Question about Kohler K-T10335-4-CP Lyntier Rite-temp bath and shower faucet with lever ....
The shower mixer seems to not be cold water just warm and hot how do i resolve this problem
  • 487 Answers
Your filters may be blocked on the mixer or it may need replacing
Posted on Jul 04, 2010
Our bath taps which are a mixer with shower attachment stay really hot if you put the hot on first or really cold if you put the cold on first any idea how to adjust so we can have warm water when turning...
you make no sense. From the picture the water "mixer" is the center lever or is it a diverter valve for the shower and water nozzle below???
The knobs are for hot and cold water??
Jun 08, 2014 | Plumbing
Mira 88 manual mixer not supplying hot water.
You need a new cartridge for the shower located behind the handle.
Jan 26, 2014 | Home
Got mira discovery mixer shower. wont get hot just luke warm or cold. taps in rest of house ok? Had it off the wall recently to tile behind it but apart from that been great for 6 years. any ideas?
There should be a hot water limiter behind the knob on the shower - shingle handle, undo the handle and move the adjustment to allow more hot water. Not familiar with mira discovery mixer
Feb 03, 2013 | Home
How to clean Axor Terrano Showerpipe - hot water part of mixer seems blocked
There are filter screens on the thermostatic cartridge inside this unit. You will need to remove the thermostatic cartridge and clean the filter screens. If cleaning the thermostat cartridge does not resolve the issue you may need to replace the cartridge. If you need further assistance feel free to contact me at Hansgrohe Technical services. 1-800-334-0455. prees 2 for tech and ask for David Scarborough.
Aug 30, 2012 | Home
Very little cold water, lots of hot from kohler shower valve
Probably some pipe rust clogged the exit.
If u have pretty low presure as default on both hot and col water, try keep force closed by hand the water exit at shower pipe, then start both cold and warm water gradually as much as u can keep it closed with the hand.
The hot water pressure going back thru the cold water pipe might unclog that debris.
Just a simple fix which many times works as a charm..
Otherwise if this is not fixing, try close both water from main service valve.
Then unscreew the secondary shower valves and manually clean them or replace if very damaged.
Dec 14, 2017 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Mira mixer cannot balance temp.either scalding hot or freezing cold
I suspect you have gravity fed hot water system and the mixer cannot balance the high pressure of the cold mains against the low pressure of the hot water.
Either install a shower pump. Means installing electrical connections and quite a bit of plumbing
Or a mechanical pressure reduction valve on the cold input pipe to the shower
Apr 02, 2010 | Legacy Home
Warm water only
You can eliminate the shower control knob possibility by turning on your hot water anywhere else in the house. If you get hot water in other places, then it could be the knob causing it. A substantial lime buildup in the tank can also cause poor heat transfer from the elements to the water.
Sep 16, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Have a combi boiler and the hot water from my taps are running cold to luke warm. My British Gas engineer has told me it is nothing to do with the boiler but is caused by a faulty thermostat cartridge in...
Modern shower valves have an "anti scald device" in them to prevent scalding from to hot water.
They come preset at 120 degrees.
Sometimes they can start to malfunction and all you get is warm, not hot water, they can also be intermittent.
This will only effect the shower valve though, not the other faucets.
Dec 06, 2008 | Heating & Cooling
Cold water suply filling up header tank in loft thru hot water suply on shower.
hi did you run a seperate cold water supply from the storage tank to the shower pump & also a seperate hot supply from the hot water cylinder, it sounds as though the cold water is crossing into the hot service & pushing its way up to the tank as its the only way it can go, sounds as though the cold water connection to the shower is not tank fed & possibly directly off the water main.?
Oct 05, 2008 | Home
Kohler K-T10335-4-CP Lyntier Rite-temp bath and shower faucet with lever .... Logo
509 people viewed this question
Top Kohler Plumbing Experts
Mike
Paul Carew
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
