Question about Whirlpool GR465LXLS Electric Kitchen Range
Pushed the bake button and the broil come on
When i first turned the unit on i pushed the bake button, the briol element came on and wouldnt shut off. I tool the mother board out cleaned everything including the pad and put back together. this time the bake comes on when i push the button but the broil wont come on even though the display board says it is turned on
  • EagleW Apr 17, 2008
    how do i check the control board chip
  • 796 Answers
May be the control board chip is not functioning properly...
check for the control board
Posted on Apr 17, 2008
    Genius:
  • 1,665 Answers
Try this link for parts availability
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
  • Kleanthis Mavropoulos
    Kleanthis Mavropoulos Apr 17, 2008
    Type "Whirlpool GR465LXLS " in search tab and click search
Bake and broiler element come on when bake is selected. Why?
Understand that I am not a professional, so this answer is subject to revision by someone who is more knowledgeable.
Where I live now I'm on Natural Gas, but in the past I've had electric stove/ovens. Based on my best recall the situation you describe is NOT abnormal.
When in the Broil mode, the Bake element is NOT on, but the Broil element is on FULL-bore to provide that strong radiant heat required for the Broiling process, AND for the good browning /crusting of the product being Broiled!!!!!
On the other hand, when Baking, not broiling, IF the Broiling element were on high it would provide too much radiant heat to the top of the product being Baked, and would burn the top.
While Baking, by energizing the Broil element in a lower power setting, the Baking process is enhanced with more heat by the assistance of the Broiler element, BUT without the hazard of burning on the top!!!!!
Hope this is right and helps your understanding.
Jan 16, 2015 | Ovens
Whirlpool built in electric oven
The upper element is for broiling and should not come on until you tell it broil. If it is coming on as soon as you turn on the breaker then it sounds like the printed circuit control board is bad. There is a relay on the board that engages when you program in the broiler. The relay can be hard to find and may not be removable. My broiler would come on when I programmed in the bake mode, go into runaway heat, put up a F10 code, and shut off. I could not clear it until I programmed in the clean mode for 2 hours. Now it works great.
Sep 07, 2014 | Whirlpool RBS275PD Electric Single Oven
Why does only broil come on when i push the bake button?
Bake and broil elements can be tested with an ohm meter for continuity. There is a relay in control / clock for both bake and broil elements. If elements test good, then those relays need to be tested for voltage.
Sep 16, 2017 | Ovens
Baking & broiling elements won't heat after baking element burned out and was replaced.
the surge from the original element burning out has destroyed the control board if you can't hear the relays on the board clicking when you power up the elements bake or broil then its either the low voltage side of the board,if you hear clicking then the relays are working but the contacts are burned out and can't pass the current to heat the oven or briol elements
Jan 04, 2013 | Jenn-Air Ovens
Hi there, We have a Fidigaire Gallery electric stove and the oven does not heat up. We press thej"Bake" button followed by the up arrow to set the tempurature but the oven will not heat up. The...
well... have a volt meter?
Are the bake and broil coils the same?
If so, you can swap them to see if the broiler element glows in the bake position... if so then the element is NFG... to proove that put the bake element in the broil position and fire up the briol function... it should not heat up...
Usually the MFG. intentionally makes the elements with a different offset, so you cannot mix them up...
that's what the meter is for... unplug the element, and put the probes in the socket.
You will be reading 220 Volts, so be XTRA careful... if no 220 then the Module that controls the relay to activate the element connector is not working correctly... so you have to sorts test both ways...
Just be careful...
Mar 10, 2011 | Ovens
My oven wont heat up?
Hello there:
first chevck to see if the broil feature will work but if both the broil and bake feature does not work meaning it will not heat up if you have selected either the bake or broil follow these solutions that i have provided for you .
It won't bake or broil If neither the bake nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring. If the oven does not have a separate bake/broil/etc. selector switch, the problem may be with the thermostat. But it's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
Jul 13, 2010 | Hotpoint SY36 Style Line Stainless Steel...
Whrilpool GR450LXHB2- The stovetop works, but the
It won't bake or broilIf neither the bake nor the broiler heating elements heat, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)", push the knob in and try the baking and broiling elements again. If it still does not operate properly, you probably have a defect in the thermostat, selector switch, or common wiring.
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
  • You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
  • If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
It won't broil Usually, when an oven won't broil, it's because the broiler element is burned out. The broiler element in an electric oven is the black, pencil-thick tube at the top of the oven. When the broiler is on, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 25, 2009 | Ovens
My oven take forever to preheat
Your bake element is probably open. When this happens the broil element may heat slightly when in BAKE mode and that is where your heat is coming from. First thing I would check is the connections to the bake element as well as the element itsef.
Dec 14, 2008 | Amana AER5715QAS Electric Kitchen Range
Broil wont COME on
doble check the unit wiring, might have a wire out of place
it the display is showing the broil element on then check and see if you have proper voltage at the element, work bat to the board and find the problem
Apr 17, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Whirlpool GR465LXLS Electric Kitchen Range Logo
127 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
