Question about Kenmore HE2 Plus Front Load Washer
How do I put the top cover of the washer back? I had the dryer put on top of the washer when it was first installed and took the washer cover off so the dryer can be bolted and sit on top of the washer tightly. I took the dryer off the washer and now I'm having problems how to put the cover of the washer back. Please help.
  • 5,911 Answers
Lay the panel on top of the washer with the screw holes pointed towards the back. Slide the panel forward until it is flush with the control panel. Reinsert the screws in the rear to secure.
NOTE: There should be a couple of tabs near the control panel on most of these washers that the top panel slides into to lock in place.
If you have questions, please post back with your MODEL NUMBER and let me know. I hope this help you.
Posted on Jul 04, 2010
My kenmore 98702 stacked washer/dryer washer lid does not stay open
Underneath the top unit (the dryer) there should be a spring loaded catch that holds the door open. See if it is gummed up and stuck or possibly broken off.
May 29, 2014 | Kenmore 98702 Stacked Washer/Dryer
Need to replace a baffle that broke off . MED9800TKo model baffle broke off insde on the dryer drum
Remove the top panel to access the outside of the drum where the baffle securing screws are found. Remove the three hex-head screws from the rear flange of the dryer's top cover the lift the rear of the cover and slide it back so the tabs clear the catches on the bracket and remove the cover from the unit.
Turn the drum until the baffle screws are on top then remove the screws and the baffles. Install the new baffles then the top cover. Make sure that the tabs slide under the bracket catches when you reinstall the top cover. The top cover screws have nylon flat washers on them. Be sure to use these screws when you reinstall the top cover.
Jul 18, 2011 | Maytag MED9800T / MED9800TQ / MED9800TK...
Need help with installing belt in Maytag Electric dryer
if not able to remove rear panel,you will need to start,like most models,take top cover off and hinge back to wall then remove frt cover including door as a whole assy. lift up drum put new belt on drum ( and position in same area as old belt,it will have marks on drum from where original belt was on drum) then put rest of belt over mtr pulley and then idler pulley, turn drum by hand to align belts and put it back together in reverse order
Jul 28, 2009 | Maytag PYE2300AY Electric Dryer
The belts come off, its a hotpoint aquarius wm63.
Remove the complete rear panel of m/c if it is a washer dryer, you will see the drum pulley in the center, and the motor pulley is at the top of the m/c
Put belt round motor pulley first, and feed belt round drum pulley.
If it is a washer on its own, remove the small center cover at rear of washer, and remove top cover also.
Put belt round motor pulley first and carefully feed belt round drum pulley, you will find this easier to do if you unhook the rear retaining spring.
Please leave a fixya rating for my solution.
Thanks.
Feb 12, 2009 | Hotpoint Aquarius WD63 Front Load...
Whirlpool gas dryer model # lgr7646eq3
put back back on with top off remove screws in top corners of front panel remove bottom panel and screws holding blower/lint screen housing on remove door springs remove screws on bottom corners of front belt is probably lying in bottom
Sep 03, 2008 | Whirlpool LGR3624JQ Gas Dryer
GE Profile Electric Dryer, Blower nt getting up to speed
You need to replace the blower motor. It says you are having temp problems because the blower is quitting and the heater is overheating.
Jun 01, 2008 | GE Profile Harmony DPGT750EC Electric...
Stacking Frigidaire dryer on washer using stacking kit 5303937141
You have to take the top off the washer a put it aside. You no longer need the top. Then you put the two angle brackets on the front top of the washer. this is where the front of the dryer will attach. The back of the washer either has or needs the brackets put on the top (been a long time since I did this). Remove the leveling legs from the dryer. Then lift the dryer and slide it on top of the washer with the back touching the top of the washer and the front about 2 inches higher than the washer top. The back of the dryer slides into the back brackets which are on the top back of the washer. Then lower the front of the dryer and the two "L" brackets on the front top of the washer slide through cracks into the dryer. Pop off the two plastic plugs on the dryer bottom front and place a screw in each one to hold the unit in place. Replace the plastic caps and you are done.
Dec 29, 2007 | Frigidaire FEQ332E Electric Dryer
Error code dHE
Several reports in Australia of brand new LG Washer/Dryer combo (model number WD14700RD) getting dHE error's with very 1st dry cycle.
I bought a LG WD14700RD last week, and yup, washed fine.
Dryer cycle results in dHE error.
Everytime.
Cycle stops & you just have to power off the machine.
Service man found several possible causes.
He unscrewed the top of the machine off & said dHE errors are related to the dryer components. He started a dryer cycle & watched & lisened to machine.
He observed the dryer fan was not starting up.
He unplugged the power cable to the dryer & replugged.
The fan now started up, but only with cold air.
He then looked towards the front of the machine & noticed several cables had come loose from their sockets, one he identified was the heater element cable.
He plugged that back in & another unknown cable was also loose. He plugged that back in.
It worked.
dHE error gone & dryer fan started & pumped out hot air.
It seems at least a few of these machines during transit (from South Korea?) fail due to cables coming loose from their sockets.
dHE errors result if fan cable & fan heating element cable come loose.
My thanks to WAM electrical repairs in Box Hill (Melbourne) for helpfull advice & successfull repair.
For people looking at buying this machine, it washes & now dries perfectly well & I am happy with the machine.
But beware that this problem is out there (there are several other reports I read) and it have this problem, which is easily fixed but does require a service call out, under warranty of course.
Steve, East Melb.
steve_aust@hotmail.com
Oct 06, 2007 | LG WM3431 Front Load Washer / Dryer
Maytag lse7806ace
After removing the power (easist was to shut breaker off), then replaced fuse just inside upper front left cover area by way of 2 white screws on bottom front panel. Clips secure the top into the horizontial lid panel (which you will also have to remove later if fuse keeps blowing) That worked for a coupe weeks as long as the Cycle Selector dial was always pushed in when you opened/closed the washer lid. Then the the problem returned. Only way out was to partially remove the unit from the wall and remove the lid assembly, which was much easier than first thought. Pictures attached. Tools needed are Phillips screwdriver and Nut drivers to remove the horizontial lid/panel from above the washer tub, and below the timer panel/dryer. Didn't need to remove the angled cover below dryer as Washer Door lid assembly is wholly below. Just push the dryer toward the rear, then remove two larger nuts from top left and top right corners. No nuts at rear, just clips that slide in/out. This allows lid cover to be pulled straight out (I had to remove the overflow tube on front right of tub, and one semi-rusted nut-driven screw from the Hot/Cold filler plate which is at the rear of the lid cover. That will make it easier to manipulate the cover and release the 4-pin plastic connector shown in pictures at the left rear corner. Then the entire cover/lid slides out easily as you may have to push the dryer top back to ease it out. Then flip it over and replace the switch and slide the 4 wire connector back under the plastic trip. and reverse the un-install. 4-pin connector is flat-keyed on one side, but it is tight to get to. My OEM part even included a new fuse (19.95 + shipping) Unit is now working fine for last 2 weeks.b88b41c.jpg8de8e68.jpg798b349.jpg49eb6d1.jpg6f06d50.jpg48c84c4.jpg
Nov 14, 2006 | Maytag LSE7806A Top Load Stacked...
Kenmore HE2 Plus Front Load Washer Logo
145 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
