Recently replaced batteries for remote. No longer have manual for codes to use on sony. i also have a digi box connected to sony tv. Can u help?
  • 1,557 Answers
The international code for sony is 001
Posted on Jul 04, 2010
Why won't television turn on with remote control?
Check the remote control for its infrared emission. Check it with fresh batteries. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
http://electrohelponline.blogspot.com/
Sep 12, 2014 | Sanyo DP26640 LCD TV
Tivax STB-T9 DTV converter - remote control audio buttons no longer controlling TV audio
Maybe the remote got dropped by the cleaners. If you could control volume with the remote previously and now can't, I suspect the remote needs to be replaced.
Jan 26, 2014 | Televison & Video
How do i put it on channel three manually?
If the remote to your box can be paired with your tv then you should be able to fix this problem simply by pairing digi remote with tv and while in tv mode on remote, hit the input button. That should change tv back to cable/antenna setting so that you may access channel 3. Hope this was helpful.
Jan 27, 2010 | Symphonic T19WF 19" TV
Is there a universal code to use for the zinwell digital to analog converter box? I have a oneforall remote URC-3220
I can help you to program your One For All Big Easy URC-3220 Universal Remote to control your Zinwell Converter Box. I recommend using the remote's code search function.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Downloading the URC-3220 users manual / owners guide. This contains all the codes for the brands of devices your remote can control.
I hope that helps.
Dec 19, 2009 | Digi Zinwell ZAT-970A tal TV Converter Box
GFM TELEVISION! THAT IS THE PROBLEM
have gfm 26" hdtv. remote was dropped on tile floora and no longer worked. no universal remotes will work - not even gfm's. went to remotes.com on the web. orig. remotes no longer mfgd. replacement unit is $39.95. worked right out of the box. batteries were in the unit. no muss, no fuss, no codes.
Aug 02, 2009 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Cox Cable Remote wont program to my Sylvania LC320ss8 tv.
there are different codes for the devices that you are using. When you want to insert the code for the tv. > Switch tv on and then switch all the other devices off. Insert code. For digi box > switch on and all other devices off. Insert code for digibox. You must then switch between tv and digi box using the buttons on the top of the remote. Toggle between tv/ digi box.
Have a go with the codes below with the tv and the digibox both on, you never know you might get lucky as these are new codes, if not revert back to 1st solution.
Universal Codes (both should work using these, i think!!!!! try 'em)
002,
008,
155,
198,
227,
231
Here are the codes for the 1st solution.
Good Luck,
Hughie.
Tv
0062
0004
0009
0135
0189
0183
1141
0227
0456
0008
0068
0075
0141
0161
Digi Box.
0899
0227
0287
0290
0225
0456
0251
0292
0236
0458
1106
Jun 18, 2009 | Sylvania LC320SS8 32 in. LCD Television
RCA TV/VCR combo T13060GY won't go below channel 5
I had a similar trouble with a couple of tv sets, one was a Granada and the other a Sony, but once connected to the satellite or digi-box via the scart socket it seemed to concentrate it's mind and override all the channels - so the tv stops being a tv set but becomes a monitor displaying whatever analogue video signal the digi-box sends to it.
The channels should arrive from the satellite receiver/decoder box and that remote control is all you need and the only thing you need to touch the monitor tv for will be the volume...
Scart sockets and plugs are apt to become dirty and unreliable and are responsible for many problems, including once a blue screen.
May 28, 2017 | RCA T13060GY Combo
LOst manual to setup Sagem ITD59g digi box.
press menu installation, then tap in 1,2,3,4 on remote for access code then choose user setting to take you to tuning menu
Mar 05, 2009 | Televison & Video
DVD recording.
Sounds like the DVDR is recording from the digi-box through the TV, so when the TV is switched of or into standby the signal is lost, causing the recorder to pause.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
Feb 05, 2008 | Philips DVDR3380/05 DVD Recorder
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
