Question about Panasonic Televison & Video
Panasonic vcr wont release tape has fault code f03
  • Panasonic Master
  • 5,449 Answers
It sounds like you have a model that uses the K-Deck, you might need to confirm this, by putting the model number on Google and the words "K-Deck". However if it is a K-Deck F03 means that it locks up when unloading. This can be put down to the loading motor, or the drive system, perhaps even the mode switch, also the timing of the mechanism.
I suspect you will need the service manual, as setting up a new mode switch is tricky. The good news is that you can get the K-Deck manual online free, all you need do is do a websearch for "Panasonic K-Deck manual". It will even explain how to the tape out of the mechaism.
One tip you can try however is spraying the mode switch with Servisol Video 40, if you think it's the culprit, it could have just got some dirt in it, not saying it could be that though, but worth trying before replacing one. (Curry's Partmaster if you need to replace the mode).
Posted on Jul 05, 2010
F03 DISPLAY ON MY NV-SD300 PANASONIC
go to panasonic.com/vcr and give them the model/serial # and ask what the F03 error code means and they can give you a solution for the problem.
Jerry
Aug 27, 2012 | Panasonic Televison & Video
Panasonic HS900 VCR. Switch on and F03 fault appears.
You have a model that uses the K-Deck look that up using google for further information.
However F03 means locks when unloading. There are several causes of this: The Load motor or drive, timing, or the mode switch.
Aug 17, 2011 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Wont do anything getting F30 error code
Do you mean F03? that error is known in Panasonic video products. It usually applies to the VCR, which means a mechanical fault; such as loading motor and/or mode switch. The switch itself would be on the main board under the VHS deck, and can be cleaned with special electronic spray cleaner, and electronic lubricant (after the cleaner), but for more reliable results, the mode switch may require replacement, which should be done by a workshop. If this is the only issue you have with your combo unit, it shouldn't cost too much to correct this problem. Either try cleaning the switch yourself (being careful when opening unit), or submit to workshop for quote and professional repair.
I have never heard of F30 as a video/DVD error code before. That error applies to some Panasonic air-conditioners and is a system error.
Apr 16, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-EZ47V Error Code F03
I saw this same issue. I would unplug and plug in the DVD and it would still show error code F03.
It turns out that one of my kids had shoved a couple of small objects inside the VHS opening and it was blocking the operation. I removed the objects and it works fine.
This error code is not listed in the manual that came with the DVD player.
Dec 21, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Error F03
F03 is a loading mechanism error. look for something obstructing the loading arms in the mechanism - a label from a tape, a piece from a broken cassette, etc.
May 08, 2008 | Panasonic AG-DV2000 Mini DV VCR
Panasonic VCR VIDEO PLAYER
Hi. I posted this question in the hope of getting some help with my VCR, as it was advertised as a free site... oh its free alright to post the question but to get any help you need to pay..... SO I SENT MY VCR TO A REPAIR SHOP LOCALLY !!! thats how I fixed the problem. with NO HELP FROM THIS SITE AT ALL........ Thanks but no thanks...........
Apr 06, 2008 | Televison & Video
Error Code F03
What worked for us when we saw F03? Taking the toothbrush out of the VCR! I kept resetting the unit and nothing worked. Finally, I decided to see what would happen if I stuck a tape in. It wouldn't go in because of the toothbrush! I took it out, reset the unit again and it was fixed.
Maybe the error is not F03, but FO3 meaning there is a FOREIGN OBJECT stuck in the VCR.
Feb 13, 2008 | Panasonic DMR-ES40V DVD-Video Recorder
Error F04 message displayed
Panasonic K deck F03 or F04 shows in display check loading motor coupling pt no VDP1434 or motor pt no VID12128 £11.95 CHS
Nov 22, 2006 | Panasonic NV-FJ620 VHS/S-VHS playback VCR
Televison & Video Logo
475 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
