Question about Kenmore 20.6 cu. ft. Top Freezer Refrigerator
Back of frig making a whining/ screeching sound.
    President:
  • 1,891 Answers
Ck your fans . sounds like the cond fan down undr neath unit . also clean the coils . mm
Posted on Jul 04, 2010
Hi my c1 has started to make a whining sound (bit like a dog whine) the last couple of days. It tends to get louder and is intermittent, it starts when the engine is fired up (no probs starting engine)...
Have your drive belt replaced (sometimes called the auxiliary or serpentine belt) when it slips it creates a screeching noise and it's also a sign that it's going to fail (snap).
These can run the alternator and power steering so you should change it as a preventative measure.
Oct 17, 2013 | 2008 Citroen C1 1.0
2007 chevy malibu...was having screeching/whining noise from front drivers wheel, usuallly when braking. i changed rotors and brake liners. now have screeching/whining when just driving, brakes are...
hhmm... I hate trying to diagnose brake issues online,,, there are so many variables.. you installed new pads and rotors...and the noise is constant now... (Wished you lived near me)... sounds like you may have pushed too much brake fluid back out of the master cyl. reservoir...bleeding ABS brakes is harder than regular brakes,,
... Bleeding ABS Brake Systems
after reading this.. take a look at your system,,, see if anything relates and you can fix it,, please reply to me on here.. thanks
Aug 11, 2017 | Ford Explorer Cars & Trucks
Screeching noise, especially w/heat on
SOUNDS LIKE YOUR A/C COMPRESSOR IS DEFECTIVE. WITH HEAT ON COMPRESSOR CYCLES FOR LUBRICATION
May 08, 2012 | Mitsubishi Cars & Trucks
I have a Dodge 2002 SLT Truck with a 4.7 engine and it whines when I accelerate. I took the serpintine belt off and it still whines when I rev the motor. Can anyone help?
One possibility could be a failing water pump. One of the first signs of a bad water pump is a whining / screeching sound due to a bad bearing.
Mar 29, 2012 | Dodge Ram 1500 Cars & Trucks
Hi,i have just bought Audi A496 1.8Ltr and power steering makes whining noise but no leak found,please help,thanks & cheers.
if it is whining -- then this is a sign that you need to add power steering fluid to the reservoir.
there will be a hot and cold line on the small dip stick in the reservoir,, it is best to fill while the system is cold,, fill to the cold line and this should stop the whining.
c...
Feb 05, 2011 | 1998 Audi A4
Leibherr Refigerator is making a constant noise
What sort of noise are you refering to. If it's a whining noise or a screech, check the fan motor. try spraying a little WD40 on the shaft. sounds like a dry front bearing. better still replace the motor.
May 17, 2010 | Liebherr KIKNV3056 Bottom Freezer...
Really bad screeching sound coming from drive belts
Alternator bearings a possible. Idler Pulleys or Belt Tensioner Pulley
Mar 24, 2010 | 1992 Subaru Legacy
Whining or grinding noise/screech when we turn the wheel
Dear Screech And Whine......What you have described is definitely a power steering concern. And yes the fluid is low.....thanks for the accurate problem description!! You are correct on the filling the fluid part also......but keep in mind that if your power steering fluid is lo that you might very well also have a ps leak too.You can do a visual check and trace all of your ps lines to make sure that no fluid is escaping anywhere.....You ae more tha welcome to get back to me if you have any further questions...HOPE I COULD HELP!!!
Nov 17, 2009 | 2001 Dodge Stratus
Kenmore 20.6 cu. ft. Top Freezer Refrigerator Logo
125 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
