Question about Compaq Armada 1500C Notebook
Furnace Filter I have a Armstrong Furnace Model # 26hwc122-1 I don't know or can't find the proper filter for it, which one will fit the furnace?
  • Compaq Master
  • 5,568 Answers
Your chances of getting an answer here obviously weren't good.
If you still haven't located and replaced your filter, post the same question to Armstrong here:
http://www.armstrongair.com/contact.php
Posted on Aug 23, 2008
Where is the filter located in the armstrong air ultra v advantage 93?
The Filter will be located between the air return and the blower box. Sometimes there is a filter "rack" added by the installer on the outside of the furnace - it will be located between the blower box (lower part of the furnace where the blower is located) and the air return duct - Locate the filter rack and remove the access cover, slide out the old filter and slide in the new one - Note that filters are "directional" meaning they are designed for air flow in one direction only (look for the air-flow orientation marked on edges of the filter) replace the access cover. If you do not see the filter rack on the outside of the furnace, it may have an internal filter rack (inside the blower box)
To change an internal filter - Remove the lower front cover of the furnace, the filter will be held flat against the return inlet by some sort of retainer - remove and replace the filter with the same size and type - be mindful of the air-flow orientation of the filter (air-flow indication arrows should point toward the blower). Replace the retainer and cover(s).
Sep 13, 2014 | Heating & Cooling
I have an Armstrong SX Ultra 90 propane gas furnace that the fan motor will not shut off ,the thermostat is on auto.
Hit the side of the furnace. Some times there's a sensor inside that gets locked up from a dirty filter.
Oct 19, 2013 | Emerson Lennox Ducane Armstrong Furnace...
Heater not working properly we put on heat it comes up cooler what I have 2 do
This worked for me try and reset your furnace while you're at it change the filter never hurts a furnace in need. My furnace has a switch on/off like a light switch externally however some don't if you have an older furnace you may have to manually light your furnace it would help if you listed your furnace model number. Try and find your furnace owners manual if you don't have it look online or contact company who build it. Also some states in the us don't run gas to homes until a certain time of year. I live in Northern Minnesota so its year round here just wondering if this also could be an issue.
Oct 17, 2012 | Heating & Cooling
I have 1990 Armstrong gas furnace Ultra III 80, Model EG6G75dc8-4 .\r\nWhen I turn thermostat up , furnace comes on, burners come on, motor that I believe turns blower turns on but i AM NOT GETTING AIR...
have you checked your filter yet? the other thing to check is open the fan door and jumper the door switch,if there is one, and turn the furnace on. is the fan blowing air now?
Mar 22, 2011 | Heating & Cooling
I have a armstrong gas furnace and I would like a wiring diagram for it it is a model mg73140
http://www.armstrongair.com/armstrong-links/
from here select the particular furnace that you have this is the only resource the is avail. due to the furnace being a Lennox made furnace
Mar 07, 2011 | Heating & Cooling
Armstrong furnace G1D91AU075D12B shuts off before thermostat setpoint ex. if thermostat is set to 70, furnace shuts off at 65 you can then turn stat off and back on and unit will start up again. since...
If your heat anticipator in the thermostat is bad or set at the wrong amperage, it could do just as you describe. If the air filter is dirty or the ducts are restricted, the furnace could shut down on high limit. I would check the air filter and replace if necessary. Make sure all registers are fully open and last, change the thermostat.
Jan 08, 2011 | Heating & Cooling
We have an Armstrong Ultra SX 80 furnace. I can't seem to find the filter on it. Does it take filters and if so, where should they be installed?
The filters should be installed either in the return air vent or on the return air side of the furnace.
heatman101
Sep 26, 2010 | Heating & Cooling
Gas Armstrong Ultra V Tech 91-Is green light supposed to flash?
Installed a new filter and furnace is running great now. The old filter was not that old, but we have been doing some remodeling and I figure that is what clogged it so fast.
Jan 10, 2010 | Armstrong H 67 1PH Bf In Line Circulator...
I have a intertherm furnace and need to know how to tell the proper filter size this is a mobile home
The best thing to do is buy a washable horsehair filter from home depot and cut it to fit. They are green in color and you cut any size you want. They slide in the door of a gas furnace or along each side of the A coil in an electric furnace. That is your best bet. Most of the time the furnaces comes witha washable filter and it is thrown away after afeew times. Rus
Dec 06, 2009 | Refrigerators
Can't find where the filters go on the Ruud, Zephyr model furnace.
Usually a Filter rack is installe don the outside of the furnace for easy access....if this is not the case , turn off the power and carefully remove the bottom panel of the furnace (The top may have to be removed first)....The edges are sharp so use gloves....the filter should then be immediately on the inside left or right side of the furnace depending on which side the return air is on....if no filter is present do you have an Electronic air Cleaner???? In that case no other filter is required...if all else fails and the furnace is under warranty call the Installers back
Oct 25, 2009 | Heating & Cooling
Compaq Armada 1500C Notebook Logo
134 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
