Question about Jensen VM9511TS AM/FM/CD/DVD/SD Player/7" LCD Car Video Player
I have the unit hooked up i can hear the cd and the radio but the display only shows a blue screen if i go to the set up screen and hit the back buttom i can see the display for the cd and or the radio only for a second and it goes back to the blue screen can u help me
  • billykid65 Jul 04, 2010
    just for your info it is not the brake wire this happen with cd radio and dvd ground is good when i go to system setup and hit the back button i see the screen for the radio with the preset button and with the cd i see the disc information i just disconnected the ground this morning and reconnected it when that happened it showed the screen the way its meant to be so i know its not the screen but once i changed it from cd to radio it went back to black blue screen with just the time stamp on it you can still hear everything just blue screen i have reset the unit several times still nothing.
    The model is a Jensen VM9511TS.
  • 4,889 Answers
Yeah sure. If you can just get me the make and model of the tv I can surely help you or atleast give my best shot.
Sai.
Posted on Jul 04, 2010
  • eagle338
    eagle338 Jul 04, 2010
    Ok. So you mean to say that you can actually watch the video that's on the CD momentarily before it goes back to the blue screen. Is that correct?
    Did you verify the wiring diagram? If not please check out page 5 of the manual so that we can skip to the settings part.
    http://a248.e.akamai.net/pix.crutchfield...
Radio display says protect. does not emit sound.
Sounds like you have either a short in your speaker wire somewhere, wires touching in the back of the unit or a short inside the stereo itself... Try pulling the radio out and unhooking all of your speakers...Turn unit back on after all speakers are disconected...If unit still shows protect, then radio is bad...If it doesnt, power off and hook up speakers one by one and power it back on till it shows protect again....When it does, the last speaker wire you hooked up has either a crossed wire or the speaker is bad...
Oct 07, 2010 | Kenwood KDC-MP205 CD Player
I have the unit hooked up i can hear the cd and the radio but the display only shows a blue screen if i go to the set up screen and hit the back buttom i can see the display for the cd and or the radio...
All I could find out about this problem, is that the screen's reverting to "stow-away mode". It could be doing it because of a problem with the touch screen (intermittent sensor connectors). The screen is TFT, and can also have damage if bumped, but from what I've read about these type of problems, it's often the touch sensor connection in the display. There are YouTube Videos about repairing touch screens, and I saw a couple on the ipods, which is a similar system. It's quite a process, but can be done with disassembly and a heat gun. Your problem could also be a slightly loose ribbon connector, with just enough intermittence to default the cpu to the stow-away mode. If the reset isn't working, it's either the screen or a ribbon connector, and those are easy to reseat, after you get the unit apart.
If you do get it serviced, get an estimate first. Then you'll know whether or not you want to try it yourself, or go another route.
Good luck, and hope this helps.
Jul 04, 2010 | Car Audio & Video
Audiovox: cd micro system for iPod. model# CD6229i: red standby light is on but blue display screen stays blank and no buttons work.
push the standby button and it should turn on the blue display should light up brighter make sure the speakers are pluged through the back and change the button that says source.. and change it too fm radio you should hear the static. hope this helps
Jan 01, 2010 | Durabrand Televison & Video
Hooking sat to car stereo
that plug at the back is not for sat radio. It is for use with steering wheel controls. You have the blue plug at rear of stereo and that is the plug for sat radio. Ericson electronics is contracted to build the sat compatible units that wire into this radio through the blue. plug. if you are using 3.5 plug audio control from a portable sat receiver, the you will need to buy an aux input cable for your stereo..
Sep 25, 2009 | Pioneer DEH-P3700MP CD/MP3/WMA/WAV...
Radio audio working but no audio from CD. Shows cd playing but no
:) swap your blue with your blue/wht or vice versa.. (behind the radio) this WILL fix your problem..
Jan 27, 2009 | Sony CDX-CA850X CD Player
Eclipse CD2000 has no sound from a cd or sirius... radio works
If you have an amplifier hooked up make sure that the correct blue wire on the harness is connected. One of the wires is the remote amp turn-on, the other is for a power antenna. That would be why your radio plays through your speakers, the power antenna wire' when the source is set to radio, sends a 12 volt signal. That would turn on your amp if thats the way that its hooked up.
Nov 16, 2008 | Eclipse CD2000 CD Player
Kenwood KDC-119 car stereo problem
There is a small hole at the bottom of the stereo face that will reset the system. I pushed a pen tip into the hole and it turned the stereo off. When I removed the pen, the system turned on and the CD ejected. Problem solved.
Jul 02, 2008 | Kenwood KDC-135 CD Player
2006 Nissan Titan: Radio-CD Will Not Power Off/Volume Stuck/No Display
Sounds like the head unit is bad. If the truck is under warranty , get it back to the dealership.
Jun 20, 2008 | 2004 Nissan Titan
Alpine 9885 - no sound with cd's or ipod
have you fixed it yet? if not try this. your car probably has factory amplified speakers. hook up the remote wire AND the power antenna wire to the blue factory amp wire and it should work just fine
Mar 08, 2008 | Alpine CDA-9885 CD Player
My phase linear uv7i can't plays dvd's or cd's and the screen is totally blue
caution it´s unlawful to operate a vehicle while video is dispayed in thr drivers viewing area
engage emergency brake sequence to enjoy video???? help help please
Jan 26, 2008 | Phase Linear UDV9010 Car DVD Player
Car Audio & Video Logo
49 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
