Question about Brother FAX-T94 Plain Paper Thermal transfer
DCP 1000 Brother Copier Replaced the drum and can't seem to get the display to reset the counter. It keeps indicating that it needs drum replaced soon. Followed instructions on the new cartridge. Still won't reset after numerous attempts.
    Problem Solver:
  • 19 Answers
With open front door take out the drum unit with the toner and put inside again, still open door press clear, the message replace drum? yes/not and is done!
Posted on Mar 20, 2009
I HAVE REPLACED TONER WITH THE CORRECT BROTHER TONER CARRTRIDGE AND THE MACHINE KEEPS TELLING ME TONER ERROR AND REINSTALL DRUM UNIT..HELP
Below are instructions that I have found from the internet. Hope that they will help.
  • Open the front cover of the printer.
  • Hold down the Go button for 4 seconds until all the LEDs light up. Then release the Go button
  • Remove the drum unit and toner cartridge assembly.
  • Replace the drum unit and toner cartridge assembly back into the printer.
  • Close the front cover of the printer
  • Your drum unit should now be reset
  • MFC / DCP PRINTER SERIES
    1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
    2.Replace the drum unit and toner cartridge into printer.
    3.The error message "Change Drum Soon/Drum end soon" will continue to appear if the drum counter was not reset when you replace the drum unit.
    4.To clear this error message, you need to reset the drum counter as instructed below.
    5.Make sure that the machine is turned on.
    For MFC users: To confirm you are installing a new drum, press 1. For DCP users To confirm you are installing a new drum, press the Up Arrow key
    7.When the LCD shows Accepted, close the front cover.
    8.Your drum is now reset.
    Resetting the drum unit will not improve print quality. It only resets your drum and allows you to continue to print. You decide when to replace the drum unit not the manufacturer!
Feb 24, 2015 | Brother MFC-8860DN Printer
How to reset counter in brother dcp6690cw
Sir/Madam
It's Very easy to reset counter in brother Printer,I suggest You watch YouTube video For Your Brother Printer Problem,I Hope You resolve and get all Brother Printer Help after watching this video URL Link below:
How to Reset Purge Counter on Brother DCP J315W Printer
Or
In case You still need Help I suggest You Follow Us On:
Brother Printer Support
Nov 13, 2012 | Brother Ink for Dcp-6690cw and Lc-1100
I replaced my drum and the output quality is poor and light in areas
did you clear the required counters and run required procedures? If not the machine still thinks it has a old drum because counter was not cleared only way copier will know it has a new drum
Mar 23, 2012 | Brother DCP 8060, 8065DN, HL 5240, 5250DN,...
When i first start my copies on my brother dcp 1000 they are clear by the time i get to copy 20 their are dark ink smudges on the paper. It seems when the copier starts heating up they smudges happen. I...
replace the drum,
( if you have used correct toner for refill because some time it happens if two different type of toner mixed up hence assuming that you have select gud toner).
vote me if found helpful.
Aug 17, 2011 | Brother DCP 1000 All-In-One Laser Printer
How to solve this problem "drum error "
The Drum must be replaced It cannot be reset. There is a chip inside which configutres the default page counter. regular and high yield drums available http://www.bizrate.com/ink-toner-inkjet-cartridges/brother-dcp-7030-drum/
Feb 12, 2011 | Brother DCP-7030 Digital All-in-One Laser...
How do you reset the counter when you replace a drum unit?
In Brother DCP-8460 procedure to reset the counter is:
Open front cover a push "Clear/Back" button and on the display show "Replace or change the drum" just choose Yes and push "OK" button.
I hope I helped.
Feb 03, 2011 | Brother DCP-8065DN Black and White Copier
Brother DCP 8060 is displaying drum near end what does thic mean
After approx. 25000 pages you should replace drum unit
This message would appear if the drum unit is near the end of its life. Use the drum unit until you have a print quality problem, then replace the drum unit with a new one.
This message would continue to appear if the drum counter was not reset when you replaced the drum.
To reset the drum counter, follow the instructions below:
  1. Open the front cover.
  2. Press the Clear/Back key.
  3. Press 1 to reset.
  4. Close the front cover, pressing firmly on each side until they click into place.
Oct 04, 2010 | Brother DCP-8060 All-In-One Laser Printer
Brother DCP 7020 Keeps giving me the "Drum Error" Message
Dear sir you see properly drum unite has a drum image sensor its demage so you change your copier drum unite, thanks.
Nov 17, 2009 | Brother DCP-7020 All-In-One Laser Printer
Have a brother mfc7440n and it keeps displaying "drum ending soon". have replaced the drum, but keep getting same display
You need to reset the drum counter.I'm not sure that working with your model but try it.
Try opening the front door cover and keep open. Then pressing clear, it should say replace drum, press 1 for yes, it should then say accepted, close cover and turn off.
Oct 08, 2009 | Brother Office Equipment & Supplies
Brother FAX-T94 Plain Paper Thermal transfer Logo
146 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
