Question about Magellan RoadMate 1340 GPS Receiver
I can't get past the opening screen. Tried the soft reset, holding switch for 10 seconds, both on and off. Can't get to screen for hard reset.
  • 6,487 Answers
Base from the description of your problem, there;s no way we can perform a hard reset on the unit since there;s no reset button on this particular model, the problem here is a corrupted software and can only be resolve by taking this unit to a service center for repair.
Posted on Jul 04, 2010
When turning on, all I get is the green android logo. Then the android word comes on and nothing else happens. It never opens.
Try holding the on button for about 10 seconds then release. Wait a further 10 seconds and switch on as normal. This soft reset often (but not always) frees up a frozen screen.
Good luck.
Sep 14, 2015 | Tablets & eReaders
Tip
How to reset your Garmin Edge 205 or 305
Edge 205 or 305 often crash, then impossible to power on again.
Here is the way to reset the Garmin edge :
Soft reset : hold mode and lap/reset buttons for 10 seconds
Hard reset : device should be powered down, hold start and mode buttons for 3 seconds then pulse press the lap/reset button.
After soft reset, you need to hold start button for up to 10 secs before it starts.
After hard reset, you will loose all your data, including profiles.
on Sep 05, 2010 | GPS
How do i factory reset a coby kyros mid8024?
There are two methods of reset Coby Kyros MID8024:
1. Soft Reset
2. Hard Reset
Steps for Soft Reset:
  • Take out the battery.
  • Reinsert the battery.
  • Press and hold the power button for 10 seconds.
That's soft reset. If your device doesn't load after this, try hard reset.
Steps for Hard Reset:
  • Switch off the device.
  • Press and hold Volume Up + Home Button + Power Key.
  • After 2-3 seconds, release the Power Key.
  • You will enter boot screen, Select Wipe Data / Factory Reset.
  • Select Yes.
This will delete all the files including apps, personal data stored in phone memory. Don't worry it doesn't wipe off the SD Card so you should make a backup of your files stored in phone memory.
Apr 15, 2015 | Coby kyros Tablets & eReaders
How do i reset my asus transformer tablet tf101 i have a blank screen will not turn on
Perform a soft or hard reset on your Asus Eee Pad Transformer Android tablet if it is not functioning correctly. Here's how.
Soft Reset
You would want to soft reset the device in the event that it has become frozen or unresponsive. To do so, press and hold the Power button on the top-left side of the device for about 10 seconds until the device powers off.
Hard Reset
A hard reset (also known as a factory reset) will clear all data and settings from the memory of the device and set it back to factory default settings. You can perform hard reset on the Asus Eee Pad using the Android OS menus or the hardware buttons.
Method 1 1. Power the Eee Pad off.
2. Press and hold the Volume Down button on the left side of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
The Asus Eee Pad will complete the hard reset process and reboot into a factory default state.
Method 2 1. Open the Settings app.
2. Select Privacy.
3. Choose Factory data reset.
4. Select Erase tablet.
5. Select Erase everything.
Dec 31, 2014 | ASUS Eee Pad Transformer TF101A1 Tablet...
My nobis pc tablet wont get past the second loading screen
Do a hard reset. Hold the power button down for twenty seconds. This is a hard reset if this does not solve the problem I recommend returning it as this is more than likely a manufacturer issue
Jan 24, 2014 | Tablets & eReaders
I have a Dell axim x5 and it is stuck on a blue screen with the Dell logo. I have tried a maste reset like hold the power botton and the reset for 2 sec but after that i get a screen with the option clear...
Perform a Reset
Soft Reset
When you perform a soft reset, the device deletes any data that has not
been saved but saves any data that has been stored in memory. Try
performing a soft reset if the device does not respond when you tap the
display or press a button.
To perform a soft reset, use the stylus to press the reset button.
Hard Reset
NOTICE: When you perform a hard reset, you lose all the data stored on
your device.
Perform a hard reset if:
• You want to delete all the data stored on your device.
• You forget your password and need to clear it.
• Your device is experiencing severe operational problems and you have
already attempted a soft reset.
NOTICE: It is strongly recommended that you back up your data before you
perform a hard reset. See ActiveSync Help on your computer for more
information.
To perform a hard reset:
1 Press and hold the power button.
2 With the stylus, hold the reset button for about 2 seconds.
3 Follow the instructions on the screen.
Feb 12, 2011 | Computers & Internet
Used my garmin edge 305 today on the ride, it worked fine, powered off after the ride. Got home turned on to review my stats and then powered off and went to upload and wouldn't upload, so tried to turn it...
Jan 30, 2011 | Garmin Edge 305 GPS Receiver
My Edge 305s GPS is not working. Everything else runs perfectly fine, it just will not acquire any satellites. I tried a soft reset. It won't let me hard reset though.
Hard reset is not very easy, so follow carefully instructions above.
Now simple advice, did you check in your parameters that the GPS transceiver is turned on ?
There is a mode with GPS off, don't ask why ...
Refer to your manual to find the menu.
Nov 22, 2010 | Garmin Edge 305 GPS Receiver
I put the 305 on the charger at night and I see the charging in progress message. When I wake up it is blank and the unit will not power up? It's like the battery is dead and it won't respond to the...
Over charging sometimes does that effect.
However, best is reset the device. Try soft reset first, if not sufficient, try hard reset.
Soft reset : Hold mode and lap/reset for 10 seconds, then release.
Hold start button then for 10 seconds, device should restart.
Hard reset : Hold mode and start button. 10seconds after, still holding them, pulse press lap/reset button, then release all.
You should get a screen asking to confirm reset to factory settings. You'll loose all data by this, but device should restart with normal behavior.
Sep 26, 2010 | Garmin Forerunner 305 GPS Receiver
The screen has frozen and I can turn it on or off I tried the reset button but that doesnt work either
There are two types of Reset are present
1)Soft Reset.
2)Hard Reset.
Just pressing the Reset button using compass or needle will just do soft reset,It is not more effective in this case.You have to go for Hard Reset.
Hard Reset:All the data's will be lost once you do this.but will solve your problem.
Hold Reset for 5-10 seconds.
Flip power switch quickly 3 times. If this doesn't work.
check the light next to the power switch. If it is flashing yellow, do the same steps. It might take up to two to four tries.
Please do rate the solution if the issue is
resolved or post a comment for further
assistance.
thank you for using fixya have a nice day:-)
Aug 01, 2010 | Sony Reader Pocket PRS-300
Magellan RoadMate 1340 GPS Receiver Logo
1,382 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
