Question about Scotsman DCE33PA1BC 15in Built-in Automatic Ice Machine/Maker w/ Drain Pump, Black
I have a scotsman DC33A-1W undercounter ice maker it some what makes ice but after it falls in the bin it dont keep an now it dont make ice
SOURCE: scotsman EC 105 - Bin full!
change the sensor ................
Posted on May 14, 2008
  • 52 Answers
SOURCE: Ice maker makes hollow ice! Why?
Not getting enough water into the ice maker. Could be a partially frozen supply line, restricting the total water input, or it could be that the timer needs to be adjust.
If the water supply tube to the icemaker is frozen. It will be a white rubber tube on the right side of the icemaker. Warm it with a hair dryer, remove it from its aluminum tubing, and make sure there is no ice all the way back to where the supply tube comes from the water valve. After thawing, your icemaker should start working again.
Now..... why did it freeze? Most likely, there is a restricted airflow to the back of the unit, which is need to keep that aluminum supply tube just warm enough to assure all the water flow OUT of it into the icemaker, and doesn't freeze up on contact. Make sure your coils and the airspace under the fridge are completely clean (vacuuum them well) and it should cure the problem.
To adjust the timer, follow the instructions here http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Posted on Jul 17, 2008
SOURCE: Whirlpool Side by Side Ice Maker Not Making Ice
If you have the type of ice maker that has an ice bin on the freezer door, then there are instructions available at www.AnyoneCanFixIt.com to fix the ice maker problem. They also sell the part that is sometimes required to repair this common problem on the ice maker. The problem is notorious on these refrigerators that were made around 2004 and later. The ice maker will usually go out within 1-2 years. They have redesigned a part to eliminate the problem.
Posted on Jul 31, 2008
  • 102 Answers
SOURCE: Our Scotsman ice maker is making ice but is not
is the drain running clear is the condenser clean and are both spray nozzles in place?
Posted on Aug 06, 2009
  • 33 Answers
SOURCE: Scotsman Ice Maker CME 256
descale bin level sensors, check for corrsion on wire harness. if does nt work. replace . bin level sensors
Posted on Aug 26, 2009
How do i get a service manual?
The bin sensor eyes need to be cleaned or replaced. First remove the front cover then remove the white plastic ice deflector shield. Now you should be looking at the evaporator plate look down you will see the water sump tray full of water in that tray is a black plastic grate that when the ice is harvested it drops and hits the tray keeping it from falling in sump tray PULL it OUT. now just behind the sump where the ice falls through opening on the left and right sides is where the ice full bin eyes are you can pull them out side ways there is plenty of wire so you can pull them up to where you can clean them with a soft cotton cloth with scotsman cleaner. Now for a manual goggle scotsman service manuals you can get a PDF file.
Apr 28, 2014 | Scotsman Ice Maker 600LB CM3 30inW...
Cant find eyes that sense when the bin is full
Pull front cover off, pull the white plastic deflector off which covers the cube plate, pull the gray plastic ice deflector which sits in the water sump tray. now reach back and down where ice falls through into bin on each side and pull them straight out to the side. You can locate them buy following the wire from the controller to the bin eyes.
Sep 28, 2013 | Scotsman Ice Maker CM3 30inW Cubed Ice...
How do i get to the sensors for full bin to clean cme506as-1d
Remove front cover, remove ice deflector shield, remove the plastic grate in the sump tray that keeps ice from falling into it. Now just behind the water sump tray where ice falls into bin on the right and left side are the bin full sensors you can see where the wire runs through cabinet from controller to them. grab them and pull straight out to the left and right some times you have to wiggle them while pulling. There is plenty of wire on them so you can pull them out and clean.
Mar 24, 2013 | Scotsman Cooled Modular Contour Cuber Air...
I have a Scotsman Cm3 which will not stop making ice. When I come back to work in the moring and open the door, ice falls all over the floor. Is there a way I can fix this?
Is the ice building up into the ice head enough to break the beam on the bin sensor. if so replace the sensors. if ice is not up far enough shut machine off remove plastic grid reach in and down to where bin sensors are and watch to see if light blinks on and off if so they are good. next step check the bin there should be a white ice deflector with 3 thumb screws in the top of it make sure this deflector is mounted so it makes the ice build up high enough to cause ice to reach bin sensor. if the sensor is not seeing ice then it will let the machine keep making ice. If this is all working good then replace the service controller but make sure you look on the back to set the right model program for your machine.
Sep 16, 2012 | Scotsman Ice Machine, Cuber, 1930 lb....
Scotsman ice maker cme1356 remain on harvest
Check bin full sensors make sure that the wires are making good contact on the board and make sure they are working run your hand between them you should see the bin full light come on the board if not replace the bin full sensors. If the light comes on then replace the board.
May 25, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Where are the bin full sensors located for cme256ws-1c full light on will not make ice
The bin full sensors are located behind the water sump tray. Pull the front cover off remove the white plastic guard. Remove the ice deflector grate that is in the water sump tray. Now look where the ice falls down into the bin to the right and left side there is where the bin sensors are you have to pull them sideways you can also open the control panel and look where the bin sensor wire runs and follow it. pull the bin sensors and clean the eyes or replace them.
Jan 03, 2012 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Should a scotsman ice machine automatically stop making ice once the bin is full
Yes, all ice machines have a means of automatic shut down when the bin is full. What is the model number of your machine and your bin?
Dec 16, 2010 | Scotsman Ice Machine, Cuber, 1930 lb....
Scotsman DCE33PA1BC 15in Built-in Automatic Ice Machine/Maker w/ Drain Pump, Black Logo
891 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Tim Whalen
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
