Carrier Model 38LE048310CD Contact swith not
Carrier Model 38LE048310CD Contact swith not engaging when I manually push in everything works pulled all wires and put 24 volt-swith works it seems as the low pressure switch or an electronic board is the suspect. how can I test which part has failed
    Guru:
  • 587 Answers
If you put a jumper wire across the low pressure switch and unit runs then either the low pressure switch is bad or you are low on refrigerant. Then check to see if you have 24 volts from common to Y1 at the control board,if you do then it's the low pressure swtch or low on refrigerant, if not it's the board if you have 24 volts coming into the board on Y1 and Common.
Posted on Jul 04, 2010
I need a contact or for a carrier ac model #38en036320 but can't find the part#
You need to contact carrier customer service online or locally.
Aug 23, 2016 | Carrier Heating & Cooling
Model dgs6500. Why does it cut off when I push reverse pedal?
is it cutting out in reverse when the cutters are engaged??
some will do this as its a safety device, more modern machines have a over ride, be it on the ignition swith or a button or even a pedal
Apr 11, 2016 | Craftsman Garden
What is the weight limit for the Snugli baby carrier blue plaid model 26L5001?
Weight limit for the Snugli baby carrier blue plaid model 26L5001 is 26lbs. Though you can check its manual or their official site to confirm it or you can contact their customer care center. You will easily find out their number online on google. Baby Shop Melbourne Cheap Baby Cots Melbourne baby direct com au
Sep 23, 2014 | Evenflo Snugli Front & Back Baby Carrier
4 wheel drive will not engage
check the switch itself to see if power is passing thru use an ohm meter for best results..
Nov 11, 2013 | Garden
1202 fx phantom power swith will not stay engaged
The mechanical push on - push off latching mechanism may have broken. Probably the switch will have to be replaced.
Sep 02, 2012 | Behringer Xenyx 1202fx Mixer 12 Input 2...
Condenser Fan and Compressor not turning on.
Are you sure you have high voltage going to the unit? One wire from fan lands on top left of contactor, the other two go to C and Fan on capacitor. Manually push in contactor, if no fan than no high voltage.
Jun 05, 2017 | Carrier 38CKC060 Air Conditioner
Doesn't engage the blade
Try this: http://www.rootflags.org/wp/archives/45
I've been having trouble with my sunlawn too and so far that's the only solution I've been able to find.
Apr 10, 2010 | Suncast Sunlawn Light Weight Manual Reel...
Putting up
Your 3D will unfold. Push down with your
foot on the centre of the main lock to
engage it.Ensure that the secondary locks have
engaged on both sides, if not then gently
push down to engage them.Your 3D Pushchair is now erected.
hi jenifer_chis..hope this helps..here's a link where you can download the instruction manual..good luck!!
http://www.silvercross.co.uk/contact/instruction-manuals/
Jun 06, 2009 | Silver Cross 3D Stroller
Heating & Cooling Logo
57 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
