Question about Dell Dimension C521 PC Desktop
Ethernet driver problem - Dell Dimension C521 PC Desktop
  • Chris Hingee
    Chris Hingee Jul 04, 2010
    What is the exact nature of your problem? Have you downloaded the correct LAN driver from the Dell WEB site?
Hello today is 7-22 and I as on a Dell Dimension C521 running Vista Basic AMD 64 and was having a problem with a no driver install in the device manager for the Ethernet Controller. I took out the net card and found the model # on it. mines was a Linksys Support
ethernet driver problem - l,81.png EtherFast 10/100 LAN Card (LNE100TX)I download three drivers one from Linksys/Cisco website:
http://homesupport.cisco.com/en-us/wireless/lbc/LNE100TX/download
and two from this opendrives.com site:
http://www.opendrivers.com/driver/214850/linksys-lne100tx-version-5-etherfast-10-100-lan-card-driver-free-download.html
http://www.opendrivers.com/driver/284251/linksys-lne100tx-network-driver-5.12-windows-98-me-nt4-2000-xp-linux-free-download.html
They all are zip files. I unzip them in the same folder and went back to the device manager and told it to look in the folder and it found it and I am up and running able to connect to the internet.
Posted on Jul 22, 2010
  • 487 Answers
Go to Del website and down load the driver
Posted on Jul 04, 2010
Driver for ethernet
http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html
Realtek RTL8139 Family PCI Fast Ethernet NIC
http://download.cnet.com/Realtek-RTL8168-8111-PCI-E-Gigabit-Ethernet-NIC/3000-2112_4-99235.html
Realtek RTL8168/8111 PCI-E Gigabit Ethernet NIC: The Realtek RTL8168 Gigabit Ethernet controller combines a triple-speed IEEE 802.3 compliant Media Access
http://download.cnet.com/Realtek-RTL-Gigabit-and-Fast-Ethernet-NIC-Driver-Windows-2000-XP-XP-64-bit/3000-2112_4-10278840.html
Drivers for RTL8100B(L)/RTL8100C(L)/RTL8101L/RTL8139C(L), RTL8139C(L)+/RTL8139D(L)/RTL8100(L), RTL8130/RTL8139B(L)series. Windows
if these driver packages aren't right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
you might have to search/try a few times to get it right
IE: motherboard name ethernet drivers or lan drivers
hope this helps
Sep 18, 2012 | Dell J0592 / 0J0592 DIMENSION 4550...
Need ethernet driver for emachine t3624 where can i get it from
- I wen to e-machines website and found out that there are no available Ethernet driver
- Since the chipset drivers are from intel more than likely that the ethernet drivers are also from Intel
- For you to be specific on what Ethernet driver it is you can check on
1. device manager -> left click on the plus/triangle sign next to other devices
2. right click on ethernet -> choose properties
3. from the properties window --> click on the details tab
4. there should be a long alpha numeric number starts with PCI......
5. google that up for you to find out what specific ethernet driver it is
- If the ethernet driver is from Intel here is the link:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=%22PL2KXPM.EXE%22
-- Cheers Don' t forget to say thanks
May 17, 2011 | E-Machines T3624 PC Desktop
I loaded xp pro but my ethernet port is not active. Do I need to load ethernet drivers?
That means that the operating system doesn't have a database for your Ethernet device. You have to have the driver that came together with your PC and you should find the driver for your Ethernet device using that.
Sep 13, 2010 | IBM ThinkPad T42 Notebook
Lan terminal not working
first check for all the drivers in the device manager.... if every thing is perfect in driver side, then check if the ethernet/ lan is enabled....
then check is the light in the ethernet adapter is lit, when you plug any ethenet cable in it... still if it is not working, then finally try to update the latest driver for the ethernet controller.... if nothing works, then buy an pci ethernet card and use it..... you can also buy external cards like usb to ethernet converter... even belkin manufactures usb to ethernet controller....
May 09, 2010 | ASUS P4P800 SE (890552603657) Motherboard
How i istall ethernet driver from internet
If you have no internet because the ethernet controller was not installed, you will need to download the ethernet drivers from another computer.
To do this, you will need either the motherboard model or the ethernet controller model. Search google for your motherboard model, and then on the drivers page, find "LAN drivers". Download the drivers, save them to a usb and transfer and install them to your pc.
Feb 01, 2010 | Broadcom BCM5721 NetXtreme Ethernet...
My Ethernet card doesn't work on my n845wn Intel
It's possible the drivers are not installed.. To check if drivers are properly installed for the Ethernet card, if you have win XP
* go to Start>Control Panel>System> click on Hardware tab, then Device Manager
- once you're on Device Manager, look for network adapter, you should see something like "Via Rhine II Fast Ethernet Adapter", this is just an example, you may have a different brand of Ethernet adapter
- if you can see the Ethernet Adapter and it has a green icon beside it, it should be working fine, you can also double click on it, to view the Status
- if you don't see the Ethernet Adapter on the list, look under the section "Other Devices", if you see an "Ethernet Controller" on the list with a yellow exclamation point, it means the drivers for the Ethernet Adapter were not installed, which means the drivers has to be re-installed
- you need the manufacturer cd for the drivers
*Now if there's no "Ethernet Controller" on Other Devices section, it's possible the Ethernet card is not being detected by the computer
- you may have to unplug the Ethernet card physically from the computer (computer must be completely turned off) then try to insert the Ethernet card again and boot up the computer, if the computer detects the Ethernet card, you need to install the drivers
- If the computer doesn't detect the Ethernet card, most probably it's busted. You may have to replace it.. You can also try to install the Ethernet card on a different computer just to check if it's really the Ethernet card or the motherboard that's the problem..
May 10, 2009 | Intel Desktop Board D845WN Motherboard
Ethernet controller has a yellow ! makr after it
reinstall the ethernet adapter driver from the dell drivers and utilities and extract the necessary ethernet driver under network driver
Apr 04, 2009 | Dell Latitude C610 Notebook
Pleas i m not getting the ethernet controller
You need to re-install your Ethernet driver.If you have Driver CD with you then first uninstall the Ethernet driver from device manager and install the Ethernet driver from you driver CD.
If you don't have driver CD with you then You can download ethernet driver by Clicking here.
Thanks
Mar 04, 2009 | HP Compaq nx6115 Notebook
Ethernet drivers
Windows XP Driver
Windows Vista Driver
These updates should sort out ethernet problems.
If these don't work or you have Wireless LAN, here is the Wireless LAN driver.
Oct 11, 2008 | Compaq Computers & Internet
Dell Dimension C521 PC Desktop Logo
235 people viewed this question
Alun Cox
