Simulation tests on page 82
Look on page 82 of the service manual. simulation 62 is for hard drive. i ran 2 and 3 and came up OK. should i run 1 to format the hard drive or will that erase everything.
  • 19,396 Answers
You need to format the hd , if you have e7 00 that means no communication to hd, you need to format it and reinstall system. I don't have the whole service manual, on some machine you have a copy of the system stored in rom, so that it will reinstall itself with a service procedure, check the service manual.On other models you need an image disk, which usually is distributed only to authorized service.
Posted on Apr 17, 2008
SAMSUNG HM500JI
Bro, when you see "SMART overall-health self-assessment test result: FAILED!" then this hard drive is either dead or dying. There isn't much you can do other than replace it now.
Oct 16, 2012 | Samsung HM500JI 500 GB SATA Hard Drive
Sharp AR-M550U code:E7-03
The E7-03 error code means the HDD is not properly installed or is dead. You can check the connections on the HDD and the MFP Controll PWB. You can also use Simulation 62-2 and 62-3 to check the read/write of the hard drive.
Sep 07, 2011 | Sharp MX-2300N Color Copier
Could you tell me how can i enter the simulation mode for the kyocera 1815 copier.
I would suggest you check the manual of the kyocera 1815 copier. this should be stated clearly on the user manual. so check the user manual for the information as regards this.
Take care.
Jul 14, 2010 | Kyocera Office Equipment & Supplies
Printer error 07,010.43:722 on phaser 8560 xerox printer
Hi eduardo580:
This your problem.
7,010.43: The printhead is stuck in the tilted position, or is not able to tilt forward to the print position, due to problems.
1 1.
Reboot the printer.
2. Did this correct the problem? Complete. Go to Step 2.
2 1. Do the printhead lock arms rotate correctly? Go to Step 3. Repair/replace
the lock arms.
3 1. Has ink spilled ink around the printhead that
prevents the printhead from moving to its
center position? You should be able to
manually push the printhead right to left.
Clean the printhead area. Go to Step 4.
4 1. Does the X-axis motor drive the printhead to
it’s center position (so it can tilt forward)?
Go to step 5. Troubleshoot the X-axis drive.
5 1. Check the process gearbox for obstructions or damaged.
2. Ensure the gears are correctly aligned and homed.
3. Verify the process shaft and drive module shaft are at their home positions.
4. Did this correct the problem? Complete. Go to Step 6.
6 1. Has ink spilled on the head tilt gear on its
drive train (near left side of the printhead).
Clean the gears. Go to Step 7.
7 1. Use service diagnostics to run the Head Maintenance Wiper Clutch test.
2. Did the test fail?
Replace the wiper drive clutch. Go to Step 8.
8 1. Ensure the wiper is properly aligned.
2. Use service diagnostics to run the Wiper Drive Test.
3. Did the test fail?
Replace the exit module assembly. Go to Step 9.
9 1. Use service diagnostics to run the Load Maintenance Clutch test.
Inspect the maintenance drive system,
replace any defective parts. Go to step 10.
10 1. Verify the headtilt gear will engage. You can
manually set the headtilt gear.
2. Is the gear engaged properly?
Go to Step 11. Set the headtilt gear.
11 1. Use service diagnostics to run the Tilt Axis Drive test.
Replace the process gearbox.
Go to Step12.
12 1. Use service diagnostics to run the Process Motor test.
2. Did the test fail? Replace the process motor.
Hope this helps
Jul 25, 2009 | Xerox Phaser 8500/DN Printer
Error code 07,010.43:59833. Service said I have to replace print head for 900$!
Hi jo47628:
Here is your problem:
1. Reboot the printer.
the lock arms.
Clean the
printhead area.
Go to Step 4.
the X-axis
drive.
or damaged.
homed.
Clean the
gears.
Go to Step 7.
test.
Replace the
wiper drive
clutch.
Go to Step 8.
Drive
Test.
Replace the exit
module
assembly.
Go to Step 9.
Maintenance Clutch
test.
Inspect the
maintenance
drive system,
replace any
defective parts.
1.
gear.
Drive
test.
Replace the
process
gearbox.
Go to Step12.
Motor
test.
Hope this helps
Apr 22, 2009 | Xerox Phaser 8550DP Printer
Error code 07,010,43:13829 xerox c2424
Hi sales1stsupp:
Here is your problem.
7,010.43: The printhead is stuck in the tilted position, or is not tilting properly over
the CAM, due to problems with the process motor gearbox.
1. Reboot the system.
Go to Step 2. Complete.
2 1. Do the printhead lock arms rotate correctly? Go to Step 3. Repair or
replace the lock
arms.
3 1. Is there spilled ink around the printhead? Clean the
printhead area.
Go to Step 4.
or damaged.
homed.
Complete. Go to Step 5.
5 1. Verify the headtilt gear will engage. You can
Go to Step 6. Set the headtilt
gear.
6 1. Use service diagnostics to run the Tilt Axis
Drive
test.
Replace the
process
gearbox.
Go to Step 7.
7 1. Use service diagnostics to run the Process
Motor
test.
Replace the
process motor.
Go to Step 8.
8 1. Use service diagnostics to run the Head
test.
Replace the
wiper drive
clutch.
Go to Step 9.
9 1. Ensure the wiper is properly aligned.
Drive
Test.
Go to Step 10. Replace the
exit module
assembly.
10 1. Use service diagnostics to run the Load
Maintenance Clutch
test.
system, replace any defective
parts
Hope this helps
Apr 22, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Latitude d 600 locks up
Dear we have provid the solutation for best my self
just do it
1.click the start
2.click ran
3. type recent
4.click ok
secon option is use for
1.click the start
2.click ran
3. type temp
4.click ok
this two setps in all file is come to desktop in open the new windows and afrer Remove the all file.
99 % you problem is solve but not solve your problem just install the antivirus program with latest update and your pc or laptop full scan
and remove the all virus ............ok .
Mar 28, 2009 | Dell Latitude D600 Notebook
How to install new hard drive
2 choices for you. Get the external to run the game or 2. Add a larger hdd to the system as a slave drive leaving the smaller drive as the master. If you go the 2nd route just make sure you buy a compatible hdd. Hope this helps & please remember to rate my answer.
Dec 28, 2008 | HP Compaq d530 PC Desktop
8500 PHASER PRINTER ERROR 9,036.44:19335
· 9,036.44 Magenta Ink Stick Count Fault
One of the magenta (red) sticks is broken or stuck not advancing in the ink loader.
I normally take a screw and twist it into the ink sticks and slide them back and out.
More then likely you will find a broken or jammed stik.
Also be sure it is not a phaser 8400 stick at the shape of them are slightly different and will not actuate the sensor.
Here is also a test procedure for the ink loader.
Use this procedure to test if an Ink Out Sensor?s flag works correctly.
1. Remove ink sticks from the ink loader?s channels.
2. Place the printer in Diagnostics Mode by:
Service method
a. Turning on the printer and as XEROX appears on the screen, press and hold the Back and Help button until Beginning Service Mode Initialization appears.
b. Scroll to and execute test Monitor: Sensors
Customer method
a. While error code displayed, press UP arrow and OK key.
b. Scroll to Troubleshooting: Service Tools: Enter Diagnostic Mode. (Printer restarts).
c. Select test 82: Monitor Sensors. Press OK.
d. Scroll to 01: Exit Diagnostics and press OK to return to customer mode.
3. Insert the clean eraser end of a pencil thru the lowermost oval slot. (The eraser end of a pencil closely simulates the bottom rail shape of a Xerox ink stick.)
Slide the pencil down the white channel guide until the sensor is tripped. A sensor change is displayed on the control panel. When the flag is depressed, the front panel will read <color> Ink Present H. When released, the reading will change to L. The test will only display a reading when a sensor change occurs. If a flag is stuck, no sensor reading will be displayed on the front panel.
1. If the sensors are not working properly, follow standard service procedures and replace the ink loader assembly.
2. If the ink out sensors work correctly, identify the ink stick(s) being used in the printer.
Apr 19, 2008 | Xerox Phaser 8500/DN Printer
PHASER 8550DP
Your yellow ink sensor is stuck
Testing the Ink Out Sensors Use this procedure to test if an Ink Out Sensor?s flag works correctly.
Service method
Customer method
Slide the pencil down the white channel guide until the sensor is tripped. A sensor change is displayed on the control panel. When the flag is depressed, the front panel will read <color> Ink Present H. When released, the reading will change to L. The test will only display a reading when a sensor change occurs. If a flag is stuck, no sensor reading will be displayed on the front panel. If it doesnt change states you need to replace the ink loader
Mar 08, 2008 | Xerox Phaser 8550DP Printer
100 people viewed this question
jasbo
jasbo
