Question about Optoma EzPro 739 Multimedia Projector
Blending Colors/Flickering Display
I have about 1550 hours on my bulb. After about 10 minutes of turning on the projetor my display colors start to blend and then screen flicker. Any Ideas? (I think its the Bulb)
  • Carlos H
    Carlos H May 01, 2008
    This solution written by SmartMex!
I fixed this problem myself! It was due to dust collecting on bulb! I took out the entire bulb fixture. I blew all the dust off with nitrogen(Air Can) and then reasembled unit. Now it works GREAT!
Posted on May 01, 2008
  • 563 Answers
Hi SmartMex
This in not a lamp problem , but rather a Mainboard issue.
You will have to take it to a Service Centre to either be repaired or replaced.
Posted on Apr 18, 2008
My emerson lc401em2f is flickering with different colors almost like arolling-flickering? how can i fix it?
If you wish to get some details; check the site linked here. Pull up older posts.
Flickering can be adjusted. Type in the keyword "Flickering"; in the search box, at the top of the display window, to get gathered related posts.
Mar 07, 2015 | Emerson LC401EM2F 40" Inch LCD Full HD TV
My HDTV wont turn on, two weeks ago the colors blend together I wasen't able to adjuste the colors. then I turn it off and leave for two weeks. when I try to turn it on it wont turn on, the control panel...
It seems that you have an issue with the power board. You could also have faulty convergence modules causing the blending of colors.
I wouldn't advise you to open the set yourself, because of the complicated circuitry and high voltage. It is safest and best to get TV repairman to look at this issue and provide a fix/repair.
May 31, 2008 | RCA Televison & Video
Hi..i am using compaq presario cq 40 and screen is flickering.i had it checked and they told me lcd is the problem but they didnt even bother to check.they just turned it on and they told me that i have to...
When it flickers, can you still see the text when the screen goes dark?
May have to use a bright flashlight set right on the display to see
the text on the screen beside where the light sits.
That will tell you if it's the backlight.
You can also look at a grazing angle into one of the edges to see if the
backlight is flickering when the display does.
When it's cold, does it start with a slight pinkish color? That can be
a sign of backlight going bad.
Anything interesting happen when you flex the cable by moving the screen?
I'm not saying it's impossible, but I've never seen software cause
consistent screen flicker. And if the vga port doesn't flicker, sw is
even less likely the problem.
If you bet the odds, you'd bet on a bad display cable.
Won't hurt to try replugging it.
If that doesn't help, then your monitor may be dying....
Jun 20, 2011 | Computers & Internet
My tv is working and all the only problem im having is the color display. every color the shows in the screen is shifted to a purple like color. what should be white colored is turn purple. i dont know if...
this may have problems with lcd controller driver the lcd color comes and driven with this controller. only quilified technician can test it....
May 30, 2011 | Televison & Video
My Smasung projection TV keeps flickering, also every hour or so the screen turns to a green flicker. I have to unplug the power cord and that temporarily fixes the problem. How do I stop the flickering?
The tv colors wheel is dying,replaced the tv colors wheel,will solved this problems.Hire a tv Tech.to change the tv colors wheel,it pretty hard to change the colors wheel in this tv.Because u require take out many machanical parts before u even can come to the tv colors wheel itself to change it.
Nov 08, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
After TV turned on for 2-3 hours the colors begin to change
The light engine is going bad. To be specific the color wheel is wearing out and cannot be replaced seperately as it's part of the light engine. Mitsubishi extended the warranty on the light engine for an additional two years. You need to contact a local Mit's authorized service center to see if yours is still covered. Better hope so as the light engine is expensive.
Jul 09, 2009 | Mitsubishi WD73727 73" HDTV
Flickering Screen/Line in Screen
flickering is a sign that bulb will go out soon. Also check if the bulb fan is clean and running.
Mar 22, 2009 | Akai PT46DL10 46" HDTV-Ready Television
Display Problem
Inverters On The way Out.
Try gently Pinching the screen at the top and bottom of where its Faulty ( On the Plastic casing ) Not the actual LCD.
Mike @ Compurepair.
Mar 07, 2008 | HP Pavilion zd8000 Notebook
Sharp Projector XV-Z90 Flickering
the color wheel is dirty. It just need to be cleaned.
Feb 18, 2008 | Sharp Projector lamp Projector Lamp
Open Questions:
Optoma EzPro 739 Multimedia Projector Logo
369 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
