Question about Aquabot Pool Rover Above Ground Robotic Pool Cleaner
Aquabot pool rover jr goes around a couple of times and stops.
Check the belt to see if it has gone loose or does not have enough tension to keep it on the move. Click on the link below to read more:
http://www.aquabots.com/repair-instructions/drive-belt-replacement.htm
Posted on Jul 04, 2010
  • 4dawgfans Jul 06, 2010
    The Aquabot Pool Rover Jr does not have a belt
Pool rover has like patrolum jelly on it around bag
It is a type of algae. Wash it off and bleach it or tilex it.
Jun 01, 2014 | Aquabot Pool Rover Above Ground Robotic...
Pool rover junior won't back up
Try this: Take the Rover out of the pool and lay it down, wheels down. With your garden hose, shoot a strong jet of water into the impeller opening, alternating sides, 3-4 times each side. There's probably some material stuck in there.
May 30, 2014 | Aquabot Pool Rover Above Ground Robotic...
Pool rover goes only one direction
they usually do unles its et the other way.. if its working leave it alone..
Jul 29, 2012 | Aquabot Pool Rover Above Ground Robotic...
Rover only goes one way
I had this same problem. I took the Rover out of the pool, removed the filter, turned it right-side-up and shot a strong blast of hose water into the outlets where the water exits to propel the Rover. Do both sides over & over a few times. That should do it.
My pool rover goes one way but wont turn around just keeps pushing against the wall
Hello Kathy,
I have the same problem. Do you already have a solution?
Regards,
Bob from belfium
Jun 10, 2012 | Aquabot Pool Rover Above Ground Robotic...
The aquabot doesn"t go all
If you can wiggle the cord and make the pool cleaner work, it sounds like an electrical problem. If this is the case, you need to have it serviced by a professional. There are a few things you can check first, though. Make sure that the filter bag is clean and clear of debris. Make sure that all lint, cloth, or debris is removed from the impeller.
Sep 10, 2011 | Aquabot Pool Rover Above Ground Robotic...
How deep does the water have to be for the pool rover jr.?
If this is the type of cleaner that runs with a long hose connected and has one end stuck in the skimmer, the pool will need to be completely filled to normal level. The pool is filled with crud right? Use a long extension pole with a leaf net on the end to get out all the stuff you can. There is no way around the hard work. Don't be surprised if you need to use quite a few bags of powdered chlorine or jugs of liquid chlorine to clear the water up. Don't give up, it's gonna be hot this summer.
May 23, 2010 | Aquabot Pool Rover Above Ground Robotic...
Online instruciton manual
Here is a page of articles from aquabot ,, lots of instructions you can view ..
http://www.123aquabot.com/Articles.htm
Please Vote !!
May 15, 2010 | Aquabot Pool Rover Above Ground Robotic...
Pool rover JR running slow
This has happened to me several times. Hair can get caught on the impeller. This causes the flap inside the jet to not close completely. Unplug the unit, remove two screws off the jet exhaust and gently remove the hair.
Mar 13, 2009 | Aquabot Pool Rover Above Ground Robotic...
Aquabot Pool Rover Above Ground Robotic Pool Cleaner Logo
271 people viewed this question
Top Aquabot Pool & Spa Experts
Robco Water
Robco Water
The Cover Guy
The Cover Guy
David Spradling
David Spradling
Are you an Aquabot Pool and Spa Expert? Answer questions, earn points and help others
