Question about LG 32LG30 32 in. LCD HDTV
Won't turn on red indicator light goes off when on button is pres
Won't turn on
  • 63 Answers
Check on the power supply for bad capacitors and order them from newark electronics get the vishays.
Posted on Jul 04, 2010
My toshiba TP48E60 model projection tv won' turn on, power light just blinks
Blinking of power LED are fault indications. Count the number of blinks occur at one time switch on. For this number, you can get an idea about the faulty section circuit inside it. It will make troubleshooting much narrower. If you wish to get more details about the blinking codes, check this link. Pull up older posts there.
Mar 08, 2013 | Televison & Video
I have a soyo tv and the codes on the setup sheet do not work
Try a code search method. If the remote have codes for your TV, you will won. It is a time taking procedure. Check it. Here the procedure is.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
IDENTIFYING CODES FOUND USING THE SEARCH PROCEDURE
  1. Press and hold the SETUP until the LED indicator lights steadily. Release Setup button.
  2. Press the mode button that matches the equipment you want to identify. The LED blinks once.
  3. Press and release SETUP. The LED blinks once.
  4. To find the first digit, press each number button from 0 to 9 until the LED blinks. The number you pressed is the first digit of the code.
  5. Press each number button from 0 to 9 again as above to find the second digit.
  6. Press each number button from 0 to 9 again as above to find the third digit.
  7. Press each number button in turn to find the fourth digit. When the fourth digit has been found, the LED goes out
Oct 14, 2012 | Soyo Televison & Video
TV won't turn on
Before going OFF, the standby LED might blink. These blinks are fault indication. The number of blink should be counted. Count the number of blinks at one time, before the TV goes OFF. [eg: 4 blinks Power SOS P Board; 6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)] and so on. you can get more details from this site named 'Electro-help'. You can reach it by searching the keyword "electronicshelponline" by internet.
Jul 03, 2012 | Panasonic TC-P50X1 50 in. Plasma HDTV
Rcr311b remote won't code to Sansui tv
Code Search
Jun 27, 2012 | RCA RCR311B Remote Control
Cant progam brookstone giant remote to phillips lcd tv
Three digit universal remote code for Philips are:
003/ 004/ 006/ 008/ 062/ 068/ 069/ 074/ 075/ 076/ 086/ 087/ 089/ 133/ 163/ 183/ 184/ 205/ 206/ 207/ 208/ 212/ 213
Four digit Codes are:
0062 0204 0184 0208 0205 0206 0207 0004 0189 0183 0199 0200 0288 0456 0003 0008 0068 0075 0086 0087 0141
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
  5. Code Search
Jun 13, 2012 | Universal Remote Control Televison & Video
UR 2 Universal controller - don't work!
Direct Code Entry
    Code Search Method
Mar 22, 2012 | Televison & Video
Treadmill keeps inclining and declining . It won't stop!
I have a Proform ZT5 model - had the same incline/decline problem. It needed calibrated.
- unplug, turn off, and take the key out
- plug machine in
- turn switch on
- Pres and hold the STOP and SPEED UP button at the same time, while holding them insert the RED KEY
- let go of both buttons
- press STOP 1 time
- pres INCLINE UP 1 time
- this should reset it.
The tech on the phone mentioned the importance of turning the maching off, taking the key out, and unplugging after each use. Leaving it plugged in there is still an electrical current running and this can cause more seriouc problems that require a new control panel.
May 08, 2011 | Proform ZT5 Treadmill
I used shift to us the remote control with the secondary TV. Now i cannot get it to correspond with the main tv. How do I fix the problem. Thanks
If u stil hve the manual, plz consult it. OR u press n hold shift, pres ur device button (tv), indicator light starts blinking, pres n release ur search/power button continuosly, whn u get response from ur tv, leave it 4 a few seconds, the light goes off n ur remote is set again.
Apr 10, 2011 | Universal Remote Control Dish Network...
I have a steady red light and it won`t turn on
After plugging the AC power cord into the electrical outlet, the power indicator on the PS system will light up in solid red.Press the power button
Feb 13, 2011 | Sony Playstation 3 (PS3) Console
LG 32LG30 32 in. LCD HDTV Logo
Computer Repairing
Computer Repairing
