Question about Sony Computers & Internet
System defaults to "Automatically fix file system errors"
What causes the "Automatic fix file system errors" to continue to repeat over and over? This has happend 3
times, and each time I have had to clean all information
from the hard drive; this is part of reloading the operating system Microsoft windows Xp. I suspect that each time this has happend the computer has been left in
the standby mode for extended periods of time. So as of
the last reloading the operating system and getting all software loaded back and updated. I have not put the computer in standby mode, and so far it seems to be working ok. Any thoughts would be helpful.
    President:
  • 650 Answers
Open my computer and right click on your local drive click properties click tools click check now remove check from Automatic fix file system errors start same with the more drives
Posted on Jul 04, 2010
Tally error code 407 system error code11001 how to solve this problam
PROBLEM: Error Code 11001 In Tally is usually caused by misconfigured system files that create registry errors within your operating system. Windows errors can cause program lock-ups, slow PC performance, system crashes, computer freezing and more. CAUSE: Registry errors generally occur when new programs are installed over old ones without the old programs being completely uninstalled. This can cause registry pile-ups and error messages. Another potential cause of these error messages can come from malicious software such as adware, spyware, and viruses.
SOLUTIONS: Scan and repair any missing or damaged Windows registry files using RegCure Pro. After the registry issues are resolved, it is recommended to optimize your PC by removing any spyware, adware and viruses with SpyHunter.
SOLUTION 1: Automatically Fix Error Code 11001 In Tally with RegCure Pro
SOLUTION 2: Optimize your PC with SpyHunter.
SOLUTION 3: Manual Uninstall (Usually Solutions 1 and 2 fix this part automatically)
Feb 29, 2016 | Computers & Internet
Start up repair cannot repair this computer automatically
If Startup repair is not working then use a system utility tool like Reginout to fix windows registry errors or restore windows to an earlier state:
Restore computer/ windows 7:
Navigate to the Start -> All Programs -> Accessories -> System Tools program group.Click on the System Restore program icon.
Click Next > on the Restore system files and settings window.Choose the restore point that you want to use.
Note: Check the Show more restore points checkbox to see more than the most recent restore points.
Note: Any restore points that you created, scheduled restore points that Windows 7 created, and those created automatically during the installation of certain programs will be listed here. You can not use System Restore to undo Windows 7 changes to a date that a restore point does not exist.
Click Next >.
Click Finish on the Confirm your restore point window to begin the System Restore.
Note: Windows 7 will shut down to complete the System Restore so be sure to save any work you might have open in other programs before continuing.
Important: System Restore will not revert any of your non-system files like documents, email, music, etc. to a previous state. These types files are completely unaffected by System Restore. If your intention with this tool was to recover a deleted non-system file, try using a file recovery program instead of System Restore.
Click Yes to the Once started, System Restore cannot be interrupted. Do you want to continue? dialog box.
System Restore will now restore Windows 7 to the state that was recorded in the restore point you chose earlier.
Note: The System Restore process could take several minutes as you see the "Please wait while your Windows files and settings are being restored" message. Your computer will then reboot as normal when complete.
Immediately after logging in to Windows 7 after the reboot, you should see a message that System Restore completed successfully.
Click Close.
Check to see if whatever Windows 7 problem you were troubleshooting has been corrected by this System Restore.
If the problem still persists, you can repeat the steps above and choose another restore point if one is available.
If this restoration caused a problem, you can always undo this particular System Restore.
Apr 22, 2012 | Acer Aspire 4930-6862 Laptop
Error code on ps3......will load regular dvds but not games or blu-rays.....code 80010514 pops up
that error is caused by a bad section on your hard drive or a bad installation of firmware, the first problem also causes the later so its usually both. you can fix this problem by formating the hard drive and reinstalling the firmware, but you will lose all your data and saves this way unless you back them up. you can however fix this another way, by accessing the play station's recovery console.
You access it by
1. Start with having the system in standby (redlight is on)
2. Hold the power button down; the system will turn on and turn off once again.
3. Press and hold the power button again and keep holding, it will beep as it turns on and then it will double beep. When you hear the double beeps immediately take your finger off the power button (if your system turns off before you get a double beep just try again and hold the button, it should double beep the 2nd time you try)
4. You will be prompted to plug in your controller via USB and then hit the PS button
You will now have a screen with these options (I have attached a picture of this screen below)
1. Restart System: Restarts the Playstation System.
2. Restore Default Settings: Reset all system settings back to default.
CHOOSE THIS ONE 3.Restore File System: Checks for corrupt/missing system files.
4. Rebuild Database: Rebuilds the OS for the Playstation.
5. Restore PS3 System: Fresh restore; Deletes everything and starts from Scratch.
6. System Update: Update the Playstiation System
IT IS VERY IMPORTANT THAT YOU DO NOT CHOOSE THE WRONG OPTION HERE OR YOU WILL LOSE ALL YOUR DATA. The one that fixed my blu-ray drive is option 3: RESTORE FILE SYSTEM
I REPEAT CHOOSE RESTORE FILE SYSTEM
if you chose restore file system just follow the prompts and your blue ray drive should work again.
Jun 12, 2011 | Video Game Consoles & Games
Error showing on my screen with the status code 13030, I try to close it , but it appears on the screen over and over.
13030 error are usually caused when the operating system's registry contains errors or when certain system files are missing or broken; 13030 error problems are a sign of a very unhealthy system. 13030 error are caused in one way or another by misconfigured system files
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
click start control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input will damage your computer
hopethishelps dont forget to vote
Feb 22, 2011 | Computers & Internet
My laptop turns itself of after 3 - 5 minute
Check the charger of your laptop if there is any place that has problem or cut? check the voltage of your laptop whether is the same thing with the charger. If everything are fine, then reload your operating system, because I have noticed this problem with my clients. Good luck
Feb 03, 2011 | Dell Latitude D600 Notebook
Automatic restart my laptop.Windows vista
If you are able to boot the computer in safe mode, you can disable the Automatic Restart from the Control Panel.
Open Control Panel.
Click on the System and Maintenance link.
If you're viewing the Classic View of Control Panel, you won't see this link.
Click on the System link.
In the task pane on the left, click the Advanced system settings link.
Locate the Start up and Recovery area and click on the Settings button.
In the Start up and Recovery window, locate and uncheck the check box next to Automatically restart.
Click OK in the Start up and Recovery window.
Click OK in the System Properties window.
You can now close the System window.
From now on, when a problem causes a BSOD or another major error that halts the system, the PC will not automatically reboot. Rebooting manually will be necessary.
If you're unable to fully start Windows Vista due to a Blue Screen of Death error, you won't be able to disable the automatic restart on system failure option as described in the steps above.
Try the steps below:
Just before the Windows Vista splash screen shown above appears, or just before your PC automatically restarts, press the F8 key to enter Advanced Boot Options.
You should now see the Advanced Boot Options screen.
Using the arrow keys on your keyboard, highlight Disable automatic restart on system failure and press the Enter key.
After disabling the automatic restart on system failure option, Windows Vista might continue to load. Whether or not it does depends on what kind of Blue Screen of Death or other problem Windows Vista is experiencing.
Since you disabled the automatic restart on system failure, Windows Vista will no longer force a restart when it encounters a Blue Screen of Death.
Now that you have the STOP Code associated with the Blue Screen of Death, you can troubleshoot the problem:
The following is the list of BSOD error codes with troubleshooting, you can find the troubleshooting steps using the error codes in the MS website also..
http://pcsupport.about.com/od/findbyerrormessage/tp/stop_error_list.htm
Hope this helped you. Please do rate me.
Thanks!!!!
Dec 21, 2010 | Computers & Internet
I am getting an error everytime after 5 minutes, w...
Could you please provide me the exact error message?
However to stop the system shutdown first follow these steps.
Disable automatic system restart.
1. Restart the computer and press the f8 key to open the Advanced Boot Options menu.
2. Select the Disable automatic restart on system failure option.
3. Restart the computer to accept this change.
Then go to safe mode
This problem occurs after a memory dump file (error log file) is written by Windows XP. Because the memory dump file flag not reset in Windows XP the memory dump file will contiue to be written every time Windows is restarted.
1. Restart the computer and immediately press f8 repeatedly. Use the arrow keys to select Safe Mode and then press enter .
2. Click Start , right-click Computer , and then select Properties .
3. Click Advanced system settings , grant permission to continue if prompted, and then click the Advanced tab.
4. On the Advanced tab, click Settings
  1. In the Virtual Memory section, click Change .
  2. For Paging file size for selected drive, click No Paging File , and then click Set .
  3. Click Yes after the following warning appears:
If the paging file on volume X: has an initial size of less than xx megabytes, then the system may not be able to create a debugging information file if a STOP error occurs. Continue anyway?
(X is the drive letter and xx is the amount of RAM installed on your computer minus 1 megabyte.)
  1. Click System Managed Size .
  2. Click OK four times to return to the Windows Desktop Screen and then restart.
For more information plz check the below doc from HP.
I hope this will definitely resolve your issue.
If not plz get back with the exact error message so I can give you better solution on this.
If you find this helpful then Plz vote for me..Dreamkam
May 21, 2010 | HP Pavilion dv6000z Notebook
Windows error code, my computer starts up gets to windows sign in screen you sign in and it turns back off. when I press the F5 key and try to boot from hard disk cd-rom or the other option it wont let me...
Please tap F8 continuously as the machine first boots up
Choose safe mode from the menu
Then click on start and all programs
Click on accessories and then system tools
Click on system restore and choose an earlier time
Choose a date before this started
Sep 07, 2009 | Computers & Internet
Window shut down automatically and restart, then shut down again... It happened after a window update yesterday lunch time.
Recovery SettingsOne of the things that is quite different about Windows XP compared to Windows 9x (9x is shorthand for Windows 95, Windows 98, and Windows Me in all their various versions), is that one can control how it responds to certain critical errors—those that cause the infamous Blue Screen of Death (BSOD). In Windows XP, the default setting is for the computer to reboot automatically when a fatal error occurs. If that fatal error only occurs when you're shutting down, the system reboots automatically.
If you haven't changed any of the system failure settings, you should be able to see the error by looking in the Event Log. But a better long-term solution is to turn off the automatic reboot so you can actually see the error when it happens—chances are it will tell you enough about itself to let you troubleshoot further. To change the recovery settings to disable automatic rebooting:
1.
Right-click My Computer, and then click Properties.
2.
Click the Advanced tab.
3.
Under Startup and Recovery, click Settings to open the Startup and Recovery dialog box.
4.
Clear the Automatically restart check box, and click OK the necessary number of times.
5.
Restart your computer for the settings to take effect.
Now when you go to shut down and a fatal error occurs, you'll at least see it and it won't cause an automatic reboot. You still have to sort out what's causing the problem, but that gets us to the next section quite nicely.
Nov 04, 2008 | Computers & Internet
It says file system error when i try to turn it on then it automatically shuts off. what can i do to fix the error?? It says File system error when I turn it on and then it turns itself
it says file system error when i try to turn it on then it automatically shuts off. what can i do to fix the error??
Nov 26, 2007 | Creative Labs MuVo V200 MP3 Player
Open Questions:
Computers & Internet Logo
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
