Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Hi I have a F&P iw811. When you turn it on the bowl just spins slowly and it wont take in any water. Any ideas.
  • johnleonie Jul 07, 2010
    I haven't heard back from the first expert. The main problem is that the bowl spins slowly without taking water for about 15 min. It then beeps continously and shows error 37
    President:
  • 1,554 Answers
Fault code 37 is Pump Blocked Error and is indicated by flashing of the third Long Wash LED, first Rinse LED, and the Spin LED. It means the the water level reading from the pressure sensor has not changed for over 3 minutes.
Unplug the machine then remove the 2 screws from the rear of the console then raise the console for access to the Motor Controller Module. Disconnect the pressure sensor hose from the Motor Controller Module then plug and start the machine. Check the pressure sensor hose for blockage or kinks if the machine fills with the pressure sensor hose removed. Otherwise, check to make sure that the water inlet valves are working.
The water inlet valves can be checked for proper operation by connecting the valve solenoid coils to a 24 VDC supply. The valves should activate; otherwise they are not working and need replacing. If the valves are working and the washer does not fill with the pressure sensor hose removed, the issue is within the Motor Controller Module and it needs to be replaced for the machine to work again.
Posted on Jul 07, 2010
  • Jahn27
    Jahn27 Jul 07, 2010
    Feel free to update us about the development of the
    troubleshooting/repair. Please accept and rate the provided
    advice/solution that helped you address the problem or at least gave you
    the right insights on what the problem is. Failure to do so will
    automatically give credit to the first advice/solution no matter how
    inappropriate or not helpful it is. Accepting and rating a solution does not stop you from posting clarifications
    or follow-up questions. You may keep posting as long as you need
    further assistance regarding the issue.
    Brigadier General:
  • 3,917 Answers
Hi
First pull the washing machine out [ What's the best way to pull a washing machine out? Turn off the taps supplying the washing machine. Unscrew the fill hose(s) (Have a bucket or bowl and towel ready, there may be a spurt of water at first due to the pressure in the hose)If you get a spray of water coming out that lasts longer than a second or so the tap may not be actually turned off properly. Hold the hose over a bowl or bucket and switch the tap back on to see if there is a decent supply of water coming through the hose.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 04, 2010
  • johnleonie Jul 04, 2010
    I have tried your suggestion and water supply from the taps is fine. If I leave the machine on for a while it will eventually start beeping continously and come up with error message 37
    I am still waiting for further help
Hi, My Fisher & Paykel GW612 washing machine is not spinning, just thumping back & forward, error code 40 on the lights tells Me to carry out a clutch disassembly procedure any help please !!!
Inner spin bowl rises up when water level is high & disengages a clutch gear. When water drains out bowl settles back down and gear engages. Error 40 is saying that the gear has not locked in place and engaged. Remove lid, take out agitator. Under agitator is a cap held in place with 4 screws. Take out screws (do not drop them down through the slots in the bowl) Take off cap & gear underneath will slide up & off the shaft (gear will be tight to pull up due to soap build up.) Inspect gear for damage & clean out any dirt or obstruction. Re assemble and try wash cycle. If you still get the same fault you may have a faulty control board.
Jul 07, 2017 | Fisher and Paykel Washing Machines
My Beko WM 8127W is stuck on a program and i can not cancel it out it wont spin or empty the water out or move the clothes is still in it any help plz .
Check your pump down at the bottom of the machine take the bottom plinth off the plastic that runs along the bottom of the machine once off on the right hand side you will see your pump you will need to undo the black screw and get your self a towel and a small and big bowl there will be a lot of water so when you have took the screw out start turning the pump cap very slowly and when you have filled the small bowl close it and keep repeating it till all water is gone then take it right out if its stuck then pull it clean it out and put back together don't for get to turn your machine off be for doing any thing ok hope i have helped if after you have done the pump and the machine still do the same thing then its programmer ok
Nov 03, 2012 | Beko Washing Machines
Water in camera wont turn on
If the camera went into the water and was pulled out nearly as fast as it went in, you may have got it out before water bathed the interior workings of the camera and lens.
Place the affected parts in a cloth bag - a pillow case will work nicely. Gate a large bowl and fill it with uncooked rice. Place the pillowcase with the camera into the bowl and completely cover with the rice so that there's at least an inch or two surrounding it. Place the bowl & camera in a dry location for 24 - 48 hours.
The dry, uncooked rice acts as a desiccant and will wick water and moisture out of the camera. The longer the camera was underwater, the less likely this method will work. If the camera fell into seawater or other saltwater solution, this will probably not work - or not work for very long. This is because salt is a corrosive. After the water is evaporated away, the trace amounts of minerals and in this case, large amount of salt, are left behind as deposits. The mineral deposits will not usually affect electronics - but can cause sticking or rubbing of close tolerance mechanical moving parts like those found in cameras and lenses. The salt on the other hand, is much more sinister. It will slowly eat the fine copper conductors on printed circuit boards, etc. and eventually cause the camera to fail.
I hope this helps & good luck!
Jan 10, 2012 | Canon EOS 600D Rebel T3i Digital Camera
Why does my sunbean mixmaster bowl don't spin?
the spinning plate under the bowl does not have any power to spin the bowl; it only aks as a "lazy susan" carousel that allows the bowl to turn from the movement of the material being wipped in the bowl.
the beaters are purposely off-center of the bowl in ordwer to create a dragging motion of the material in the bowl, thus pulling (that is, spinning) the bowl slowly. If the beaters are not off to the side of the bowl, you will not get the pulling/spinning motion. Also, if the plate under the bowl does not move very easily, then the bowl will not spin. You may have to remove the spin plate and clean the center pivot for the plate to move freely. Good Luck, Macgivor.
Nov 27, 2010 | Sunbeam 2346 Heritage MixMaster Series...
Just hooked up new pressure asist tank & bowl,turned on water to it,and it want flush.what i mean about want flush, is it will flush but water does'nt go down,as if it's not staying open long enough.
Sounds like you have a clogged drainline or vent-stack. Fill a large bucket with about three gallons of water and dump it quickly into the bowl. If the drainline/vent is clear, the toilet will "flush" like a gravity toilet and the water will drain from the bowl almost as fast as you can pour it in.
If the water level in the bowl slowly rises (as if it's about to overflow) and then slowly drains, you have a clog somewhere.
All toilets, regardless of their flushing mechanism, require a clear, unoibstructed drain/waste/vent system to extract waste.
If the toilet "flushes" with the bucket of water, you may want to call Flushmate tech support (the number is on top of the tank) or check out the installation and troubleshooting videos at howto.flushmate.com.
Hope this helps.
Aug 18, 2010 | Sloan M-101526-F42 Flushmate?® Complete...
Gw 612 washes ,drains wont spin fault comes up as on off off off on
Hi just read your posting.Now the problem you might have, and I have had before, is the motor is not turning the bowl far enough when it is starting to spin and therefore the machine thinks the bowl is not turning.To get your machine spinning 1st undo the 2 screws under the lid so you can lift the hob up to see the bowl.Select a spin cycle and hit start while you are holding the hob up enough to see the bowl.The reason for lifting the hob instead of the lid to see the bowl is if you lifted the lid the machine would not work because of the lid switch.Now when you are holding the hob up to see the bowl make sure the lid is closed so the machine will work.Now once you have started the spin cycle you will see the bowl turning one way then reverse and turn the other way.While you are holding the hob up when the bowl turns in 1 direction help turn the bowl in that same direction with your hand.Once the bowl reverses help turning it in that direction also.This will make the machine register that the bowl is loose enough and will kick to spin.Once it is spinning let it spin for the cycle and you should be fine.Please reply for further help if needed,Good luck
Jun 16, 2010 | Washing Machines
Hey, my f&p smart drive 9 excellence washing machine does not start wash cycle after entering water level etc.... upon pressing the start button nothing is happening any thoughts?
Is the bowl turning slowly when you press start.if it does then you may have a faulty inlet valve,make sure taps are turned on.try advancing the machine to spin cycle,see if it will do any other things such as spin & drain.if it does then probably just not letting in water & inlet valve needs replacing..try filling machine by hand & see if it washes.
May 24, 2010 | Fisher and Paykel (IWL12)
Bowl keeps slowly filling with water when turned off.
I think your water valve is bad , change it
Aug 12, 2009 | Washing Machines
Washing Machines Logo
57 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
