Question about Hoover Ultra U6430-900 WindTunnel Bagged Upright Vacuum
I need to know how to change the belts on this vacuum
I bought this vacuum used and do like how well it works. Unfortunately the thick belt has broken and I do not have an owner's manual so I don not know how to replace the belts.
5 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: Windtunnel Light Vacuum Belt
Take off the bottom plate, you will see the brush roll and old belt, If you can reach the motor shaft, then put the belt over it and then over the brush rol and stretch to fit back in the slots fot it. If you don't see the motor shaft, then you have to remove the top cover to get to it.
Posted on Mar 04, 2008
reddevil6
  • 1673 Answers
SOURCE: Replace the belt
Take off the bottom plate, put the new belt on the motor shaft first, then stretch it to go over the pulley, it is hard, but it will stretch to go over it.
Posted on Mar 29, 2008
  • 4 Answers
SOURCE: Belt replacement
No belt- it is motor driven. what happens to these if the rollers get stuck(by- say, a Lego® or something)  is the roller itself has an insert which will break, requiring roller replacement.
simple fix, but costs a little more than a belt. remove two screws holding the roller cover, accessible by flipping the vac over. then figure out which roller is broken, and remove the 2 outer screws on that side. pull the outer bearing cup assembly straight out to remove the rollers.
I have found the rollers as cheap as $3.50 ea/ for generic replacements. Also I reckon any Vac shop would have them on hand.
Posted on Apr 28, 2009
  • 294 Answers
SOURCE: Belt for Hoover Powermax S3606 Canister Vacuum is Broken
Your belt number will be listed on the data label with the model number. Check your local Hoover / Dirt devil dealer for the part.
Posted on Apr 21, 2010
How do u repair a broken rubber belt that helps spin the brush?
Hi, it's Cindy from Crucial Vacuum.
Unfortunately there is no way to fix a broken belt. The only way to repair the vacuum is to purchase a new belt.
You can purchase your replacement belts direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com viewers, use code: FIXYA10
http://www.crucialvacuum.com/hoover-elite-rewind-belt.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Cindy Yuk
Crucial Vacuum Customer Care
Apr 27, 2014 | Hoover U5507900 Elite Rewind Bagless...
The brush wheel will not go around?
make sure the carpet/floor selector switch is in the carpet position. if that is good then you probably have a broken belt. Unfortunately a complete clutch assembly will have to be installed. Just the belts cannot be changed
Apr 08, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
I have a dyson - bought it 3 yrs. ago and the roller brush stoped working - doesnt pick up anything. Can you help? The brush doesn't roll or spin. Where can we take it to be fixed and is it under warrenty?...
Don't worry it's probably just that the belt has broken or stretched. Your actually supposed to change them yearly. So if its been three years thats probably the case. Here is a link to the belt you need and a manual with instrutions:
Dyson DC07 Belt and Manual
Nov 28, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
The brush is not working anymore
Your drive belt is probably broken. They usually need to be changed every 6 to 12 months. If you haven't replaced the belt recently I would try that. You can get the belts you need through this link and also view the manual which has step by step instructions on how to change the belt. hope this helps!
http://www.vacbelts.com/bissell-lift-off-revolution-pet-vacuum-belt-.htm
Oct 25, 2009 | Bissell LiftOff Revolution Pet Vac 37602...
No water on carpet but apolstry cleaner will spray
Buy a cow... Literally. I did and it worked right when i bought it. My cow's name is Susie.
Jul 11, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Changing belt
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=700198
Generic problem for all Vacuums
Changing belt
Posted by Tribbles007 on Jun 23, 2008
Changing belt
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Normally there are 2 to 4 screws or clips, levers on the bottom of the vacuum, and then you can remove the bottom plate or top cover and then you can get @ the belt to change it. Unfortunately, I do not know the brand name and model& serial 3 in order to tell you the exact method for the belt change. You can check with your local vacuum cleaner dealer in your area or contact the vacuum factory tech support line. Such as: Example….
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Vacuums
I need to replace the belt on the power nozzle of my Hoover Dimension 1000 Model S3491. Unfortunately, I have no written instructions on how to do so. I purchased the vacuum cleaner in the mid-80s. Are the...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=566792
posted by Deb in Iowa on May 03, 2008
I need to replace the belt on the power nozzle of my Hoover Dimension 1000 Model S3491. Unfortunately, I have no written instructions on how to do so. I purchased the vacuum cleaner in the mid-80s. Are the instructions still available? Thanks in advance.
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I believe so, but you would have to contact the Hoover Factory and they would have to send out either the owner’s manual or a copy of the owner’s manual from the fische. I remember this vacuum cleaner well. In order to change the belt you need to remove the 4 screws in the bottom of the power nozzle and then the top cover will lift off from the back to the front and then you can get in to change the belt. Always use the Factory Genuine belts instead of the replacement belts, they last longer and the average belt change for a flat belt is every 4 to 6 months as a rule for the best cleaning. In order to change the belt, lift up the pulley side of the brushroll and slide off the old belt and then slide on the new belt and re-install the brushroll, then use a belt puller or screwdriver with a hook on the end and to pull or stretch the belt onto the motor pulley, once you have it on the vacuum track the belt in a straight line and then reinstall the top cover and screws in reverse. If you have questions please feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Go Ahead. Use Us.
May 03, 2008 | Vacuums
I bought a Hoover Wind Tunnel in January 2008. At first it worked great though very noisy. Now it will not pick up small fuzz on medium shag carpeting. I have checked the bag, the filter, the belt, and...
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=563001
posted by smithcarolj1 on May 01, 2008
I bought a Hoover Wind Tunnel in January 2008. At first it worked great though very noisy. Now it will not pick up small fuzz on medium shag carpeting. I have checked the bag, the filter, the belt, and obstructions and there are none. Plus the noise level has increased. What is wrong?
I am very dissatisfied.
Sorry you are having a problem, using the Hoover Windtunnel is a very good vacuum. Reading youre description, the belt is one of the main reasons you are not picking up the small fuzz on a medium shag carpeting. The belt change on the average , if you have one or 2 belts should be changed every 4 to 6 months as a rule, and the brushes need to be in good shape as well, if those two are working well you may have a bad seal on the motor or a broken fan blade(s) and that would decrease suction and you would need to replace the fan. Also check the gaskets if they are broken or damaged or pinched and letting air through the suction will leak out. These are some of the items to check for, so feel free to contact your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Thanks, Don The Vac Man
Go Ahead. Use Us.
May 01, 2008 | Vacuums
My power brushes on my bissel carpet cleaner stopped working. They do not rotate. This is the 2nd power cleaner I have bought and it has the same problem as the first one. What is the problem with the...
Brush belt is very weak.
Brush Belt broken or disconnected. Very weak belt. Colossal engineering mistake by Bissell. Belt itself and its components are under way to much stress for the size they developed to perform their task. For Quality Control to let such an obvious blunder pass can only mean that it was intentional for reasons, Im sure, beneficial to Bissell and costly for the consumer. No telling how many people buy another entire machine when this rubberband of a belt breaks like it was intended. Bissell is not a consideration of myself or anyone I can enlighten.
Apr 18, 2008 | Bissell 8910 ProHeat Clear View Upright...
Hoover Ultra U6430-900 WindTunnel Bagged Upright Vacuum Logo
107 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
