Question about Lands Phones
How to pair plantronics c65 to panasonic kx-tg7123e phone
5 Suggested Answers
SOURCE: panasonic KX-T7730 CORDED PHONE
my telephone is lock forget pasword
Posted on Nov 05, 2008
  • 15 Answers
SOURCE: Panasonic kx-tg1100
STEP1:
On the handset you want to discard go to "SETTINGS HS" -> "REGISTRATION" -> "CANCEL BS"
This will discard the registration of the handset to any base.
STEP2:
Using the handset you want to register go to "SETTINGS HS" -> "REGISTRATION" -> "REGISTER HS"and select the base you want (i.e. BASE 1, BASE 2, ..., BASE n).
NOTE:If you do not get access to the BASE you are looking for (STEP 2) then you have to cancel the registration of the new handset to any base. Therefore, follow STEP1 for this handset as well and then follow STEP 2.
After you finish all the above, hold down the "PAGE" button for about 5 secs.
You are now done!!!
Good luck
Simos
Posted on Nov 23, 2008
  • 1126 Answers
SOURCE: I need a manual for panasonic phone KX-TG1311
http://www2.panasonic.com/consumer-electronics/support/Phones-Fax/Telephones.75500
The closest that I could find was kx-tg1031. Perhaps you will have better results. All of these are in english.
Posted on Aug 31, 2009
  • 19 Answers
SOURCE: operating manual for Panasonic phone KX-A126CE
Had an LG tv manual shipped to me 4 free. In the meantime their manuals were available for viewing or downloading on-line. Sure panasonic does the same.
Phonesmith
  • 113 Answers
SOURCE: I have a Plantronic headset. I have moved to
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system. With the handset on the cradle/hook press Program 61 and ENTER. Press SEL or AUTO ANS / MUTE to change the setting to On. Press AUTO DIAL / STORE to save your changes. Lift the handset and put it down to exit program mode.
PLEASE rate/vote this answer if it was helpfull.
THANK YOU
Posted on Mar 23, 2010
How do I divert a call from a wireless Panasonic KX-TG6621E to a mobile phone?
Totally different networks.
But the Panasonic may have Bluetooth Capability
You would need to "PAIR" Both devices
See your Manual
PANASONIC KX TG6621E Manuals
Review Panasonic KX TG6621
Mar 06, 2015 | Panasonic Lands Phones
How do I fix my galaxy s4 wireless bluetooth pairing with panasonic cordless kx-tga651?
Have you tried to see if it was bluetoothed? An was the bluetooth on on your Galaxy?
May 25, 2014 | Panasonic KX-TGA101S Cordless Handset
Panasonic KX-17730 no sound it cannot cancel the function on FWD/DND
A 7730 phone is an analog Panasonic system phone. It requires 4 wires to make it work, the voice is on the inner pair and the data on the outer pair of a 4-pin cable. Try moving the phone directly to the system cabinet and plugging it in there. The ports on the cabinet marked Jack 01, 02 etc usually are extensions 101, 102 etc. If the phone works there (make sure you're using a 4-pin base cord) then you have a wiring problem. If it doesn't work, fix the phone.
Carl
Jun 19, 2011 | Panasonic KX-T7730 Corded Phone
Hi , i have panasonic TDA100 ipbx system i recently buy kx-tda170 hybrid extension card and install to pbx how can create extension from 25aid cable
The 170 card is an 8-port DHLC and it's pinned exactly like the old 123211 and the TD series systems where the first 2 pairs are the voice and data for a Panasonic Analog phone or a single line set on the first pair, and the 3rd pair is unused in the TDA. There are 8 3-pair sets in the cable and the 25th pair is nothing. Here's a link to an installation manual http://public.carl.airpost.net/Pana/TDA/100_TDA_IM_07-04.pdf The instructions start on page 139.
Carl
May 05, 2011 | Panasonic KX-T7731 Corded Phone
What is the price of a headset
anywhere from $11
http://www.amazon.com/Plantronics-M214C-Headset-Adjustable/dp/B000ANOY7M/ref=sr_1_1?ie=UTF8&qid=1294360480&sr=8-1
to $170
http://www.amazon.com/Plantronics-CS-55-Digital-Wireless-Headset/dp/B000C12GH2/ref=sr_1_3?ie=UTF8&qid=1294360480&sr=8-3
Jan 06, 2011 | Panasonic KX-T7730 Corded Phone
I have a kx-t7630 digital phone but if i connect it to the dhlc card in a panasonic kx-tda200 i won't work.. but if i connect analog phones it works.
Check the wiring. The cable that plugs into the DHLC is designed to be compatible with the TD series systems which means the first two of every 3 pairs is used for the 8 extensions. The 2nd pair has to be wired and jumpered for a digital phone to work. I'm guessing all other Pana analog or digital phoens would fail too.
Carl
Oct 05, 2010 | Panasonic KX-T7630 Corded Phone
I have a Plantronic headset. I have moved to another location (and phone jack) in my office. The Plantronic headset plugged into the Panasonic KX-T7633 does not get a dial tone. When I go back to my...
THANK YOU
Oct 29, 2009 | Panasonic KX-T7633 Corded Phone
How can i connect my headset to the KX-T7630 properly?? i sound very far away to my callers!
This is an unusual problem and might be either a bad headset or bad connection. What kind of headset do you use? Plantronics? How is it connected, directly to the little phono jack on the side of the phone, or through a cradle for the headset. If you're using the Plantronics wireless headset, refer to the manual on how to adjust the mic settings, there will be a dial on the side and it can affect the mic.
Aug 28, 2009 | Panasonic KX-T7630 Corded Phone
Is tha possible to get 25 single lines on 16SLC card(50 pin)
The 25-pair Amphenol connector is just something the industry uses because it's standard and easy. In a TDA system, the 8-port C.O. Trunk card uses the first 8 pairs, a 16-port the first 16 pairs, an 8-port Pana station card uses the first 24 pairs, 3 pairs per extension. The last pars don't have any hardware behind it and are connected to nothing.
The only phone system that I remember where all 25 pairs are used is a 1a2 10 button set and, maybe a Comdial system where the 25th pair is the common audible for station 17 :-)
Carl
May 22, 2009 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T2375MXW
Program , mute , 6 : now you can type the time
press program to store.
Mar 07, 2008 | Panasonic KX-T7730 Corded Phone
Lands Phones Logo
69 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
