Question about Dell OptiPlex 330 Desktop Desktop Computer
My system freezes any time during psot booting and when logged on
  • joecoolvette
    joecoolvette Jul 05, 2010
    I believe it is a hardware problem, not software. Let's do some simple diagnostics. A) Is the computer dirty inside, as well as inside the Power Supply? If you have never cleaned it, or had it cleaned, it is. When a Processor becomes too hot, it turns off. Caused by one of two things, or both. 1) Computer case fan in the front is dirty, and the Heatsink Assembly that receives air through the plastic tunnel is dirty. 2) Thermal paste compound that is in-between the top of the Processor case, and the bottom of the Heatsink, has dried up. B) Checks out? Let's go on. Power Supply is developing a weak Voltage power rail. Check the 12 Volt power rail. 11 to 13 Volts indicates it's okay. Less than 11 Volts means it's time to replace the Power Supply. Mini-Towerhttp://support.dell.com/support/edocs/sy... Desktophttp://support.dell.com/support/edocs/sy...
  • 487 Answers
Soft ware problem. Try pressing the ESC button during boot up, this will allow you to go into safe mode from where you can reset your system to a previous time
Posted on Jul 04, 2010
When open the compeuter must press f2 for work my computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
if this fails to fix the problem you might try safe mode
During the boot process tap the f8 button three times this will boot into safe mode where the only things
working will be your mouse and keyboard enabling you to attempt to repair your computer
is this the only key you have to press might be a log in requirement you have enabled
depending on your operating system click start control panel user accounts change the way you log on you should see log on options change the way users log on/off
learn more about user accounts increase log on security
hope this helps
Aug 24, 2011 | ASUS P5RD1-VM Motherboard
Dell Inspiron 1545 desktop freezes after login.
HI, when did the problem started? what you can do is to restart the computer in safemode with networking. And if the problem just started recently. you can try to do the system restore.
  • click on start
  • go to all programs then accessories
  • then go to system tools and choose system restore
  • then choose a different restore point
  • then wait for the restore to finish and try to log on again.
  • if there is still a problem logging on
  • try to have the system check the files system
  1. click on start
  2. go to all programs
  3. go to accessories and choose command prompt
  4. now type sfc /scannow and wait for the system to finish doing the scan.
  5. then try to log on again.
thank you for using Fixya, you recommendation is highly appreciated
Jul 28, 2011 | Computers & Internet
My computer, Windows XP, freezes when I use Firefox
Your system loaded with Windows Xp Operating System might get affected by various viruses and malware. The antivirus softwares installed in your system for the removal and prevention of viruses from your system cause the freezing issue. This antivirus softwares might take too many time to load and it also make the entire system slow to boot. The antivirus programs result in the freezing of the Windows Xp during start up. Thus you need to temporary uninstall the antivirus software during the start up of your system.
Jan 05, 2011 | Computers & Internet
Adminspassword
When you boot up to the log in screen type in administrator to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up
Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
on the users tab,click the name of the computer administrator you can change the password there
hope this helps
Admin password forget what will do?
or
hope this helps
Dec 05, 2010 | Computers & Internet
Post Boot Freeze
It freezes because one of the programs set to start at boot crashes. To identify which immediately after booting open Task Manager and look at the processes - one should reach 99% CPU use. Once you have found it stop it from launching at boot or just uninstall it.
Jan 22, 2010 | Dell Inspiron 1525 Notebook
Lenovo 300- N200 fails during the boot process. Screen freezes after boot sequence.
Is it working with latest update from windows if you are using any windows operating system? Some applications installed by you which run at startup time hug the system.
You can try logging into the system in safe mode and try to see whether you are able to enter into the system or not. Once entered with safe mode rename the installation folder for the new applications that you might have installed, after which the system started freezing.
After renaming it you can boot the system in normal mode. As the new applicaiton will not be able to run (due to folder renaming) it is most likely that the system will boot properly and you will be able to enter the system.
Then rename back the folder to original verify the compatibility of th eapplicaiton and if possible uninstall the application.
This process has saved me from a lot of system complications. Hope this helps you.
By the way which operating system are you using?
Nov 08, 2009 | Lenovo 3000 N200 Notebook
Freezes after logging in
It's time to reinstall the operating system--you have had a virus destroy the boot/load sector, thus the lag.
Apr 11, 2009 | Dell Inspiron E1505 Notebook
HP Pavillion 760n Warning immediatly back up your data
plz check if you can get the bios screen. If yes then while booting press F8 key so that you can enter safe mode.if you can log in through safe mode then do a system restore to earlier date.If you cant log in through safe mode then you have to reinstall or repair your operating system
Oct 28, 2008 | Computers & Internet
Freezing or shutoff on boot, setup or minutes into operation
Try this:
Boot the system with your Windows XP installation disk. When the boot options window appears select R for recovery console. Once you have logged into the DOS session type: fixmbr and hit the enter or return key and select "y" for yes you want to do this. Type: fixboot and hit the return key again, hit "y" for yes.
May 17, 2008 | HP Pavilion ze2000 Notebook
Dell OptiPlex 330 Desktop Desktop Computer  Logo
118 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
