Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
How do I adjust the speed control handle
The control handle has about 8 inches of travel area. The first 6.5 inches do nothing. When it starts to move, it jerks forward because I can not move it slowly in such short space. What to do, What to do???
Also, How can I get a manual? This was a store floor demo unit and they lost the manual.
Thanks for any ideas and suggestions.
  • 2 more comments
  • Ian Summerfield
    Ian Summerfield Jul 04, 2010
    was this new,or s/hand?
  • roelke Jul 04, 2010
    Its a new unit.
    It was a floor display unit but except for that it is new -- i.e. never been used for mowing.
  • Ian Summerfield
    Well,I would go back to the store and ask them,tell them your problem.Is it a continuously variable speed g/box?are you sure your brake pedal/handbrake isnt on?while your going forward,try adjusting that control lever.see what it does.
    Brigadier General:
  • 3,911 Answers
Well on my AYP manufactured tractor, which is much like yours but has the name Husqvarna on it, the hydrostatic transmission is shot and it exhibits much the same characteristic. That is no forward nor reverse movement until it gets nearly to the end of its range. The F/R lever on the right side is connected to a much smaller lever on the end of a shaft which goes into the transmission. What I would do is check the linkage to make sure that the range of travel on the speed control moves the smaller lever input into the transmission. If the range of travel is the same, you may need a new transmission, they are expensive. If there is some slop in the linkage, you may have another day in the sun. You can google "manual, craftsman, lawn tractor" and find some links to get a manual. What I did was find another lawn tractor as the cost of repair far exceeded the value of the old mower.
Posted on Jul 05, 2010
Mototech mini quad. Where do I charge it
Looks like you need a battery charger. It has two 12 volt batteries. Didn't it come with a charger? And your parental control is via a key.
The MotoTec 24v Mini Quad v2 is the ultimate kids atv! Great for driveway and backyard fun, cruise over bumps and speed through dirt trails with ease. Comes standard with front & rear suspension, front & rear brakes and large 13 inch knobby pneumatic tires. This mini quad provides longer ride times than the competition with TWO large 12v 12amp hour batteries. New features include: headlight, key start, battery meter, forward & reverse, 2 speeds selectable by key and twist throttle with safety foot switch. SAFETY FIRST - ALWAYS WEAR YOUR HELMET AND ALL SAFETY EQUIPMENT AND OBSERVE SAFE RIDING RULES!!! Motor: 24 Volt 350 Watt
Battery: TWO 12v 12ah (24v Total)
Top Speed: 5 & 10 MPH (parental speed control by key) Recommended Age: 6+ years old (A parent's decision to allow his or her child to ride this product should be based on the child's maturity, skill and ability to follow rules.)
Max Rider Weight: 150 lbs
Frame: Steel
Tires: 4.10-6 Knobby Pneumatic (13 inch)
Brakes: 2 disc front, 1 disc rear (with parking brake)
Suspension: 2 independent front shocks, 1 rear shock
Throttle: Variable twist-grip (with safety foot switch)
Seat: Padded (single rider)
Handlebars: Adjustable Forward/Back
Battery Meter: Yes
Key: Yes
Headlights: Yes
Charging Time: 4-6 hours
Charger Included: Yes
Assembly Required: Yes
ATV Size: 42x23x25 inches
Handle bar height from ground: 25 inches
Seat height from ground: 19 inches
ATV Weight: 101 lbs
Box Size: 43x25x22 inches
Box Weight: 114 lbs
Product decoration and specifications subject to change without notice.
Warranty: 30 days parts replacement
MotoTec 24v Mini Quad v2 Blue
Dec 09, 2015 | MotoTec Kids ATV-24v Mini Quad
How do i replace grips on 2009 electra glide ultra classic
For twist grip equipped motorcycles to remove the throttle or right side grip remove the upper and lower switch housing screws, loosen the upper screw securing the handlebar clamp to the master cylinder housing. Remove the lower clamp screw with flat washer, separate the upper and lower switch housings and remove the throttle grip from the end of the handlebar. (To remove the throttle grip, a slight tug may be necessary to release index pins in grip from receptacle in seal cap of twist
grip sensor.)
With throttle cables, to remove the throttle or right side grip slide the rubber boot off of each cable adjuster, loosen the jam nut on each adjuster, turn the adjusters in the direction that will shorten the cable housings to their minimum lengths. THEN remove the two screws and separate the upper housing from the lower housing, unhook the ferrules and cables from the throttle control grip and the lower housing, (remove friction spring, throttle friction screw and spring from the lower housing only if necessary), (only if and as necessary mark the position of the master cylinder assembly forward position and split line on the handle bars) (to be safe squeeze the front brake lever and place a 5-32 inch thick cardboard insert between brake lever and lever bracket and then release brake lever to hold the lever in this place to protect the brake switch from damage if the switch housing and the master cylinder get separated) (and only if and as necessary, loosen the two perch screws) move the lower switch housing as necessary and remove the grip.
To install the throttle grip apply a light coating of graphite to the handlebar and the inside surface of the upper and lower housings, (if removed, install the spring, throttle friction screw and friction spring in the lower housing) (and, if removed, attach the cable assemblies to the lower housing), (throttle control cable has a 5-16 inch fitting end and is positioned to the front of the lower housing. and the idle control cable has a 1-4 inch fitting end and is positioned to rear of lower housing. Install the throttle control grip over the end of the right handlebar, position the lower housing onto the right handlebar, engaging the lower housing with the throttle control grip, position the ferrules over the cable ball ends, seat the ferrules (with the cables attached) into their respective notches of the throttle control grip, install the upper housing over the right side handlebar and secure it to the lower housing with the appropriate two screws and hand tighten them, then align the brake master cylinder and perch assembly with the marks made prior to loosening them, and beginning with top screw, tighten the two screws to 108-132 inch lbs using a T27 TORX drive head and then tighten the upper and lower housing screws to 35-45 inch lbs. THEN point the front wheel straight ahead and WITH THE ENGINE OFF, adjust the throttle and idle cables by turning the adjuster in the direction that will lengthen the cables. Gently twist the throttle control grip to the fully open throttle position (fully counterclockwise) and hold it in this position and turn the throttle control cable adjuster counterclockwise until the throttle cam on the induction module (or carb) contacts the throttle cam stop, release the throttle control grip and turn the adjuster counterclockwise an additional 1-2 to 1 turn and tighten the jam nut on the throttle control cable adjuster. THEN turn the handlebars fully to the right and turn the adjuster on the idle control cable counterclockwise to lengthen the sleeve until the end of the cable housing just touches the spring within the cable guide. NOW check the adjustment by, with the throttle friction screw loosened, twisting and releasing the throttle control grip two or three times. The induction module throttle wheel must return to the idle position each time the throttle grip is released. If the throttle does not return to idle, turn the idle adjuster, shortening the cable sleeve until the correct adjustment is obtained, tighten the jam nut and slide the rubber boots over each cable adjuster. NEXT start the engine and with it idling turn the handlebars through their full range of travel and if the engine speed changes at all during this maneuver, adjust the control cables according to the foregoing procedure so that there is no change in the idle speed when the handlebars are rotated through their entire range of travel.
To remove the clutch or left side grip remove the two screws and separate the upper housing from the lower housing. Mark the forward position and clutch perch split line on the handlebars and then as necessary loosen the two clutch perch screws and move it out of the way so that you can access the grip end. If you want to save the grip take a small screwdriver with about an eight inch length and insert it into the grip, wiggling it to loosen the glue somewhat and then spray some brake kleen into the space under the grip where the screwdriver blade is inserted and wiggle and twist the screwdriver around to loosen the rest of the grip glue and pull the grip off. Sand down the handle bar area where the grip will rest and apply grip cement to the area and slip the grip on. If the left hand grip is patterned, align it with the pattern on the right hand grip with the throttle in the fully closed position, immediately push the grip completely onto the end of handlebar using a twisting motion. Do not hesitate when installing the grip or the adhesive may dry before installation is complete. Allow 6 to 8 hours to elapse at 70 degrees F to allow the adhesive to fully cure. If a newer non-glue grip is being installed slip it on with the flats properly oriented to fit with the switch housing halves when they are installed. Install the switch housing halves and lightly tighten the two screws and then orient the clutch perch to the previously made alignment marks and beginning with the top screw, tighten the screws to 108 - 132 inch lbs using a T27 drive head and then tighten the switch housing screws to 35-45 inch lbs.
Sep 20, 2014 | Motorcycles
Why wright pneumatic door closer v150 slams closed
Adjust the speed. Adjudsting screw in the end of it (on the door edn). Tun it in to slow down, out to speed up. Should only need 1 or 2 turns. If still not adjusting, replace the unit.
May 13, 2014 | Wright Products Heavy-Duty Black Pneumatic...
Calculate gallons of a tank
I assume the length of a side is 16 in, and the height of the prism is 23 inches.
Volume of a prism is V_prism=(Area of base)*(height of prism)
Area of base is made up of the area of the 6 equilateral triangles with sides =16 inches. The height of such triangles is given by 8*SQRT(3).
Use the Pythagorean theorem or the trigonometric ratios to find the height of each of the 6 traingles.
Area of base =6*16*(8*SQRT(3))/2 sq in
Volume =6*8*8*23*SQRT(3) cubic inches
Calculate the value in cubic inches and convert to gallons: I leave that task to you.
May 12, 2014 | Office Equipment & Supplies
Kitchenaid Artisan KSM150 Stir problem - Stir speed is the same as setting 2, but all others (4, 6, 8, 10) work fine. Tried adjusting the control board but "stir" and "2" still spin...
You are not adjusting the screws correctly. All three screws (2 top left and right, and 1 bottom)
must all be adjusted. Here is how:
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Jun 20, 2011 | KitchenAid KSM150PS Artisan Series Stand...
The KSM150PS 325W mixer does nothing until speed control is moved up to position 8 or 10. Then when repositioned back down to say 6 it may run for a moment but then stops. It might just click on position...
You need to adjust the mixer speeds. Obtain a copy of the KSM150PS Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must all be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Apr 22, 2011 | KitchenAid KSM150PS Artisan Series Stand...
It started as a clicking noise inside the primary chain cover, kept getting louder, especially when at idle...I recently had the 10,000 mi service done, and I suspect it wasn't adjusted to the proper...
If your bike is a Big Twin, your primary chain is supposed to the adjusted to have 3/4 to 7/8 inches of up and down travel when the engine is cold. If it's a Sportster, it should have 3/8 to 1/2 inches of up and down travel when cold. As the engine heats up and expands, the chain will tighten up. The clicking could be caused by the engine compensator sprocket as well by weak springs in the spring cup or by the nut being loose.
Good Luck
Steve
Apr 03, 2011 | Harley Davidson FLSTF - FLSTFI Fat Boy...
Burnt smell from clutch when im in 3rd gear
It sounds like the clutch is close to being worn out as the pressure plate is not gripping the clutch plate with sufficient force when power is applied. Before you consider replacing any thing, first check the clutch free travel adjustment because as the clutch plate wears the free travel does decrease and if there is no free travel, then there will be some releasing action on the pressure plate allowing cluth plate slip. Hydraulic setups are usually self adjusting but you should check the free travel of the clutch pedal which should be about 3/8 to 1/2 inch measured at the pedal rubber. This is done by adjusting the push rod that links the pedal arm to the piston in the master cylinder. Adjust by first loosening the locknut on the rod at the end where it attaches to the pedal arm and turning the rod in either direction to obtain the correct free travel. One adjusted retighten locknut.
For a cable setup there should at least 1/8 inch of free travel of the cable before it starts to move the clutch fork on the outside of the bell housing. To adjust, hold the operating fork so that the release bearing is touching the fingers of the pressure plate. You will need to turn the cable adjuster so there is only about 1/8 to 1/4 inch of free travel of the cable where it attaches to throw out fork before it starts to move the fork when the pedal is depressed.
If all adjustments are correct and clutch is still slipping then the pressure plate diaphragm spring has lost its tension and /or the clutch plate has worn down to the rivets. Either way you will have to do a complete clutch rebuild.
Oct 28, 2010 | 1989 Volvo 240
What is an Error 22, 23,and 26 on a precor 9.35?
Error 22 indicates that the drive motor (running belt) has been instructed to start, by either manual or program control, and the monitoring system has not received any response from the speed sensing system indicating that the drive motor has started.
Error 23 indicates that the speed sensor signal was lost while the treadmill was in operation
Error 26 this error monitors the speed sensor signal and verifies the the speed sensor signal is appropriate for the requested speed. If the speed sensor signal is incorrect or erratic an Error 26 will be displayed.
Unplug unit and remove motor shroud and try these procedures:
The treadmill utilizes an optical (infrared) speed sensor and the line of sight between the speed sensor and the speed sensor target is obstructed. The speed sensor position relative to the speed sensor target is incorrect. The speed sensor potentiometer adjustment is incorrect (when equipped). The speed sensor target is damaged
Carefully, vacuum out the drive motor compartment with a static safe vacuum cleaner. Pay special attention to the area between the speed sensor and speed sensor target. Adjust the speed sensor position so that the space between the speed sensor and the speed sensor target is 3/16 inch and so that the speed sensor photo eye is aimed at the larger portion of the targets wedge shaped section. On hall effect speed sensors (magnetic sensor) the space between the end of the speed sensor and the flywheel tooth should be 3/16 inch. If the treadmill utilizes a speed sensor potentiometer, locate the speed sensor potentiometer on the lower PCA. Set the speed sensor potentiometer at mid-range. Start the treadmill and increase the speed to 6 mile per hour. Carefully adjust the speed sensor potentiometer to the point where the treadmill is operating the smoothest. Increase the treadmills speed to full speed at repeat the previous adjustment. These two adjustments are typically small and are usually only a matter of fine tuning. . Most speed sensor targets consist of a circular arrangement of alternate black and silver sections. If the speed sensor target is torn or badly scratched the speed sensor may receive an incorrect reading. Replace the speed sensor target.
Jun 25, 2010 | Precor 935 Premium Series Treadmill
Can you tell me what Err22 is? Thanks!
Description
Possible Causes
1. The treadmill utilizes an optical (infrared) speed sensor and the line of sight between the
2. Drive motor brushes are bad.
3. The speed sensor position relative to the speed sensor target is incorrect.
4. The speed sensor potentiometer adjustment is incorrect (when equipped).
5. The speed sensor is inoperative.
6. The lower PCA is bad.
7. The lower PCA to upper PCA interconnect cable is bad.
8. The upper PCA is bad
Possible Remedies
1. Carefully, vacuum out the drive motor compartment with a static safe vacuum cleaner. Pay
2. If the motor brushes do not make sufficient contact with the motor commutator, the drive
motor will not start when drive voltage is applied. Replace both drive motor brushes.
3. Adjust the speed sensor position so that the space between the speed sensor and the speed
4. Locate the speed sensor potentiometer on the lower PCA. Set the speed sensor
5. If the speed sensor in inoperative the drive motor will start and run briefly before the error 21
occurs. If it is possible to access the speed sensor wiring, measure the D.C. voltage between
the speed sensor leads Two of the leads will constantly read approximately 5 Vdc. Two of the
leads will toggle between 0 Vdc. and 5 Vdc. as you slowly rotate the speed sensor target. If
you do not see both measurements above, the speed sensor is inoperative and must be
replaced. In some cases the speed sensor is mounted on the lower PCA and the the lower
PCA must be replaced.
6. Substitute a known good lower PCA to determine if the lower PCA is bad.
7. Substitute a known good interconnect cable for the existing cable.
8. Substitute a known good upper PCA to determine if the upper PCA is bad.
Oct 27, 2009 | Precor 9.21 Treadmill
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
239 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
