Question about Saws
I need to change the blade on a Ryobi TS 1300 table top mitre saw. I am needing some directions.
  • 8,197 Answers
You can get the manual on the link below. on page 13 will tell tell you how to change blade.
http://dl.owneriq.net/d/d088bccc-fead-4473-8063-ddd58e6e961b.pdf
Good Luck and please rate 4 thumbs up for the free answer.
Posted on Jul 04, 2010
How to lower toptable of a ryobi table mitre saw tms-305
http://ryobi.co.za/product/table-and-mitre-saw-combination-1800w-tms-305/
this saw has a 2 inch capacity. if you have say a 3 inch piece you use 2 passes of 1-1/2 each
regards
sir dana
Apr 25, 2017 | Ryobi Saws
Ryobi mitre saw jamming when cutting
There's a normal adjustment process of squaring the blade to the table, page 19 of your manual. If the blade is not square to the table then it will bind. Here's the link for the manual, see page 19.
http://manuals.ryobitools.com/system/files/400/original/TS1342_942_eng.pdf?2011
Dec 21, 2013 | Ryobi ZRTS1342L Factory-Reconditioned 14...
BLADE ALIGNMENT
bent blade...?
Sep 10, 2012 | Cars & Trucks
To remove the blade, is the nut right or left-hand threads? Is there a blade lock?
With any circular saw, table saw, metal cut off saw, mitre saw etc the nut always tightens against the direction of rotation and loosens the opposite way
Nov 12, 2010 | Delta Saws
How to change mitre saw blades
you need to remove the "throat" plate and raise the blade fully. UNPLUG SAW FIRST there are 2 wrenches on the side one for the hex nut and the other for the arbor, the threads are standard. let me know if you need more assistance
Aug 25, 2010 | Dewalt DW744S 10" Portable Table Saw with...
How to change blades on an old Ryobi 380mm cut off mitre saw?
most of these saws have a push/lock tab on back side of motor housing that pins the shaft for blade change. if you cant find, use a 4/4 wood block to wedge old blade so you can loosen bolt.. hope this helps....chris
Jun 18, 2009 | Saws
How do I replace my mitre saw blade?
It should still easily fit a 5/8" blade. The arbor shape shouldnt have any effect on the type of arbor hole needed on the saw blade (only round arbor holes are made on saw blades. You will probably find the arbor securing nut has a shape that fits into the flat gaps between the saw blade and the arbor when fixed. So grab a 5/8" round arbor saw blade and give it a go. It should work fine.
It is the arbor nut that secures the blade onto the arbor via friction which holds it on.
Please rate this solution on FixYa!
May 29, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Changing the saw blade on a Ryobi Mitre saw
There may be a push button type blade lock, and on many of these saws the retaining bolt for the blade is backwards threads, e.i., looking at the top of blade retaining bolt, turn it clockwise to loosen. This would normally tighten, but in the case of many of these saws, it loosens it.
Jan 04, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Saws Logo
355 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
