Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
Shaking of pictures on tv
What causes the pictures on tv to shake like water waves?.This occured after flactuation of electric power.
What is the solution of that?
Posted on Jan 08, 2012
    Genius:
  • 1,224 Answers
A flux could cause bulb lead to come out of flux this is one thing that makes it shake
fan blade on cooling fan broke maken it shake
uneven service thats not solid can make it shake
Posted on May 10, 2008
What causes my picture shake
Check your TV level ... it must stand on a firm foundation ... it wobbles because your floor shakes - reduce the shaking by improving its contact with the floor.
Jan 15, 2013 | Hitachi 60UX58B 60" Rear Projection...
Picture shakes
sounds like caps dying on power board
Nov 28, 2012 | Samsung UN55B6000 54.6 in. LCD HDTV
Why does the cursor shake on my graphics tablet?
I had the same problem and found the solution (for me).
It was the Laptop Power Supply.
  • Switched off the supply and ran off laptop battery - no shaking.
  • Switched on the supply - shaking.
Hurray! It also explained why sometimes it would shake, sometimes not and why it also occured on my other laptop which caused me a lot of confusion - I was swapping over the same Power Supply to use on both laptops!
Dec 30, 2011 | Trust Computers & Internet
When I drive and reach the speed of about 60 mph, the steering wheel shakes a little. Does the wheel bearing or struts need to be changed?
I would start by having the tires carefully inspected and balanced if needed. A tire that has a broken internal steel cord can develop a lump or wave in the tread face which will cause the steering wheel to shake as the vehicle speed increases. Usually a tire that is developing such a problem is very close to failing completely [flat or blow-out] so have them checked as soon as possible. An out of balance tire usually just causes a general vibration or shake but can cause bigger problems depending on how out of balance they might be. Worn tie rod ends or other suspension components can cause a similar shake so have those items checked at the same time. Worn struts usually won't cause the shake you are describing but can cause the car to handle quite poorly and bounce excessively on bumpy roads. Wheel bearings often [but not always] make a grumbling/growling kind of noise as they start to go bad but usually won't cause a shake. A good inspection should quickly pinpoint the cause of the problem
Jun 21, 2010 | 2006 Toyota Camry
I have a HLN617W Samsung television. The picture shakes bad. When I put it on pip where you can watch 2 screens at one time, on the left is real shaky and the right is good for about 20 minutes and then it...
Two boards can cause that kind of problem in Samsung HL-N617W, either power supply or digital board.
Need to swap above said boards to confirm what board is causing problem or inspect closely for leaky electrolytic capacitors and replace them with same ratings.
Hope this info will help you.
Thanks.
Nov 15, 2009 | Samsung HLN617W 61" Rear Projection HDTV
My Sony DSC T70 shakes & vibrates
On Sony T100 and similar,
its the vibration canceling unit, i had the same problem.
if you have good hads you can fix it.( on your oun risk)
1) disasamble the camera, you will see black plastic box inside, this is he lens unit.
2) on the botom you see 2 scrwes, they are holding the CCD remove them and the ccd unit will come from the lens assembly
3) the next is the stabilizer unit it is the problematic one. it is located on the left side of the lens asebly and is held by 2 screws.
you can test it by puling out the cable connected to it (the conector is just under the lens) and verifign that the problem is solved. ( you can leave it this way it will shoot fine just without the anti shake)
4) to fix it take it out ,remove the plastic cover, you see the lens on a plastic mount it should be glued to the magnet under it. the problem is that the glue fals apart.
remove one of the pins on wich it slides, and take the lens and the magnet out.
5) reglue the magnet and reasemble the camera.
6) power up and test, for me that solved the problem
if you need more help you can mail me at adisarit(et)yahoo(dot)com
this is spam mail so be prepared to wait a few days for reply.
i have a document with pictures explaining the process
Aug 25, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Screen vibrates intermittantly. Also buzzing noise.
This is a problem with the lens gyro we can keep it from shaking it requires the camera to be taken apart and amodification done to the lens repair cost 65.00 in most cases.
May 14, 2009 | Sony Cyber-shot DSC-T70 Digital Camera
Vibration of camera
Have sony 36 trinitron about 5 years or older..the picture just shakes. never lose the picture or the sound. just cant get it to stop shaking.
U have magnatic degausing coil problem.Take the tv aparts,there a solid back coil all around inside the front frame of ur tv.That the cause,unplug that coil,should not effect the tv pic if have no magnatics problems.
Feb 22, 2009 | Sony FD Trinitron WEGA KV-36FV27 36" TV
Violent shaking picture initially but slowly tapers off but still shakes
Do you have a service manual for your tv? If not I would suggest you get one because there could be several things causing this I will post a website whre not only can you get a manual for your tv but they also supply free online tech support to help you troubleshoot and fix your problem
http://servicemanuals.vstore.ca/
May 06, 2008 | Toshiba 50H72 50" Rear Projection...
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
1,063 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
