Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
My rca has a tube hanging down
My rca D52W20BYX1 model # F045C10AB would turn off and then back on, then it wouldn't turn at all it looked like sparks inside the foam screen below and there was a crackling noise, we took off the front foam screen and it looks like a tube is hanging down in the center.
  • 93 Answers
SOURCE: RCA HDTV Model # HD52W59
I hope it is still under warranty,cause you need to either fix the problem with a A/V repair guy or return it and get your money back.
Don't fool around with it.
solutiondoct
Posted on Nov 06, 2008
  • 1030 Answers
SOURCE: Rca dlp tv popped crackled and no picture today.
just might be the bulb. Have you unpluged you set make sure its cooled down and remove the buld examine the bulb ussally when the bulbs go bad they shatter not always but it good to check them out as the first step
Posted on Nov 17, 2008
juanfix
  • 31 Answers
SOURCE: 52 inch RCA TV Model P52755BA about 12 yrs old
probably you have glycol leaking on the anode lead, in one off the pic tube, check for wets spots, or pay attention on the chassi where the hv leads are located, be careful
Posted on Dec 02, 2008
ladywinn
  • 5138 Answers
SOURCE: Need a Power Supply / Deflection Board for a RCA D52W20BYX1 TV
Try UED www.ued.com or call 1-800-648-6657
Posted on Dec 22, 2008
SOURCE: have a 06 rca hd61w66 powers on but screen dont
Thats the Power Supply. You need to call a service man, please disconnect this unit from the Power, It is dangerous to leave it plugged in. what is happening is the set has developed a serious fault, to avoid a fire or explosion, the PSU has shut down the set. that noise you hear is the power supply struggling against the fault. trying to start. Please for safeties sake, get a "Quote" from a reputable, preferably an RCA recommended service centre.
Posted on Mar 28, 2010
Testimonial: "i have it unplugged! thanks man i will try to get ahold of one "
Hello, I have a 52in RCA projection tv, model D52W20BYX1. It used to work fine but now whenever i try to turn it on it the power button light turns on and the tv makes a short whistle sound, this happens...
Not sure why chat got closed/ disconnected.
There is big transistor TL010 attached with heat sink near flyback transformer, this is horizontal output transistor, check it and replace if found shorted.
Thanks.
Apr 08, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an RCA F36669 tv that doesn't stay on.
look to see if the wire is in tv. unplug there 28000 volts there and it hurt use a long handel sew drive to find out unplug tv
Jul 08, 2010 | RCA F36669 36" TV
D52W20BYX1 Green problem
I would go back to green tube disconnect ,unplug CRT board to green tube if set stays up playing its the tube.
Sep 19, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv went off and won't come back on.
the arcing sound is some kind of high voltage leak, which will shut down the tv. pull the speaker grill off and the access board, look at the 3 picture tubes, turn the set on you will see where the leak is, it's usually the high voltage splitter, which has a high voltage wire going into it and 3 high voltage wires coming out going to the picture tubes, if it arcs from the splitter you need to change it, if it arcs from one of the picture tube wires you need to pull the tube out and fix the high voltage leak, and possibly a cooling fluid leak caused it, not an easy reapir, you probably need a repairman.
Sep 08, 2009 | RCA P52926 52" Rear Projection Television
My RCA D52W20 turn on with a blue screen and then turns off within 3 sec's. It goes off like someone has switched off the TV. The light blinks and goes off. Can anyone help
Your blue tube has a short. What you are seeing is the TV turning on and the blue tube going to full brightness. It then draws enough current that the television's protect circuits shut it down.
Need the full model number which should include a BYX or just YX followed by a number. Going off the D52W20BYX1 the blue tube would be part number 263049 which https://www.encompassparts.com still has a few for $220 before shipping.
Jun 29, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca model D52W20BYX1 comes on for a moment then goes off rite away
rca model d52w20byx1 itc222. sounds like shutdown mode. Does the led flash. unplug the set leave set unplug for 30 min. this reset procesor. now i tell you this in the shop its never that simple but it first step. IF you have a flashing led when you push power button. it tells you alot. it tells you main fuse is good the processor is getting power and it detects something wrong. leading causes are shorted horzontal output transistor. shorted cp150 capacitor. technicians have a computer that read error codes much like that of a car. let me know if i can help troubleshoot it down.
Nov 23, 2008 | Televison & Video
Screen lookes like colores separating
Here's all I find regarding bad convergence from the techrepairCD:
RCA ~ITC222 D52W20~Convergence bad~~~ITC222~Replace leaky DL032 on
deflection board~~~~~~
RCA~D52W20Y ATC221~Convergence goes out/bowed after on for a few
minutes~~~ATC221~Problem may be on the deflection board. Was unable to
pinpoint where in this case.~~~~~~
RCA~D52W20BYX1 ITC222~Convergence way off after replacing small signal
board~EEPROMS were transferred over to new board~~~IK210 was
defective..transfer the new EEPROM back over.~Remember on these
sets*when replacing the SSB* if there is a small P on corner of
screen*hold volume on remote for 8 seconds after it reaches minimum.~~~~~
RCA~D52W20BYX1 ITC222~Can not align blue convergence* bottom really
bowed* possibly either color after replacing SSB.(Or no auto
convergence.~(Service menu: turn power off for 30 seconds* press vol dn
and ch dn* simultaneously for 8 seconds* set turns on with service menu
options)~~ITC222~In service menu* select convergence. If sensor
calibration was performed when convergence was too far off* it will not
alighn.~Get crosshatch with straight lines* perform sensor calibration*
then attempt convergence alignment again. Be sure to store settings*
then do sensor calibration again.~You must get a green flash of the
screen after sensor cal and a check in the box. RED flash indicated
convergence settings are too far off~~~~
RCA~D52W20BYX1 ITC222~no convergence correction~~~ITC222~LP650
(259271) DP670 (259246) & RP632 (259564) 4.7 3W on convergence power
supply board~~~~~~
Oct 28, 2008 | RCA R52WM24 52" HDTV Projection Television
Check HERE and provide the vendor with the chassis number as well.
The model number helps but the chassis number is very important.
Good Luck.
Mar 05, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
57 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
