Question about Pentair Minimax 100 Pool Heater
I have a PacFab MiniMax 100 pool heater. The pilot remains on... but the burner will not ignite unless I hit/jar the heater. Any suggestions on what may need replacement or repair?
  • 760 Answers
First thing to check is the flow switch. You can bypass it temporarily, and see if it lights. DO NOT OPERATE IT WITHOUTH FLOW SWITCH. If it isn't the flow switch, then it could be the thermostat or a bad connection on this low voltage millivolt circuit.
Posted on Jul 04, 2010
How do i install an igniter in minimax
Pentair 472604 Igniter Replacement MiniMax NT STD Pool and Spa Heater
The ignitor is simple to replace, It is either a spark ignitor or a Hot surface ignitor. The above link will take you to a picture of the Hot surface ignitor, it is normal held onto the bottom of the burner tray, at right about the middle, by 1 or 2 sheet metal screws.
If a Spark style ignitor/electrode, then the bottom link is the one want to look at. Again, held in place the same way as above description.
Pentair 471090 Ignitor Electrode Replacement MiniMax 75 100 Pool and Spa...
Good Luck
Jun 04, 2014 | Pentair Minimax NT Heater
Igniter works gas kicks on after igniter stops if it would spark a little longer it would lite I can lite it with a match
Check igniter! You don't have the right spark? Lots of times it will short out & you can see the sparking elsewhere other than just at the gap at top of the igniter. The other thing to check is ensure that the orifice is completely clean at the pilot burner. A clean pilot orifice and the proper spark will ignite the heater.
May 19, 2014 | Pentair MiniMax 100 Natural Gas Swimming...
Pentair minimax nt explosive ignition
Problem is an obstructed gas oriface. The burners light from the burner closest to the pilot assembly out like a dominoe effect. The explosion is because the gas has to make its way over to the pilot from a further burner thus filling the firebox full of gas before it ignites. This blockage is most commonly from a spider web inside the oriface itself. Pull the burner tray, remove the orifaces from the tray and look through each one cleaning them out with a toothpick from the backside. The orifaces should be threaded on the gas line coming off the gas valve (looks like a silver box inside the front panel)
Feb 16, 2012 | Pentair Minimax NT Heater
I have a Pentair Minimax CH 250M pool heater. When I opened my pool, the heater started up fine and heated the pool initially. However, since the initial heater it has not come back on, and the pool is...
Do you have 24V at the brown wire of the gas valve? If you do then it is probably a bad gas valve.
If you don't have 24V on the brown wire it is probably the ignitor.
Jun 04, 2011 | Pentair Minimax Ch 250,000 Btu Natural Gas...
My heater will not light and electronic ignighter just continually sparks but burners do not light up? I've checked gas, etc but just won't light. Any suggestions? Do burners need replacing? Heater is 8yrs...
Do you physically see the spark or are you just hearing it. You can also take the igniter wire off of the control module and disconnect the pilot gas tubing from the gas valve. Turn the heater on and wait to see if you hear and smell gas coming out of the gas valve. If there is no gas check for 24v at the PV connection on the module. If there is voltage the problem is the gas valve. If no voltage the problem is the ignition module. If there is gas I would replace the pilot and gas tubing.
Santa Clarita Pool Heater Repair
Apr 19, 2010 | Pentair 250k Minimax Ch Ng Mv Heater
Mini max 100 pool heater. Propane tank full pilot won't light
hello. i can help. if you have propane but you can not get the pilot to light your thermocouple needs to be replaced. this is a common item available at any hardware store.
Jun 25, 2009 | Pentair MINIMAX NT TSI IGNITER
I have a Mini Max 100 pool heater. The pilot
check pressure switch for proper adjustment and make sure filter is clean so system pressure is normal
Jun 07, 2009 | Pentair MiniMax 100 Aboveground 100,000...
I have a Pentair MiniMax NT 250,000 btu pool heater that fails to
Two reasons.
1. There is air in the gas line. Power down the heater and allow it to try igniting until lockout. If it locks out, repeat the process. Most lines will clear within 4-5 attempts to ignite.
2. A plugged burner orifice. Run a small pipe cleaner in the brass fittings on the burner tray. They may have small webs in them restricting gas flow.
If the unit is a Standard (STD on the plate inside) it has a flame sensor that may also be bad. That sensor is on the end of the single wire that is cloase to the ignitor wire near the burners. Also check for a losse ground wire on the heater.
Nov 24, 2008 | Pool & Spa
Pentair Minimax 100 Pool Heater Logo
474 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
