Question about Westinghouse SK-32H240S Television
I own a SK-32H240S westinghouse - I am trying to find the channel to where a valid signal can be found - In these channels I surf, all i get tis the "no channel" message - I have DISH NETWORK and am trying to find the correct channel to where I may watch satellite from.
    Novelist:
  • 123 Answers
We would be happy to help get that fixed right away. Thefirst thing we want to ensure is that all connected equipment is on. Check whattype of cable is used to connect the TV to the receiver. If you are using a CoaxCable to connect the receiver to TV1, check the receiver's back panel forthe output name. If your receiver has a "TV CH 3/4 Out" (non-ViPReceiver): Tune TV to channel 3 or channel 4, back if it islabeled "Home Distribution" (ViP Receiver): Tune TV to channel62 or 75. If using non-Coax (RCA, Component, or HDMI) toconnect receiver to TV1, cycle through the inputs until picture appears; MostTVs have a "TV/Video", "Input", or "Source" button.We want to ensure that the TV and the receiver are connected properly, pleasevisit this link to for more information:http://www.dishnetwork.com/SupportSection/setup-receiver-totv. Once we havemade sure everything is connected properly, unplug receiver for 10 seconds thenplug it back in, this will reset the receiver. If we are still not getting apicture connect another component (VCR, DVD Player, etc.) to the same TV, usingsame cable, same input, and same channel to see if it works. If you get apicture with the other component give us a call at 1-800-333-DISH (3474) forsome additional troubleshooting. If it doesn't work with the other componentthen replace the cable that was used.
We hope these steps resolve the issue. We want to thank you for being a valuedDISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Posted on Feb 22, 2011
Problem: Westinghouse SK-32H240S HDTV has a flashing/blinking blue/red power led
hi when the colours flash again, press the menu button on the remote control and retune the tv hope it helps
regards
shaun
Mar 28, 2014 | Westinghouse SK-32H240S Television
Need westinghouse tv model sk-32h240s service manual
Westinghouse TV SK-32H240S http://legacywd.com/pdf/111_User_Manual.pdf
Aug 03, 2012 | Westinghouse SK-32H240S Television
Westinghouse tv sk-32h240s after watching for 10 minutes srceen turns blue
That normally indicates that it has lost the signal from the tuner/cable box if you lose the audio as well. I'd try different inputs such as a Dvd player and see if the same thing happens. If it doesn't, then the problem could be a bad solder connection near or in the tuner or cable leading to the tuner.
Jan 29, 2011 | Westinghouse SK-32H240S Television
I AM SUPPOSE TO PLACE THE TV ON CHANNEL THREE TO PICKUP SATALITE FEED. SINCE THERE IS NO CHANNEL 3 IN AREA IT WONT SWAP FROM ARIAL TO SAT RECIEVER
You use channel 3 if you are going to use coax cable to feed your TV from the sat receiver.. Some sats will use Channel 60 or something in that range. You should use Audio/video cables for you Sat feed.
Apr 30, 2010 | Westinghouse SK-32H240S Television
Tv does not stay on, screen goes black
Checked all connection given properly checked your cable connection some time cable connection not proper than also its display no signal
Jan 23, 2010 | Westinghouse SK-32H240S Television
Sk-32h240s unable to get all local channels thru ant. only what whould be the formally vhf channels, not uhf.
UHF needs a UHF antenna most all channel antennas do not work good on UHF,
Try the set at a friends house that does get those channels. UHF is harder to get and that is why a UHF only antenna is needed by most people. Lots of antennas are junk do a search and you will find the 8 bay C/M is rated the best by a large margin.
A good antenna amp at the antenna is also needed it should be a low noise one. A search will show the ones that work best.
The Gov. as much as lied to us and the TV Stations the type of digital they forced on us is the wrong one and millions of people even with a great antenna have lost TV.
Oct 25, 2009 | Westinghouse SK-32H240S Television
I have a westinghouse sk-32h240s whin i retune it
No. Everytime you rescan channels it will dump any previously saved channels.
Jun 23, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
I have a Westinghouse 26 inch TV. Model # SK-26H590D. It will not scan channel 9. I have tried both the automatic scan and the find channel scan. It is hooked to a Phillips Mant 510 vhf/uhf indoor antenna...
I carried my Westinghouse TV to the basement. Unplugged the antenna from the digital converter box and connected it to my digital TV. I then re-scanned for channels and found channel 9. After carrying the Westinghouse TV back upstairs, I connected the original set-up and tuned to channel 9 which was now showing on the screen as no signal. From that point I moved my VHF dipoles until I had located the correct position for reception. A little labor intensive, but I was fortunate to have another antenna that was receiving channel 9.
Feb 19, 2009 | Westinghouse SK-26H590D Television
Home theater hook up
Make sure u have plugged in the audio cable to the tv.
thanks..
Feb 01, 2009 | Westinghouse SK-32H240S Television
Televison & Video Logo
218 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
