Question about Roland Juno-D
My Roland Juno d has contact issues. I need to have the contacts cleaned once a year because I keep losing sound on some keys and some sound too softly. I am tired of shelling out $135 every year for a cleaning. art
Answer:
Before i give you the right solution, i have to say that i have posted the answer to FIX the problem of all of the contact problems, people writing in how many of their keys are not working. And the post that they are showing is one that says to clean the contacts. That will not work.
Ok,
the answer.....
You can purchase a kit called Rubber contact kit here: http://www.mcmelectronics.com/product/20-3890&cid=prodCrossSell
or
Key contact Kit:
http://www.oaktreeent.com/Roland_Keyboard_Parts_Units.htm
These kit are made to re-coat the contacts on the keys. It will bring your board back to brand new condition and last as long if not longer than the original coating.
Also can be used for any rubber contacts like remotes or game controllers. etc.
This will work and i did mine after numerous times of taking the keys off and cleaning them.
I hope this gets out to all of you that are having the same problem.
Good luck
Posted on Jan 08, 2011
Roland juno d not work
Check the power adapter at the coaxial plug end that plugs into keyboard- is there power there? If so, is the socket on the keyboard loose at all? If so- the socket may be broken, If there is no power there, you either need a new power supply or you need to open it up to see if it is just the fues in that supply that failed.
If the plug inserts snugly as it did when new and it dopes not power up, the issue may be the power switch on the back- it may have dirty or corroded contacts- cycling the switch on and off several times rapidly should clean it.
If it still does not power up, there should be a fuse internal to the keyboard that would require you open it up to check it. If it is not under warranty, this is not an issue- if it is under warranty, it is something that should be checked in the shop.
Apr 06, 2012 | Roland Juno-D
Where can i get a screen replacment for the juno g ? and how much is it?
You will have to go to Roland parts to get the item and the price will vary depending on your location. The display is going to be expensive... Here is a site...
http://www.instrumentalparts.com/rojuglcdscju.html
$205 it looks like... I would contact Roland directly first. Use google to find their contact info.
Apr 11, 2011 | Roland JUNO-Gi 61-Key Mobile Synthesizer...
After several months of being stored i used my roland juno D to find that some of the keys didnt work. I cleaned the rubber contacts etc but they still dont work? and the ones that do are uneven volumes...
Did you clean these contacts with ONLY isoprophyl 99% alcohol and Qtips? If you used another product you may have spoiled the contacts. Also did you clean the circuit board where they contact with the same product?
If you used another cleaner, best to redo your work... quickly... Contact cleaners such as Deoxit and Blue shower destroy this type contact.
Mar 14, 2011 | Roland Juno-D
SOME OF THE KEYS ARE NOT GIVING ME SOUND
The key contacts have become contaminated. Disaasemble and find the contacts under silicone rubber domes. They are typically black conductive rubber pills, two per key. Clean them and the circuit traces they press against under them with ONLY 99% isoprophyl alcohol and Q Tips GENTLY. Then reassemble and test operation.
Feb 11, 2011 | Roland Juno-D
Some keys on my roland juno d wont sound. How do i fix this problem? Please help.
The key contacts need to be cleaned. They are usually conductive rubber pills in silicone domes that get pressed onto circuitboard traces by the keys. Disassemble to get at the contacts. clean ONLY with 99% isoprophyl alocohol and Q tips. Clean both the pills AND the circuit traces they contact.
Be very careful of cables when opening the unit. Document where all the screws go and their length and threads.
Nov 13, 2010 | Roland Juno-D
Some keys do not play and it is a relatively new keyboard with little play. I was going to take it apart myself but I need help with that. thanks
I would recommend taking it in to be repaired. If they service Roland products they will have access to any parts it needs. It sounds like the key contacts are damaged or dirty. In either case it is not easy to disassemble the Juno because of the internal wiring. It needs to be reassembled perfectly for it to work properly and it is easy to damage something during disassembly. Hope this helps.
Oct 23, 2010 | Roland Juno-D
I wish to know how to open a Roland JUNO-D synth to access the little rubber strips with the key contacts; I have the typical key-not-sounding problem.
Usually there are a number of screws from the bottom to remove. SOmetimes they hide some under a label or rubber feet. The top should remove and pone must be careful of the cables from teh top to the base of the unit.
Keep track of where screws go as often they have different length and using the wrong length when re-assmbling caan cause trouble.
Aug 07, 2010 | Roland JUNO-D Synthesizer
No sound when hitting some keys
Your key contacts are dirty. Disassemble and clean both the circuit traces and the conductive rubber pills with ONLY 99% isoprophyl alcohol and QTips.
The contaacts are in pais which allows for measuring key velocity. When contacts are dirty, this affects the loudness.
Jun 03, 2010 | Roland Juno-D
Roland juno-d, keys are either too loud or too
Normally you have to clean the conductive rubber "pills" AND the circuit board traces they get pressed down on.
USE ONLY 99% isoprophyl alcohol on Q-Tips to do the cleaning and be gentle.
Use of other product like deoxit and other contact cleaners will wreck the contact material.
Jan 11, 2010 | Roland Juno-D
Roland Juno D Keyboard Keys not sounding
The problem of the Juno-D is de rubber strips inside under the keysthere are 5 strips, you have to clean this rubber strips with alcohol and clean the board too, this will resolve your problem if you leave the Juno-D without playing for a long period you will get the same problem again. this is a very poor keyboard it,s a pitty that Roland Make so poor keyboard!!!!
Dec 16, 2008 | Music
Roland Juno-D Logo
419 people viewed this question
Top Roland Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Roland Music Expert? Answer questions, earn points and help others
