Question about Cell Phones
Gps navigation My n95 picks up sattelites but does not pinpoint my position.
  • sammyj_1001 May 06, 2008
    Hi I have the same problem. I Enter nokia maps but the satelite shows 3 yellow lights. It connected once and they all turned green but it shortly went off again.
    President:
  • 1,944 Answers
You should enable the AGPS to help pin point your location.
Posted on Apr 17, 2008
Ho do i master factory reset for my cricket comment 3
a GPS device will not work on the cricket network. GPS sattelites are up in the sky not cell phone towers. go read a book or something
Jul 05, 2014 | Garmin Nuvi 2460lmt Gps Navigation System...
Been on before ,cannot pick up sattelite, getting worse by the day ,getting quite annoyed as this happens more often than actually works .at moment still not picking up sattelites. have had this before...
I understand your frustration - but don't toss it yet! Try a hardware reset first.
1) Lift the antenna up as usual.
2) Locate and press the small button on the rear of the nuvi (that was covered by the antenna).
3) Hold it in for 3 seconds.
4) Place it into the cradle / charger and it will turn back on and operate normally.
Good luck!!
Sep 06, 2011 | Garmin Nuvi 350 Car GPS Receiver
My Nokia N95 gps doesn't work after I change my casing. I tried using the gps data but it only get me 1 sattelite signal,though it were seldom.
This problem usually occurs, when your old data resides and , when it is not able to replaced...
This can be rectified by RESETTING YOUR PHONE TO FACTORY SETTING once..
Navigate to SETTINGS_>SECURITY->RESTORE TO FACTORY SETTING
Now try connecting GPS, it should work,
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Aug 27, 2009 | Nokia N95 Cellular Phone
My Garmin 765t stopped navigating
There should be a small reset switch on the back of most garmin gps units. with the unit on, depress the reset switch with a pen tip or small object until the unit shuts off and restarts. It may take a little longer to pick up the satellite but it will reque the unit and unlock the navigation screen.
Aug 01, 2009 | Garmin nuvi 765T GPS Receiver
Similar issue..tom tom would not pickup sattelites.
definitely!never ever keep GPS in glovebox or center console heat in cxars goes above 140 degrees in summer and can cause meltdown and distortion of plastic as well as total destruction of SD cards It also kills off memory.
If you are goiung to store a GPS for any period place it in a place away from magnets heat and extreme cold ( heat and cold also destroy batteries)
Jul 23, 2009 | Tomtom ONE GPS Receiver
GPS for china mobile
For china mobiles manuals, software and drivers check chinamanuals.com (check for CECT N95)
I don´t think there is a GPS available, because the N95 does not support java.
Jan 17, 2009 | Nokia 1100
Gps issue on nokia n95
i think you need to contact orange and ask if your gps has been activeted if not they will give you further instructions i inform you to ring your customer sevices and tell them your problem
Feb 22, 2008 | Nokia N95 Cellular Phone
SATTELITE NAVIGATION
Install Mapsource program from the CD and also install the maps. Start Mapsource program and use the Map tool to select the states you want to install. Now hookup your Garmin to the computer and Transfer the maps to the Garmin
Oct 19, 2007 | Garmin StreetPilot i3 GPS Receiver
Cell Phones Logo
61 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
