Air conditioner seems to be working but cold air is not coming from the vents
  • 43,501 Answers
There can be a couple of things that could be happening...
The first and easiest thing is to check the air filter. Make sure that it is clean... clean it or replace it. Next check the air vents to make sure that they are open and giving you good air flow...
Also check to make sure that you are not icing up on the indoor coil... ice will tell you that you are low on refrigerant. You also could be low and not be icing over, but you would need to have gauges on the unit to check that.
Finally check and clean the outdoor coil...this also can give you problems if the heat is not being removed from the outdoor unit efficiently...
You may also have a unit that is sized in such a way that it hits the balance point at about 85...that means that your heat gain is equal to the capacity of the unit...I often try to size them for about that here in Northern PA. because wqhen seldom get hotter then that and the unit then is much more effective at removeing humidity at lower temperatures...
You can also check out the tips that I have wrote about Air conditioningAir conditioner seems to be working but cold air - 2_bing.gif trouble shooting and maintenance...
Posted on Jul 04, 2010
Rv air conditioner how cold should the air blowing from ceiling vents be?
Do you have two rooftop a/cs, ideally any a/c you like to see temps from the inlet duct to the outlet vent at least 15-20 degrees difference in temp,check your filters,that front air works twice as much as the rear,plus cooking and heat load on it can be more than the rear,those units are a glorified window air and cost 10 times more because it is for an rv,i worked on r v's for 20 years,nowadays they are throwaways ,nobody likes to repair them,could be low on refrigerant and if it has a leak it cost tooooo much to repair,sorry but i speak the truth!
Mar 08, 2013 | Heating & Cooling
2003 jeep grand cherokee heater problem
Jeep Grand Cherokee is notorious for broken blend-air doors. This is the door inside the A/C-heater housing that switches the air from hot to cold. You must remove the dash to repair it.
Nov 13, 2011 | 2003 Jeep Grand Cherokee
Central air conditioning unit blows air but not cold air
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 29, 2010 | Amana Heating & Cooling
Not cooling fast
Check for cleanliness of your air filter and evaporator coil. Make sure nothing is blocking your return or supply vents. Check the integrity of your duct system (no loose connections).
Apr 06, 2010 | Ruud UBHC Air Conditioner
Cool air, but no fan, electrical smell inside house
most like it the motor windings are burn and you need to replace the blower motor
Sep 27, 2009 | Ruud UBHC Air Conditioner
1995 Chevy Silverado 4X4 cold air blows through floor vent
none of the above, the vent door is stuck inthe open position most probable cause is vacum leak look closer to your fire wall and you will see a very thin vacum hose going into the vehice which seems to be unpluged!!
Nov 13, 2008 | 1999 Chevrolet Silverado 1500
Air conditioner fan is not moving air is coming from the vents but not cold
Air conditioner probably has a failed run capacitor inside the unit. Check all circuit breakers and/or fuses first.
Jun 30, 2008 | Heating & Cooling
Air conditioning and heating
The vacuum line on the drivers side of the intake manifold just below the throttle body fell off.
May 26, 2008 | 2003 Jeep Grand Cherokee
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
