighten up you need a new chain. buy a new chain and follow the steps again. let me know if you have any questions
Jun 19, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Chain won't rotate
Assuming that you have a fueled engine saw instead of an electric type, remove the drive cover after releasing the chain brake and backing off CCW the chain adjuster screw. Remove the bar/chain and clean the assortment of parts including the small oil passages that are in the drive end of the bar. Wash out the interior of the clutch assembly with spray carburetor cleaner and let dry. Start the engine without the bar/chain and watch for oil oozing out of a small port in the side of the engine case. If nothing, check the oil pump, lines, and valve/filter within the oil tank. If ok, re-assemble the bar, then the chain over the sprocket and out over the bar. Extend the bar out to tighten the chain, and fit the cover to the saw. Tighten the fasteners finger tight, then adjust the chain up to the lower bar edge (the teeth cut toward you on the bottom run) but not so tight that you can't turn the chain by hand. Tighten the fasteners and recheck chain tension. Check chain oiling by running the bar tip at speed near a piece of cardboard for a few moments--it should throw off a thin line of oil onto the board. Hope this helps!
Jun 26, 2010 | Garden
Chain saw chain is loose
Loosen the side cover nuts, then turn the adjuster CW to bring the chain up to the lower edge of the bar, then check to see if the chain will move fairly easily by hand. Tighten the clamp nuts and recheck tension. If chain seems to get loose quickly again, it may not be sharpened correctly causing heat to build in the chain. You should see no reflection of light from the cutting edges if filed correctly and the saw should require very little pressure for it to cut rapidly. Hope this helps!
May 15, 2010 | Husqvarna Chain Saw 20" Bar
452 c/saw doesnt cut well , revs are good, chain has been sharp, tree is medium hard timber.
This could be a problem with chain sharpening technique. Use of the correct size file, filing angles, and filing depth will all affect cutting performance. If the bar and chain are worn, you may be experiencing chain 'roll-over' which hinders the way the teeth cut into the wood. Try turning the bar over and tighten the chain a little more than usual, but still be able to turn it by hand. If the outer edges of the bar groove area have a 'flared-out surface, take a file to those edges (cut about 45 degrees) which may be catching on the 'kerf' of the cut. Make sure the teeth are cutting toward you on the bottom run. Hope this helps!
Apr 22, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
How do i tighten the chain on a stihl 038av magnum?
Normally, a loose chain will enhance it's ability to jump off when trimming small branches.
When installing and/or adjusting a chain;
1) install the chain, bar, and cover, and install the cover nut loosely
2) support the 'nose' end of the bar with a block
3) tighten the chain until it touches the bottom of the bar,
and then tighen the adjuster 1/8 of a turn more.
*this will make the chain just a LITTLE snug
4) tighten the cover nut, and then by hand CAREFULLY rotate the chain.
If you cannot rotate by hand, it is too tight. re-adjsut
** This proceedure must be used on ANY brand chain saw.
Here is why.
If the bar nose is not lifted upon adjustment, when cutting,
the nose will move upward, the chain will have a 'droop' away
from the bar and appear to have loosened while cutting.
Any contact with a small branch will flip the chain off of the bar.
If you re-adjust it improperly, the same senerio will occur the next cut.
Nov 22, 2009 | Garden
Chain keeps coming off
Here is why.
Nov 12, 2009 | Remington Electric Chain Saw
Remington ld4016 w
There are one or two large nuts on the chain side. There is also a screw adjustment on the front where the bar or chain guide meets the saw. You loosen the nuts a bit (so that you can move the bar). Then you back the screw out to allow the bar to move back into the saw enough for you to put the chain back on the bar in the guide slot. Then you tighten that screw to the point that you can still push the chain around the bar (wear gloves) and there is very little slack under neath. Then you tighten the nuts. As you tighten them, pull up on the "nose" of the bar.
Make sure you keep oil in the reservoir and oil a lot as you cut. Keep the chain adjusted, they stretch as you use them. RTFM
Oct 18, 2008 | Remington 16" Electric Chain Saw
Husqvarna "Chain Saw - 16" Bar, 3 Hp Logo
143 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
