Question about Acer Aspire One Netbook 8.9" Notebook
Internet connectivity. I can connect with three other pcs. One desktop and two other laptops so I know the modem and the router work fine. On the laptop it shows that I have connectivity but I cant get connected.
    Sergeant:
    Champion:
  • 324 Answers
Check your drivers, for your wireless card
Posted on Jul 04, 2010
There is no internet connection to the laptop. The arris modem gives internet acess to the PC computer, though. The manual for the Airlink 101 router says to connect the router and MODEM to each other by a...
What you're missing is that ALL the PCs will be connecting THROUGH the router to the Modem. Unplug the PC network Cable from the modem, then plug a network cable from the router's INTERNET port into the modem (where you removed the PC's network cable). Now, plug the PC's network cable into one of the ports on the router (usually 4 or more, marked 1,2,3,4. Think of a Router as a "splitter". It connects to the Modem, then several devices connect to the Router, some of them by wire and some by Wi-Fi. So your desktop PC is connected by wire to the router and your laptop PC is probably connected by Wi-Fi (wire is an option, as well). The Router sorts out all those signals and communicates with the Modem. Sound reasonable?
May 02, 2017 | Arris Comcast Touchstone Telephony VOIP...
Unable to re-connect laptop to internet via wireless router
Reset all again.
Power off the modem, router, and PCs and wait 20 seconds or so.
Then power up the Modem first, then the router, and finally your PCs, wait a couple of minutes and try to connect.
Apr 19, 2009 | Toshiba Satellite A100-S8111TD Notebook
Linksys wireless on my desktop,trying to use another computer in dining room that has a router or rooter dont know what it is, cant get online please help,the wireless rooter is connected to my main...
You do not need 2 routers to connect to the internet infact you need only 1. having 2 conflicts with pcs and causing them not to work.
From the wall you have your cable fro your internet that plugs into your modem, from the modem it plugs into the router by ethernet cable to the uplink slot and then your computers connect to the router. Most routers can connect 4 computers at once. If running them all wirelessly just reboot them and they should connect automatically. If your wiring them plug them into the back by an ethernet cable in the slots 1 for the first PC, 2 for the second so on and so on. You may have to cold boot everything at first meaning shut down all the computers, unplug the router and modem. Then Plug in the modem let it boot up, plug in the router let it boot up then the pcs.
If you need more hook ups if 4 isnt enough yo uneed a switch or access point not another router.
Let me know If this helps and if I can help further.
Joe
Apr 19, 2009 | D-Link DI 514 Wireless Router (DI-514)
Vista desktop won't connect to internet cable modem eithernet
power down cable modem, router, and computer. Connect ethernet cable from modem to router/ and connect ethernet cable from router to PC. Power up cable modem first, after modem shows connectivity, plug in router. After router shows internet connectivity, start computer. Be sure that you LAN card operable
Apr 15, 2009 | Acer Computers & Internet
Router doesnt connect to internet
This sounds like a problem with your DSL modem, not the router. Try unplugging both devices and wait about 10 seconds. Plug in the modem first and wait about 30 seconds (at this point the Internet light should be on). Now plug in the router and wait another 30 seconds. This problem is normally due to the modem not getting sync. I would try plugging your laptop directly into modem if this doesn't work to see if you then have Internet. If not call your ISP.
Feb 14, 2009 | Linksys Wireless-G WRT54G Router
Net gear router won't install properly and will not let me use the internet
You may want to try:
  • If both your router and modem have DHCP features enabled, disable the one in the modem;
  • manually set the Internet/WAN IP add of the router to follow the IP add of the modem;
  • manually set the default gateway of the Internet/WAN side of the router to use the IP add of the modem;
  • set the PCs connected to the router to automatically obtain IP adds.
  • verify that the PCs uses as their default gateway the IP add of the router.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 12, 2008 | NetGear RangeMax WPN824 Router
How to setup an adsl modem and a router
forget the router as it appears that it is messing with the connection
May 13, 2017 | Cnet CNIG914B 4-Port 10/100Mbps Router
Connecting a modem and router to my desktop
When you connect all the devices make sure you reset them all after plugging them together. Also use a different ethernet cord and make sure your plugging the Modem into the WAN port on the router. If your still having same problem just let me know.
May 08, 2008 | Linksys Wireless-G WRT54GS Router...
Server not found} NetGear WGR614 Wireless Router doesn't connect me to the internet.
Dear Loud Nouises,
Your router must be connected properly to the cable modem. This must be to the wan port on the router.
Next, the router must be set-up accordingly to recognize the modem's internet connections. Please ask for the IP address.. and other relevant informations from your internet provider.
Set -up your computer using the internet connections wizard on each of your respective computer.
This should work fine if all connections were correctly configured.
Sidlahora
Nov 27, 2007 | NetGear WGR614 Wireless Router
Connections
YES> If you will install a router into your network, it will share the internet conenction among the two computers. Both wireless and wired. So the connection will be from
Modem ----> Router (wireless/wired capable)   ------> PCs (two Pcs both the desktop and the laptop
and you can also add up another PC if you want to.
Oct 13, 2007 | ASUS WIRELESS ROUTER |WL-520G - RT...
Acer Aspire One Netbook 8.9" Notebook Logo
51 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
