Question about Frigidaire FRT21G3CW Top Freezer Refrigerator
Puddle of water in bottom of refrigerator
It doesn't happen all the time. But for no reason a puddle of water shows up in the bottom of the refrigerator.
    President:
  • 1,891 Answers
The drain in bottom back of freezer is pluged rsome hot water through it . ( use a turkey baster ) .. this should correct problem .. mm
Posted on Jul 04, 2010
Testimonial: "It would seen you were right. Thanks. The only thing I wasn't sure of was how to get to the drain. That would have made the job go a little quicker."
Why does my double doors/GE/culligan refrigerator leak water at night
there will be a drain at the back of the fridge down the bottom there is probably something caught in it blocking it causing the water from the evaporator in the fridge to run out instead of down the drain
May 22, 2014 | GE Refrigerators
I have a frigidare 20.6 frig. approxiamately 10...11 yrs old im find water puddles on top glass shelf and bigger puddles at the bottom I cleaned as much as I could the fan is working help model...
Hello Donna, I am happy to assist you. I understand that water is collecting in your refrigerator. Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
I certainly hope this troubleshooting tip resolves your concern. If you have any additional questions, please feel free to respond.
Aug 03, 2013 | Frigidaire Refrigerators
My matag model # mzd2766ge side by side has been leaking water on the floor. This happens only sometimes but by the time we notice its a big puddle on the floor under my cabinets. is something blocked up...
if it has ice/water in the unit,check the hoses going from the supply line at the inlet valve on the refrigerator rear section,if theres a hole in the tube,when the ice maker calls for water to fill the ice trays it will leak out this pin hole during the time the water supply valve is open and then shut off when the valve closes due to no pressure on the line then,thats probably the reason the puddles not always there
May 13, 2011 | Maytag MZD2766GES Side by Side...
There is water leaking in the freezer. I imagine it is the ice maker. There is an "ice puddle" on the bottom level and occasionally water seeps out onto the kitchen floor. Is this easy to fix for a...
my model is not exactly the same but check for this this anyway:
Take a flash light & check for ice in the back vent underneath the very bottom shelf in the freezer. If you see ice in there, completely defrost until the ice is gone & the plastic drip hole is unobstructed. The leak on mine was happening because that hole had frozen over & caused excess water to flow into the bottom of the freezer & out the bottom of the door instead of through that hole.
Apr 20, 2010 | Admiral 26 cu. ft. Side-By-Side...
Puddle of water in front of the refrigerator--
Ur colling unit is etheir broken or not at the right setting
Nov 19, 2009 | Samsung RS2556 Side by Side Refrigerator
Water and ice in bottom of freezer, occasional water on floor
I believe your defrost condensate pan below the evaporator is blocked with ice and now when defrost happens the water pours over the tray and to the bottom of the freezer. You will need to defrost the ice in the collector tray and the pour a solution of hot water and clorox to make sure the water ends up in the condensate pan below your refrigerator. So unplug the refrigerator remove the panel and let me know what you find. I have some more solutions depending on what you see is happening. Thanks, Sea Breeze
Jul 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water in bottom of refrigerator coming from freezer (not really sure of the exact model as I'm not home to double check).
If water appears on the floor in front of the refrigerator once or twice a day, it could be due to a clog in the defrost drain tube. The usual evidence of a clogged drain in a side-by-side refrigerator is ice under the bottom basket in the freezer compartment, in addition to a puddle of water on the floor. Try watching the YouTube videos like this one:
https://www.youtube.com/watch?v=H_DKNtgd5vI
Apr 01, 2017 | Roper RT18VKXKQ / RT18VKXKZ Top Freezer...
Water in bottom
do you have the drip pan in place underneath? If yes, does it have a crack in it?
The sudden puddle could be caused each defrost cycle.
Jul 08, 2008 | Sub-Zero 690 Side by Side Refrigerator
Frigidaire FRT21G3CW Top Freezer Refrigerator Logo
156 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
