Question about Troy-Bilt Pony Garden Tiller
Tansmission won't lock into drive. 1979 Pony
Tansmission won't lock into drive. I have to hold the wheel drive lever.
As long as I'm holing the lever in the drive position the wheels turn. I don't hear any unusual noises such as grinding gears.
    Problem Solver:
  • 9 Answers
Sounds like your fork lever/ shift rod is bent and flexing
Posted on Jul 09, 2010
Free wehee lever repair
The free-wheel lever actually disengages the automatic electric brake so that the chair can be pushed. The brake is what holds the lever in either neutral or drive. Could be that your electric brake is shot.
Apr 07, 2014 | Shoprider Wizz Power Chair 888WNL by
Passenger seat won't lock in place
The adjusting lever for seat position is not locking into place. On the bottom of seat are runners on each side with holes in them that the adjusting lever tabs will lock in and hold seat in place. The seat slides on the runners if those tabs are raised. There is also a connecting wire or rod from the lever to the other side of seat so when lever is pulled up, tabs on both runners are raised for seat to slide. Something is keeping the tabs from locking into the holes on the runners in your car. Maybe the adjusting lever is broken somewhere, or the wire/rod came loose, or the lever is just dry and sticky and needs a shot of WD40 to loosen it up. If you can't see it and fix it with seat in place, then pull the seat back off for the repair. Good luck. Post back if my explanatiopn is not clear or you still need help.
Jun 19, 2012 | 1998 BMW Z3 Roadster
Reverse belt or transmission won't lock into place
The reverse on the Pony tiller will not lock. You pull back on the reverse lever and as soon as you let go it will stop. This is normal operation for reverse.
Frank
Aug 30, 2010 | Troy-Bilt Pony Garden Tiller
Pony wont stay in drive
I would check and see if your cable is binding. If it is binding you may not be getting it engaged all the way. Also you have to rock the tiller back and forth a little while you are trying to engage it or sometimes it will not engage all the way and then will pop out. Also check that the arm the cable connects to at the transmission is free to move in and out of gear. Sometimes those get coroded up. Just spray some penetrating oil on it,the cable and lthe lever. As far as I know there is not a tension adjustment on the cable.
Good Luck!
Sep 08, 2009 | Troy-Bilt Pony Garden Tiller
Troy Bilt Pony s/n P92695 5Hp Briggs. Drive wheels won't stay engaged. Lever jumps out. Can hold lever in with not much effort and will stay engaged. Any adjustments?
yes there is an adjustment. follow your shift lever down and you will find a block of iron with 2 bolts holding it. you will also see ond the lever itself a spring loaded pin.most of the time this pin gets gummed up and does not engage the block completely.clean and ensure the pin moves freely. if this does not solve the prob then the block can be moved up or down by loosening the bolts.
Sep 06, 2009 | Troy-Bilt Pony Garden Tiller
How do i tighten up the sterring wheel?
this is probely a tilt wheel alot to it really remove steering wheel and lock plate(buy these tools or u will be sorry steerwheel remover,lock plate remover.) unscrew tilt wheel lever combination switch lever-pull out on to remove ,remove scew retaining turn signal bracket to lever,all screws holding down turn signal assembley make sure u tilt colum up .round silver button looking thing with square hole ,use medium philups screwdriver and put in hole and press in and turn it will release and come outward this is the spring for tilt wheel 5/16 head bolt remove this is a pin to hol lock cylinder in pull lock cylinder out ther are bearings in the shaft, hard to replace and to find anywhere,carefull,,,each side of colum ther is a funny looking flat round circle, they have a theaded hole inthem u will need a speasal tool for this aalso,,,parts store pivot dowle removal tool,,, this housing can come off now there are 3 screws to tightin up u will see them
Jun 30, 2009 | 1985 Pontiac Bonneville
How to take motor off frame troy built tiller
The easiest way is to first remove the drive belt , then on both sides you will see two bolts with locking nuts on them where the engagement lever raises the motor to tighten the belt. Back these bolts out , then have someone hold the motor while you work the rod out on each side that the motor slides up and down on. Oh if you have a bumper there are two bolts in the top of each one holding the bumper on to take out first. Hope this helps.
May 14, 2009 | Troy-Bilt Pony Garden Tiller
Stuck in 4 wheel high lock
I had the same problem just yesterday. My shifter lever for the 4x was just flopping around. I crawled under the driver side right behind the driver front tire and there was a lever hanging down with an "L" shape on the end of it and a groove cut all the way around it. That lever is the end of that shifter lever inside of your vehicle. it attaches to another lever "a flat bar with a hole drilled into it and mounted to the side of the transmission. Don't attempt to move the flat bar but do reposition the lever inside the vehicle so that you can put the "L" shaped lever back into the hole of the flat bar. There is supposed to be what they call an "E" ring on the end of this "L" shaped lever that slips over the shaft in that Groove I was telling about. it snaps into place and holds the two levers together. It's missing so go to auto parts store and get a new one. I'm headed there today. Shift your car into 2wd and drive. Then replace the "E" ring that's missing and you're good to go.
Good luck
Apr 29, 2009 | 2000 Dodge Durango
I need a schematic for the rear brakes on an F150 super cab with 4.6L automatic trans 4wheel drive
Drum, Rear Brake System Standard Rear Brake
Item Part Number Description 1 2069 Brake Shoe Hold-Down Spring Pin 2 — Rear Wheel Cylinder Retaining Bolt (2 Req'd) 3 — Washer (2 Req'd) 4 — Anchor Pin (Part of 2211) 5 — Wheel Cylinder 6 2028 Brake Shoe Anchor Pin Guide Plate 7 2A637 Parking Brake Lever 8 2296 Brake Shoe Retracting Spring (Short) 9 2296 Brake Shoe Retracting Spring (Long) 10 2200 Rear Brake Shoe and Lining (Secondary) 11 — Washer 12 2106 Parking Brake Lever Pin Retainer 13 — Brake Shoe Adjusting Lever Cable Guide 14 2A642 Primary Brake Shoe Parking Brake Lever Link 15 2A601 Parking Brake Link Spring 16 2068 Brake Shoe Hold-Down Spring 17 2A176 Brake Shoe Adjusting Lever 18 2048 Brake Shoe Adjusting Screw Socket 19 2047 Brake Shoe Adjusting Screw Nut 20 2041 Brake Adjusting Screw 21 2049 Brake Shoe Adjusting Screw Spring 22 2200 Rear Brake Shoe and Lining (Primary) 23 2A178 Brake Shoe Adjusting Lever Cable 24 2211 Brake Backing Plate
Heavy Duty Rear Brake
Item Part Number Description 1 — Rear Wheel Cylinder Retaining Bolt 2 00538 Lock Nut 3 2212 Rear Brake Backing Plate 4 2262 Rear Wheel Cylinder 5 2A642 Primary Brake Shoe Parking Brake Lever Link 6 2A601 Parking Brake Link Spring 7 2A637 Parking Brake Lever 8 2106 Parking Brake Lever Pin Retainer 9 — Parking Brake Lever Bolt 10 — Secondary Shoe Assembly 11 2A179 Brake Shoe Adjusting Lever Cable Guide 12 2068 Brake Shoe Hold-Down Spring 13 — Adjusting Lever Pin 14 — Adjusting Lever Return Spring 15 2A176 Brake Shoe Adjusting Lever 16 2047 Brake Shoe Adjusting Screw Nut 17 2049 Brake Shoe Adjusting Screw Spring 18 2041 Brake Adjuster Screw 19 — Primary Shoe Assembly 20 2068 Brake Shoe Hold-Down Spring 21 2200 Rear Brake Shoe and Lining 22 2035 Brake Shoe Retracting Spring 23 2A178 Brake Shoe Adjusting Lever Cable 24 2092 Brake Adjusting Hole Cover 25 2069 Brake Shoe Hold-Down Spring Pin
The rear drum brakes:
  • Have internal shoes that expand against the brake drum (1126).
  • Are a single-anchor type.
  • Are actuated by one rear wheel cylinder (2262).
  • Have two pistons in the rear wheel cylinder (2261). One exerts force against the upper end of the primary shoe; the other exerts force against the upper end of the secondary shoe.
  • Adjust rear brake shoes and linings (2200) automatically.
  • Need manual brake adjustment if the adjusters are not operating properly or after the rear brake shoes and linings have been replaced.
When the brake pedal is applied, hydraulic fluid pressure forces the pistons in the rear wheel cylinder outward, moving the rear brake shoes and linings against the brake drum.
The rear drum brake system includes the parking brake mechanism. Refer to Section 206-05 .
Apr 04, 2009 | 1997 Ford F150 Regular Cab
Troy-Bilt Pony Garden Tiller Logo
269 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
