Question about Price Pfister 07-81PC Savannah 2 Handle Shower Only, Bell Showerhead, White
Price Pfister tub/shower facuet needs much force turn on and off
Price Pfister tub/shower facuet requires severe pull on center knob to turn water on for tub or shower head. Shutting facuet off also requires much pressure pushing on center control knob. Any suggestions as how to solve this problem?
Thanks for any solution you may be able to provide.
Gil Liedel
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 63 Answers
Call 1-800- p- faucet get new diverter
Posted on Mar 03, 2013
    Scholar:
  • 56 Answers
Put water off at mains . step 1.-open your i box mixer. step 2-u will see a 2 mm pin. mabe yours looks difrent. bt there were u change between bath and shower that button... that nob wil have a pin at the back. try to put q20/oil in there or sope. if that dosent work u will have to get a plumber in to unscrew the mixer and clean out the inside. not recomended if not a plumber bt if u do wane try it ur self and the sope and oil dident do the job let me know im a plumber will walk u threw it
Posted on Jul 08, 2010
Help! When I pull out the control stem on the tub spout to send water through the shower head most of the water continues to flow out through the tub spout. Is there something that I can replace or...
You can replace the assembly and not have to worry about taking apart the stem or, you can get a replacement diverter. The spout will twist off turning counterclockwise.
Jun 14, 2011 | Price Pfister 01-111 Shower Head, Tub...
Our shower head is very similar to the Price Pfister Savannah model. Recently we were forced to replace our water heater. As a result several faucets were blocked up with debris. We suspect that is the...
The simple method is to take the faucet head off the extension pipe that comes out of the wall. It will take two pair of pliers and a firm grip to take it off. Using a wet/dry shop vac at the supply end and a garden hose at the shower end, force water backwards through the faucet head.
Jan 02, 2011 | Price Pfister 01-81BC Savannah 3 Handle...
Hot watwer leaks from the hot side of the facet
Replace the stem assembly (ceramic cartridge) with Price Pfister service part #910-030. Be sure to turn water on briefly to flush out any debris in the valve body before installing new part. NOTE: this valve does not like old galvanized plumbing.
May 21, 2010 | Price Pfister 01-31xa Shower Head, Tub...
I turn on the spout for my tub and i turn the dial for my shower head to come on and it does, no problem, the shower head shoots water at full force, great water pressure, but there is still water coming...
I would look into the spout being the issue. The spout is a bypass when the shower is on and yours seems to be letting water get through. I would replace the spout..
Apr 27, 2010 | Price Pfister 01-311 Shower Head, Tub...
Price Pfister Shower--No water to shower
Does the tub spout water flow stop when the shower knob is pulled?
Was the systems pipping flushed before the shower head was installed?
It may be clogged, remove the shower head and then attempt to operate. If it is clogged you will see debris trapped in the screen at its connection point. The shower head can be disassembled - cleaned - reassembled
Is the shower head an adjustable type, that may be in the off position?
Good luck
Aduz
Mar 26, 2009 | Price Pfister Hanover 950-102S Soap &...
My 3 handle bathtub fauset [price pfisher] cycles hot and cold
You will need to either replace center "shower diverter"assembly or a quicker fix would be to remove old tub water fill spout and replace with a "pull up diverter knob" type water spout. Cost about 10 dollars Hdepot Pull Knob to divert water to shower when showering.
jthomefix
Mar 15, 2009 | Price Pfister Ashfield Widespread Bathroom...
Shower spout
There is a threaded stem that passes through the spout and attaches to the white plastic diveter valve. If you are starting from scratch (everything apart), you can put it back together in this order:
1) Place the white plastic diverter inside the spout. the circular side with the black round washer should face the the wall side of the shower (mating up against the threads for the water pipe).
2) The stem can now be inserted from the top and into the notched section of the white plastic diverter valve. The threaded end of the stem shoud be outside of the spout (from the top side).
3) A round black washer fits over the threads. It should sit right where the threads end. Dont push it all the way on to the unthreaded portion of the stem.
4) Screw the threaded knob onto the threads.
Should be ready to install now. Including the spout itself, there are 5 parts and are configured in this order from top to bottom.
1) Female threaded knob (the knob for operating the spout)
2) Threaded stem (threads on top)
3) Round black washer
4) Spout
5) Whit plastic diverter valve.
Mine leaks when I turn on the shower, thus reducing shower pressure. I looks like a poor design to me. The stem is not a tight fit in the spout and this allows the diverter to "wobble". The washer on the diverter valve does not seat tightly and allows water to leak out the tub spout when showering. I would replace the spout.
Jan 30, 2009 | Price Pfister 01-311 Shower Head, Tub...
Price Pfister 07-81PC Savannah 2 Handle Shower Only, Bell Showerhead, White Logo
212 people viewed this question
Top Price Pfister Home Experts
Mike
Tim Whalen
Are you a Price Pfister Home Expert? Answer questions, earn points and help others
