Question about Whirlpool CGM2751KQ Gas Commercial Dryer
I have a Whirlpool Heavy Duty Commercial Gas Dryer, Model #: GCGM2991LQ0. It is not allowing the gas to ignite the glow bar. The glow bar appears to be red hot, but nothing is happening. What am I missing?
  • cynthia miller Jul 05, 2010
    Thank you for your knowledge and expertise! The Pictures with parts labeled were extremely helpful. And, it turns out that the solenoids were the problem, as well as the thermal fuse. Thank you, again, very much. Sincerely appreciate your help!
    President:
  • 1,554 Answers
First, make sure the shut-off valve is open and there's gas being supplied. After these two are ensured and the glow bar glows red hot but still no gas is being ignited, replace both valve solenoid coils. The solenoid valves do not work simultaneously but rather in succession. No gas then will be ignited if one the valves do not work and both solenoid coils must be replaced.
Pull the lint trap out then remove the screws under it.
Pry the top cover as shown then raise it to the rear of the dryer.
Remove the screws attaching the front panel to the cabinet then lift and remove the panel. Replace the solenoid coils then reassemble the dryer in reverse order of the disassembly steps.
Posted on Jul 04, 2010
I have a Frigidaire gallery commercial heavy duty dryer model #GLGR331AS1 it just stopped heating turns on and runs but no heat. Could it be the solenoids or the igniter ?
If the igniter glows but it doesn't ignite, most of the time, it's the valve coils, most of the other times, it's the radiant sensor.
If the igniter doesn't glow, check your thermal fuse. If your thermal fuse is good, replace your igniter.
Oct 21, 2014 | Dryers
Whrilpool heavy duty dryer not drying, just replaces the ignitor
Im assuming that you have a gas dryer since you said you replaced the glow plug (igniter). So your problem is most likely with lint in the vent hose. Try taking it off and shaking out all the loose lint. If thats not it you could have a gas flow problem. Check your connections for leaks or crimps in and metal hosing.
Dec 12, 2009 | Whirlpool Dryers
Gas Dryer igniter glows but does not ignite
If the igniter goes on but only cycles off you have a bad solenoid coil on the valve you can pick them up as a set at a local parts supply shouldn't be more than $25
Sep 04, 2009 | GE DDC4500S Gas Commercial Dryer
Whirlpool gas dryer "ultimate Care 2" does not dry my clothes.
yes, the gs coil is not opening. Go to www.repairclinic.com put the model number in and get the gas valve.
Aug 31, 2009 | Whirlpool LGB6300 Gas Dryer
Dryer repair
There is no pilot. It is electronic ignition via a glow bar.
Remove the front panel. The glow bar and gas valve will be on the bottom right side.
What is your problem?
May 20, 2009 | Whirlpool LGR5636L Gas Dryer
Whirlpool dryer not heating up
It does not have a pilot. It uses a glow bar ignition system. You probably have a bad glow bar if it is not heating at all part number 279311
Apr 06, 2009 | Whirlpool LGR3624JQ Gas Dryer
Gas Dryer blowing cool air and will not heat up.
Look inside door and get the model number for me. Could be igniter, gas solenoids or temp control switch inside. Let me know, Thanks Sea Breeze
Mar 19, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Burner comes on for 30 secs or so and shuts off. Ignitor cycles
it sounds like the gas valve solenoids are shorting out. there are two coils that operate in tandem to allow gas flow. these coils can eventually overheat and cause the gas not to flow as well have a rattling sound from the plunger inside the coil trying to move inside the weakened coil. the coils can be replaced and will come in a pair with guide pins to help you put them in correctly. one coil will have three wires going to it and the other coil will have two wires going to it. pretty simple fix and should solve the problem
hope this helps....jay
Mar 06, 2009 | Whirlpool LEQ9858P Electric Dryer
Gas dryer with gas smell and no heat
It sounds like your GLOW BAR gas igniter is bad. This is an electric powered heater coil that , when it glows red hot, ignites the gas burner. This part normally fails at least once during a dryers normal service life. If you are handy, you may be able to replace the part yourself. Otherwise, have a technician look at it. If you want to DIY, go to an appliance parts store . Remove and observe the GLOW BAR from your gas dryer. If one of the metal element appears to be burned open,replacement is necessary.. Show the part, along with your dryer maker, model, and serial number, to the store employee. This person can give you helpful info along with a new part. If the GLOW BAR is NOT burned out, seek out a technician.
Aug 29, 2008 | Bosch Nexxt WTMC3521UC Gas Dryer
Whirlpool Gas Dryer
Yes, that is most likely the problem. Once the glow bar igniter glows so hot, the switch opens & drops power to the igniter.(The radiant sensor has continuity while cold & open when a flame is present.) At the same time, by opening it redirects power to the valve coils allowing them to open & gas flow to the burner assembly. The dying glow of the igniter fires the gas. However, if your igniter glows, the radiant sensor is good. In this case, you'd need to replace the gas valve solenoids.
Aug 01, 2007 | Whirlpool LGR5644J Gas Dryer
Whirlpool CGM2751KQ Gas Commercial Dryer Logo
78 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
