Question about Samsung HLP5085W 50" Rear Projection HDTV-Ready Television
Samsung HLP5085W DLP - lamp replaced about 7 months ago. I powered up TV and got strange colors with flickering picture. Turned unit off and triangle symbol appears with lamp showing - needs replacement. Could it be a ballast problem? When I power up now the TV just scrolls the blue circle like it is starting up over and over again for many times, then shuts down and triangle appears again. I don't want to buy another lamp and it be a different problem. Lamp is a Phillips and worked fine until today.
  • 10,594 Answers
Strange colors and flickering picture symptom shows problem with color wheel and/or dmd board.
Lamp is only light source in dlp tv and it has nothing with colors or picture flicker.
TV goes to protection mode because of some internal problem as mentioned above.
If you wish to repair tv by yourself then you should have service manual copy in hand and that can be downloaded from HERE for small fee.
Hope these info will help you.
Thanks.
Posted on Jul 04, 2010
  • fschimpf Jul 04, 2010
    Tried to power up this am. TV drones, like a deep hum seems to be cycling and it has an intermittent drone sound, then triangle and light bulb icon appear. Could the color wheel be locked up and that is the sound I hear, power trying to spin it against resistance. It definitely sounds like heavy resistance. I didn't want to tear into it yet, and the TV is in a recess, so getting it out is a 2 man job. Is there something I can see on inspection, color wheel free wheeling? or anything that would point to a specific problem area.
    Thanks
  • Shahid Electronics
    Shahid Electronics Jul 04, 2010
    Color wheel is located in light engine and tv will take apart in details, need to take out light engine out from tv cabinet then removal of lamp housing because color wheel is located next to lamp housing.
    TV showed signs before going to stop working are color wheel that stop spinning for some reason that could be it got jammed or broken etc.
Display problem with my Samsung HLP5085W DLP TV
What you are describing sounds like a tuner issue. Samsung had a run of bad tuners, and was recalled. If your watching a chennel and the image tears, this is the sign of the bad tuner. It is possible that the wobulation circuit is unstable. First units we bothered by subwoofers thumping the TV. Not much help other than that, good luck
Jul 07, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung DLP TV has lot picture. Makes a Humming sound
That sounds most like the color wheel,
to change that you need to have some skill in electronics, I would recommend to take it to a shop
Apr 25, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLP Flickering
If you're certain the lamp is good, it's probably the ballast. The ballast has enough juice to power the lamp, but it's unable to maintain a steady consistent level of power, hence the lamp flickering. Changing the lamp may temporarily resolve it because a new lamp is more easily maintained than an older one, but if the ballast is failing, the problem will recur and probably shorten the life of the lamp. The ballasts cost around $70-80. Replacing it can be done by the electronically adept end user, or you may need a service tech. The problem with a service tech is that some may not acknowledge that the problem is the ballast especially if the intermittent flicker is not happening while he/she is examining it.
Apr 04, 2008 | Televison & Video
Samsung HLM507 FLICKERING PROBLEM
how extended is that warranty, and what does it cover? Sounds to me like a classic video controller board about to fail.
Mar 24, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung HLS4266W 43" dlp
Power issues (Tv not turning on) were typically due to faulty ballast. While the TV reports a bad lamp it is the ballast itself causing the issue. Samsung is well aware and will replace both the ballast and the lamp (since the lamp can be prematurely aged but the bad ballast). After replacment most people stop having issues.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung hln567w dlp tv
after 3 years it is a good chance that the lamp is going,,however if it plays its melody when it turns off there is a possibility thateither the lamp door switch or the thermostat are failinf
Nov 28, 2007 | Samsung DLP HL-P5663W 56" TV
No picture whirring noise shuts off and on
DLP(digital light processor) does not have a color wheel
Oct 05, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung HLP5085W 50" Rear Projection HDTV-Ready Television Logo
599 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
