Question about Little Giant 2 Md 1/30 Hp, 30 Lpm, 230V Inline Magnetic Drive Pump, No Power Cord
New pump lil gaint model 2 mdqx sc do not under stand why its not pumping water salt water tank 100gl builtin over flo bx with sump j
  • 487 Answers
Have you tried priming the pump, i.e fill with water from the top out let pipe
Posted on Jul 04, 2010
FLO light stays lit. Good water flo through heat pump.
check pressure switch if heater issue if salt issue check sensor on salt unit
May 22, 2016 | Pool & Spa
I just installed new water pressure tank,it builds pressure to max then water runs low on pressure till pump kicks back on.whats wrong
Have to set the pressure switch
(instructions are under the cover)
65 # cut off
42 # cut in
Should install a new switch every ten years
& a new check valve before the tank & manifold
assy every 20 years
Oct 25, 2014 | Water Worker 44 Gallon Vertical Stand...
Who makes the motors for little giant pumps 3-MDQX-SC
Try taking it to a Grainger's store or go online to Graingers.com. There are usually enough numbers on the motor to find a match if there is one available.
Oct 21, 2014 | Little Giant 581507 3-MDQX-SC Magnetic...
Culligan water softener manual
You are likely using a rock salt and what you are seeing is a build up of dirt and fine sand because rock salt isn't clean... it's got rocks in it. Clean your tank out and rinse it thoroughly with a hose. Be sure to clean out your 3" tube (brine well) and under the salt platform if you have one. Start with a clean salt like System Saver II or Crystal Plus. Never fill your salt tank over half full. Always let your salt be used down to the water level. IF the salt at the water level is soft and pasty don't add more; tip the salt tank until the salt is raised along one side or corner to above the water level when you stand the tank up carefully. This will allow all the water in the tank to become brine (saturated solution).
IF you are using potassium instead of salt, the brown is a natural component. Don't worry about it although it never hurts to clean your brine tank yearly.
Aug 04, 2014 | Water Dispensing & Filtration
Pumps manuals
if calcium deposits seals leaking replace pump
Sep 29, 2013 | Hayward Max - Flo 1 1/2 - Hp In Ground...
I have a culligan softminder twin system that is releasing salt and water onto the floor also the sytem does not seem to be cycling thru correctly and the water is not coming out pure it is discolored and...
Check the salt tank too see if it is overflowing. There could also be a crack in the bottom of the brine tank causing it to leak. You need to determine where the leak is coming from. Many times water is leaking from the valve, running down the tank and collecting under/around the salt tank. As far as not cycling make sure the meter cable is plugged in, power to unit, etc. The valve may not be switching tanks, there can be many causes for this. Bottom line is By-Pass the softener until a service tech can come out. These Culligan twin tank systems (9000,9100,8500, Twin-Flo) are actually fleck valves so any water treatment dealer that sells/services Fleck valves can repair this system.
RJ
Nov 30, 2009 | Culligan Sediment Water Filter
Hi, I have an inline aquarium pump made by Little Giant (Model 3-MDQX-SC that stopped working after I turned it off. The problem came about after I turned it and I could NOT restart. The pump is currently...
sounds like you need to get that pump off, take it apart and give it a good cleaning in vinegar. I have 135gal reef tank and do mine about once every 6 mos. You need to have cut off valves on each side so you can take it off when you need to. Go to 3reef.com. They can answer any question you've got!
Apr 18, 2009 | Little Giant - 3-MDQX-SC Inline Pump
Little Giant 2 Md 1/30 Hp, 30 Lpm, 230V Inline Magnetic Drive Pump, No Power Cord  Logo
114 people viewed this question
Top Little Giant Plumbing Experts
Mack Baxter
JOHN LAPIER
Gary Nitowski
Are you a Little Giant Plumbing Expert? Answer questions, earn points and help others
