Question about Coustic Car Audio 12RS Car Speaker
Coustic Car Audio 12RS Car Speaker Watts
I have a 12" Coustic Car Audio 12RS Car Speaker/Subwoofer which has a 4 ohm single voice coil, and I would like to know the maximum watts that it can withstand.
    Problem Solver:
  • 4 Answers
That all depends.
I have a Sony Xplod Sub, also 12" and 4ohm, and it is a 1000w sub.
But my friend has sub that is also 4ohm and yet it is only 500w.
The ohm mean nothing when trying to figure out the wattage.
Try www.coustic.com for more info (site will not load for me)
Posted on Jul 04, 2010
Whats the best way to hook up 2-10'' 4 ohm dual voice coil to the d5 1200.1 amp
4x4 ohm voice coils can be configured to either run @ 1 ohm, 4 ohm or 16 ohm, while the amp needs to be dropped to 2 ohms, no lower, to be most efficient. if a single dvc sup could handle 1200 watts, then hjust run 1, with both coils positive and negative inputs connected to the amps output. if you needed both subs, you would lilely only get 600 watts, by creating a 4 ohm load by running both speakers to the amp positive to 1 ccoil, each speaker, an mjumper cable between the negative of 1sdt clils to positive of 2nd coins, and running both 2nd coil negatives back from both speakers to the amp negative. the 2nd wscenerio will result in less sheer wattwage, but will also provide cleaner power. you need to study ohms law and parallel versus serial wiring to accomplish the 2nd scenerio, or, just get 2 4 ohm single voice coil speakers that can handle 600 watts apiece.
Sep 05, 2014 | Diamond Audio D5-1200.1 Car Audio...
Can i have box dimentions for my 12" xplod sub
  • Warranty Terms - Parts 1 year limited
  • Warranty Terms - Labor 1 year limited
  • Product Height 12"
  • Product Width 12"
  • Product Weight 7.8 lbs.
  • Product Depth 6-1/2"
  • Subwoofer Size 12"
  • Resistance (Ohms) 4 ohms
  • Bottom Mount Depth (inches) 10"
  • Woofer Composition Mica-reinforced woven glass fiber composite
  • Woofer Surround Rubber
  • Peak Power handling 1300W
  • RMS Power Range (Watts) 380
  • Cutout Diameter or Length (inches) 12"
  • Sensitivity 84dB
  • Frequency Response 30Hz - 1kHz
  • found at:::---- http://www.bestbuy.com/site/Sony+-+Xplod+12%22+Single-Voice-Coil+4-Ohm+Subwoofer/9202481.p?id=1218057724056&skuId=9202481
Jun 04, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
Can you hook up two 12 inch subs to a 1000 watt amp?
need more info well you need to look at the subwoofer and see how many watts it can take and if it 2 ohm or 4 ohms single or dual voice coils and on your amp is it mono or 2 channel and what is the omhs for it
Mar 11, 2010 | Alpine SWS-1223D Car Speaker
I dont have any cosmetic problems with my subs .. but i have 4, 12 inch hifonics olympian subs in one sealed box. and i cant find any specs on them at all.. do you know the watts and rms wattage and how...
look on the bottom of subwoofer should say like olm2412 olm1612 olympus the 1612 is the rms and speaker size 2412 is 2400 rms and the 12 stands for 12 inch subwoofer.i think thair is only 2 modles . also u have 4 u would need a 10,000 rms amp if thay are the olm2412s or 6,000 rms amp to push 4 olm1612. as far as box building info i think you should call maxxsonnics. 847-540-7700 talk to mike
Mar 03, 2010 | Hifonics W-124 Olympian 12" Subwoofer Car...
How do i wire mtx 9500 subs 2 10'' down to a one ohm
THE T9510-04 SUBS ARE SINGLE COIL SUBS AND YOU CAN VIEW THAT WIRING DIAGRAM AT THE FOLLOWING LINK:
http://www.mtx.com/caraudio/products/subwoofers/TechData_T9510-04.pdf
THE T9510-44 SUBS ARE DUAL VOICE-COIL SUBS AND YOU CAN VIEW THAT WIRING DIAGRAM AT THE FOLLOWING LINK:
http://www.mtx.com/caraudio/products/subwoofers/TechData_T9510-44.pdf
SINCE YOU NEED A 1 OHM LOAD, I PRESUME BRIDGED AND ARE USING TWO SUBS, THEN HOPEFULLY YOU HAVE THE DUAL VOICE COIL TYPE, AS THEY ARE DUAL 4 OHM AND YOU WILL HAVE TO CONNECT THE VOICE-COILS IN PARALLEL WHICH WILL MAKE EACH SPEAKER A 2 OHM SPEAKER AND THEN CONNECT THE TWO SPEAKERS THEMSELVES IN PARALLEL AND THIS WILL PROVIDE YOU THE 1 OHM LOAD. IF YOU IN FACT HAVE THE SINGLE 4 OHM VOICE COIL VERSION, THEN IT WILL ONLY PARALLEL THE PAIR DOWN TO 2 OHMS. OK. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE.....V
Jan 08, 2010 | MTX T9510-44 - 10" 9500 Thunder Series...
I have a 12" xs that has dual 1 ohm vc`s...how do i wire it to get a 1 ohm load?rick
Im sorry but thats not gonna be possible with a single sub with dual 1 ohm voice coils. You can wire it to achieve 2 ohm or 1/2 ohm. You will need to add a second sub to get to the 1 ohm mark.
play around on this site for some clarification: http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=1&I=12
Oct 01, 2009 | Kicker 12" Solo X Subwoofer S12X - 5000...
Wiring 12" icmb-5612 preformance teknique subwoofer
That sub has dual 4-ohm voice coils. It can be wired either as 2-ohm, 4-ohm, or as 8-ohm.
2-ohm = voice coils in parallel (both positives and both negatives connected to your speaker amp out wires).
4-ohm = use only 1 voice coil (either is OK).
8-ohm = voice coils in series (connect the positive of one voice coil to the negative of the other and connect the remaining positive and negative to your speaker amp out wires).
Mar 24, 2009 | Performance Teknique ICBM-5612 Car...
Fried electronics in KLH ASW10-120B subwoofer
It is a 4 ohm nominal impedance woofer. If you put a new woofer in, it will last maybe half an hour and then fry/melt. The problem is the amp, not the woofer. Throw the amp out and use the box as a passive sub. Get a 100 hz sub crossover.
Dec 03, 2008 | KLH ASW10-120 Subwoofer
How should I wire my 3 subs to the 500/1 amp???????
First of all how many ohm's are each subwoofer rated at . Are the subwoofers dual voice coil or single voice coil. Once I know that I can help you. I think the JL amp is not recommended below a 2ohm load.
Mar 16, 2008 | Jl Audio 500/1 Car Audio Amplifier
Coustic Car Audio 12RS Car Speaker Logo
121 people viewed this question
Top Coustic Car Audio Car Audio & Video Experts
xxxxxx xxx
Are you a Coustic Car Audio Car Audio and Video Expert? Answer questions, earn points and help others
