Question about Nakajima AE-710 Typewriter
The ribbon cassette is stuck to the far left and the machine is constantly beeping.
    Genius:
  • 1,218 Answers
Remove the ribbon cassette and verify there is a print wheel in the machine."don't put the ribbon back in yet. Push the carriage part way over to the right, stop, then switch the power on. The carriage should go to the LHS and the print wheel should "home" itself. If the unit is beeping at this stage...check the flex multi stand cable coming from the carriage. On earlier models the wires could sometimes break a couple of inches from the carriage. The carriage and cable will have to be replaced if this is the case.
Posted on Aug 18, 2010
How to change the correction tape?
Changing the Correction Tape
1) Move the print carrier to the center of the platen using the SPACE or BS key.
2) To replace the correction tape, lift out the typing ribbon cassette (see Changing The Ribbon Cassette) and remove the two spools of the lift off tape by pulling them outwards.
3) Place the empty spool of new tape on the left pin so that the tape winds clockwise. Place the tape around the left guide. Pull the tape around the right
guide and place the loaded spool on the right pin so that the tape unwinds counter-clockwise.
Note: Make sure the sticky side of the tape is facing the platen.
4) Manually turn the left-hand spool in the clockwise direction, tightening the tape until resistance is felt.
5) Replace the typing ribbon cassette.
6) Press the CODE + = (SETTING) key.
Changing the Ribbon Cassette
2) Hold the ribbon cassette on both sides and lift up the front portion (where the ribbon is exposed) to remove the cassette.
3) To insert a new cassette, place the back end of the cassette on the cassette
holder on the carrier and gently press down on the front of the cassette unit it clicks into place.
4) Turn the ribbon feed knob counter-clockwise again to take up any slack in the ribbon.
5) Presss the CODE + = (SETTING) key.
Good Luck!
Oct 13, 2010 | Smith Corona Wordsmith 100 Typewriter
This typewriter has not been used in years. Every time I plug it in though it starts beeping. Why?
Take the chrome bar that is inside where the carriage is(the assembly the ribbon goes on) and put light weight oil on both sides of it and move it back and forth so it will free it up.There are two bars in it. Put the oil on the bar toward the back and put white grease on the one that is closest to you. This should take care of it. If not make sure the hammer is pressed all the way up against the card scale.(black lever on the left) and that you have ribbon left in the cassette. Kevin
Jul 09, 2010 | Swintec 7040 Typewriter
The keys on the left side of my circa 1933 Royal typewriter gets stuck on the ribbon everytime. Also my ribbon doesn't advance. Help?!
Hi:
The most likely problem is there is dirt inside the ribbon basket. This is the area where the type bar (this is the bar with the actual letter on it) ends. They all fit into a semi circle area. If you can find something very narrow and thin with a hook on it you can use it to clean out the areas where each type bar goes. Then try to lightly lube the entire basket right where the type bars pivot with something light like sewing machine or 3 in 1 0il. As far as the ribbon reverse goes it might be as simple as making sure that the ribbon is being fed through the ribbon reverse forks which are usually located left of each ribbon spool.
Good luck
Andrew
Jun 28, 2009 | Royal ET510 Typewriter
Nakajima AE 800 will not underline words with new ribbon
Check to be sure the ribbon is fully down and latched, also be sure the L/O tape is not sitting to high and stealing the underscore.
DickyO
Mar 25, 2009 | Nakajima AE-800 Typewriter
Kenmore oasis dryer cycle signal beeping constantly
This symptom indicates a stuck key on the user interface control board.
Replacing this control board would most likely fix this type of problem.
You can order this part from SearsPartsDirect.com, RepairClinic.com, PartSelect.com etc.
Before buying any parts I suggest you access the interface ribbon and disconnect it and then connect it back and see if there is any improvement.
You might also remove the interface from the console and check the console for any stuck buttons.
Remember to unplug the unit first.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 18, 2009 | Kenmore Elite HE4 Electric Dryer
Ribbon replace on ibm selectra 2
Lift top cover up.
Move the carrier to center of machine.
On the right hand side of the carrier there is a red lever. slide it to the left.
( it will lift ribbon arm's up & move the ribbon drive mecanisem out of the way.)
you now can lift the ribbon cassett out of the machine,
put the new ribbon in the machine.
there is a wire with a white plastic roller around it on the left side of carrier. make sure the ribbon goes on the out side of the that wire.
put the ribbon throuugh the lift arms
turn the knob on ribbon till the colored led is in to the ribbon cassett + a few turns of the black ribbon is around the spool.
slip the red lever to the right.
close cover & try typing
hope it works for you
Feb 08, 2009 | IBM Wheelwriter 30 Typewriter
IBM Selectra III typewriter
There are two different ribbons for selectric III T/W's. One has the ribbon guides as part of the cassette the other the guides are part of the machine.
Be sure the ribbon and L/Oare installed properly and the ribbon is winding on the take up spool properly (counter clock wise) and if the guides are in the machine id to the left if thr white slacker finger just L. of the ribbon also be sure the L/O tape is behind the black seperation finger and the ribbon is in front of it (just to the rt. of the opening in the plastic card holder).
DickyO
Oct 30, 2008 | Lexmark Wheelwriter 15 Series II...
Beeping sound when powering unit on
Have you simply pushed the carriage back to the middle? If it is like the ML100 (it looks the same) you can just push it over ...with the pwoer off. Then put in you new ribbon. And this time, when you turn it on, it is the new ribbon that hits a switch on the underside of the keyboard, located to the upper left. If you do not have a ribbon installed, it will travel all the way to the left, and beep, beep, beep, beep. ,,,, The switch is hit with the ribbon housing.
Jun 25, 2008 | Brother ML-300 Typewriter
Fault code c-31:22
your needs repair in mechanism..Fault given is undetected reel motor rotation .This can be caused by a bad captan motor ,pinch roller bad or bad LS chassis ribbon from upper cassette mechanism.If unit has old type (B) mechanism ,there is a good change LS chassis ribbon is bad .When cassette is inserted and pushed into mech .The latch for LS chassis wears down ribbon and causing a sensor fault ..
Dec 05, 2007 | Sony Handycam CCD-TRV208E Camcorder
F0 error - My GE Over displays an F0 error & constantly beeps
Appu, the F0 error for this built in means there is a shorted or stuck off key. Sometimes this can be resolved by removing the keypad ribbon cable from the board and cleaning the ends with an eraser. If that doesn't work, you want to find out whether its the board or keypad by ohming the ribbon cable, 3 to 4, probes on the conductor side...should read 125 to 1750 ohms while pressing the off key. Catriver..post back.
Apr 29, 2007 | GE Profile JK915 Electric Single Oven
Nakajima AE-710 Typewriter Logo
119 people viewed this question
Top Nakajima Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Are you a Nakajima Office Equipment and Supply Expert? Answer questions, earn points and help others
