Question about Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor
My 1.7 26 gallon husky upright will not come on at all
  • 2,100 Answers
Did you trip the reset button? It should be there someplace i a spot where you can't see it, just push it till it clicks, make sure the switch is on. Hope this helps.
Posted on Jul 04, 2010
Husky 26 gallon air compressor parts
well it depends on what you actually need because husky doesn't make the compressor, it's branded
Dec 15, 2013 | Air Tools & Compressors
CAN YOU STAND THE Husky WL651004AJ UPRIGHT?
Your compressor will work in the vertical position however you will not be able to properly drain the water from the tank in this position.
Feb 18, 2012 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
How do I tighten the pipe on to the air regulator and the husky 26 gallon tank at the same time? they all need to be turned the same way, I do not understand
This can be a tricky dominoe affect depending whats in the way when you make a complete revolution while turning. Take everything off. If possible screw the pipe into the regulator first, then the pipe and regulator into the tank. If you are not getting the desired postion or alignment when you tighten it, then you will need to apply a few layers of teflon around the thread to achieve proper location.
Dec 05, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
I have 3 compressors, all of them refuse to stop compressing until i manually shut them down,husky 26 gallon upright 5 yrs old, porter cable pancake 2 yrs old. and a master elite? came from home depot as...
the regulator/switches are either rusty, clogged, or need to be replaced. if you have some machanical aptitude and common sense this should be easy, if not have a pro or someone some knowledge of this type of thing handle it for you. in the future drain your compressor DAILY to avoid this problem
Nov 13, 2009 | Porter Cable Air Tools & Compressors
I have a 5hp 26 gal upright cast iron.Moved lying on side
clean fuel tank, and lines. just do a standard tune up. check every componet for wear or rust.
Oct 26, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
Husky Q26 will not build pressure. Where do I buy parts?
First check the check valve and also if it has an unloader valve make sure it is closing.
The main check valve is often right where the air goes into the tank. The unloader can be integral to the pressure switch or on the compressor.
Sep 26, 2009 | Air Tools & Compressors
HUSKY 26 Gallon Shuts Down After <75PSI!?
Possibly the pressure switch needs to be adjusted to reach a higher pressure. Trace the power cord into a box that also is piped into the pressure line from the compressor. If the pressure works itself back down again, use thread-locker fluid on the adjustment screw to hold it's setting.
Sep 08, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
80 psi and it stops
adjust the pressure regulator
Jun 17, 2009 | Air Tools & Compressors
Campbell Hausfeld 5 Peak / 1.7 Running HP, 17 Gallon Husky Air Compressor Logo
555 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
