Question about SanDisk Sansa Clip MP3 Player
My sandisk sansa clip wont turn on at all ive tried to reset it by holding down the power button but it still wont work i know that it is fully charged
    President:
  • SanDisk Expert
  • 650 Answers
Remove the back and check and see if the battery isn't fully connected
Posted on Jul 04, 2010
I have a sansa clip 4gb and im about to throw it against a wall and ive had it since chritmas and idk how to fix it help me please.
Not sure what is wrong. but try to reset it first. to reset your player, Press and hold the Power/Menu button for approximately 20 seconds. Release the Power/Menu button. Press the Power/Menu button again to turn on the player. If this does not fix it. Go to >> Sandisk support
Sep 27, 2011 | SanDisk Sansa Clip MP3 Player
My sansa clip randomly shut off and now wont turn back on. ive tried to charge it and stuff like that but still nothing. what should i do?
Try this.
Hold down the Power/Reset button for about 15 seconds to perform a normal reset.
If you would like to reset the device to it's original factory settings, you can do so by selecting Settings from the Main Menu, and selecting Reset All.
Dec 02, 2010 | SanDisk Sansa Clip MP3 Player
My sandisk sansa clip 1gb wont turn on
Make sure the player is fully charged. 1. Connect the player to the PC. 2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode, 1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary.
To reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Here is how to get to the battery, 1. Press the battery compartment in while sliding to the right. 2. Remove old battery. 3. Insert new battery or reset the old battery. 4. Close the battery compartment. Then try and see if it will come on with out the battery hooked to your computer. 1. Remove the battery. 2. Connect the player to the PC to verify if it turns on. 3. Re-seat the battery to ensure proper connection. 4. Verify if the player turns on.
Jan 29, 2010 | SanDisk Sansa Clip MP3 Player
I turned the mp3 player on and everything froze and it wont even shut off.
Reset
If the Sansa
Clip player freezes up, slide the Power Button up and hold it for
approximately 15 seconds. This is like a power down of the device. Once you
perform the reset, the adjustments you made during the last operation will be gone.
www.sandisk.com
get the manual for your player.
Aug 26, 2009 | SanDisk Sansa Clip MP3 Player
When i turn it on it only whows the sandisk sing
You can try to reset your device...
To reset sansa
Press to power on/off, enter menu, or hold 15
seconds to reset your Sansa.
Or-To reset the sansa = Hold down power button for 20 seconds.
if that doesnt work, let me know
Thank you
Belbwa
Feb 24, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
It wont come on
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Dec 29, 2008 | SanDisk Sansa Clip MP3 Player
Wont play.. stays paused.
Turn off. Put in Hold mode. Hold down middle button. Plug in while still holding middle button. Now reformat the Clip and update the drivers.
Dec 26, 2008 | SanDisk Sansa Clip MP3 Player
Please help!!!
1 Other User Has The Same Problem Posted by DEEDEE0809 on May 06, 2008I HAVE A SANSA SANDISK 1GB AND I HAVE FULLY CHARGED
IT AND I WOULD LIKE TO KNOW HOW I RESET IT
You can do a hard reset by pressing and holding down the Select button (it's a silver square on mine) while pressing the volume + and - buttons simultaneously once.
Let me know if this helps. It didn't seem to fix my problem!
Apr 24, 2008 | SanDisk Sansa MP3 Player
My scandisk sansa clip mp3 player is fozen at the refresh database screen
I actually called the 800 sandisk number and the guy was helpful (after some annoying personal questions).
Unplug from your computer
Turn off the device.
Push the button down to be in the "Hold" position
Press down on the "center" button (inside the circle)
While still pressing on the center, plug in the device.
Now you should be able to see the device under "My Computer"
Right click on it and FORMAT --YOU WILL LOSE ANYTHING THAT WAS ON IT! But you will be able to use it again. I was assuming all my stuff was gone, it was just copies from my computer anyway.
This worked for me and now I just have put my music back on it.
Hope this helps everyone else! And don't hook it up to a MAC!! Even just to charge it!
Feb 16, 2008 | SanDisk Sansa Clip MP3 Player
My SanDisk sansa e250 wont sync
try reseting it to factory settings. in other words put it into recovery mode. to do this simply plug it into your computer, then push the hold button down so the orange is showing. then push and hold the record button on the side of it and push and hold the power button. if you do this correctly it should work. heres a link to the sansa forums just in case http://forums.sandisk.com/sansa/board?board.id=e200
best of luck friend! : ) dont give up!
Dec 30, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
569 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
