Wireless fails to operate sometimes on Amilo Pi1505 laptop. Have tried switching wireless on and off without success. After a couple of days it will suddenly start operating again without imput from me.
  • davidpfenner Apr 17, 2008
    I have a wireless router with Netgear mains circuit booster. This appears to all be working ok as we have another laptop used in the house and this is picking up a connection ok.
    I believe it is an intermittent fault on my machine but have yet to establish what causes the wireless part of the laptop to work sometimes and not others.
    Sometimes it just fails to turn on when I switch on an then will then be ok when I use the machine later. I have also had the wireless signal cease while I am using the machine.
    Currently I am having to connect the ethernet cable to get on line.
    Hope that helps and thanks for your assistance.
    Dave Fenner
  • Chris  Morse
    Chris Morse May 11, 2010
    Where is the wireless internet coming from? Do you have a wireless router?
  • 67 Answers
It may be a compatibility issue betwen the mobile device and the router. Find the router model/name as well as the mobile card or built in mobile device manufacturer/model name so that I may research this further. Some settings in My Network Places will allow you to change how your mobile device will act. For example, you can change the settings so that it ONLY looks for the specific network in your home, rathe than searching for the strongest signal which may cause you to lose connection while it looks around. Another factor to consider is location location location. Where is your router in relation to the laptop at the times that you are losing signal? Consider how many walls it has to go through, or floors if its upstairs and you are downstairs.. Try changing some of those settings and find out those model names, then get back to me to let me know how things go and we will go from there. Good Luck!
Posted on Apr 17, 2008
Amilo pi1505 will only read sd card not sdhc
Correct. The PI1505 will work with SD cards but not with SDHC cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in devices not designed for them. You can get a SDHC-compatible card reader which plugs into the USB port.
Dec 31, 2012 | Dell Inspiron E1505 Notebook
I have got a problem,when i wanna run the wireless on laptop,it doesnt allow me to connect,it keeps saying "turn on your wireless compability" and it says that you can do this by switching on a...
Here the list of FUJTISU SIEMENS-AMILO models and where the wireless switch is located. Hope this will helps. Check what family your laptop belongs to then turn on the wireless swith using the list below:
Fujitsu Siemens Amilo A Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo D Series ---- Button above the keyboard on top right
Fujitsu Siemens Amilo K Series ---- Not Wireless
Fujitsu Siemens Amilo L/EL Series ---- Fn / F1 to turn on/off
Fujitsu Siemens Amilo La Series ---- Fn / F2 to turn on / off
Fujitsu Siemens Amilo Li Series ---- Easy launch button (one of 3) on top of keyboard
Thanks for using Fixya.
Jan 27, 2011 | Computers & Internet
I got Fujitsu Siemens AMILO pro V1000 laptop , the problem is there is wireless device inside the laptop but i can't see it in my computer .....> hard drive ...> device manager .... > network...
A wireless hard drive? Wouha, you're lucky...
1. It's possible that the wireless adapter is disabled in the bios -> enable it.
2. Maybe it's only disabled in the device manager -> enable it.
3. It can be that the drivers for the adapter aren't installed -> install them.
Hope helps.
May 30, 2017 | Fujitsu Siemens AMILO Pro V1000 Notebook
My wireless wont turn on Amilo Li 2727
my laptop amilo li 2727 wireless wont turn on
Oct 29, 2009 | Fujitsu Siemens AMILO Xi 1546 Notebook
Wireless connection
You did not state which laptop model you have. Here is a list of the most common key strokes or switches:
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 13, 2009 | Fujitsu AMILO PC Laptops
Hardware switch on a amilo fujitsu laptop
On some of the Amilo Models, the Wi-Fi button is actually a key combination on the keyboard. Have a look for a key with the wireless symbol on it - looks a bit like an antenna, and hold Fn while you press that key. Your Wireless should come back on.
Fujitsu's can be odd, cause the hardware button (mentioned above) doesn't actually disable the driver in Windows, just turns it off so no connections appear.
Mar 05, 2009 | Computers & Internet
Wireless drivers??
download Ralink Wireless adapter and install it...check it out
Sep 26, 2008 | Fujitsu Siemens AMILO Pro V2010 Notebook
Built in wireless lan........
Operating System? Sometimes with XP, you have to disable the Zero Wireless Configuration Utility when using a proprietary on-board utility. This is done in the services.msc panel.
Start > Run > services.msc (ok)
Dec 03, 2007 | Computers & Internet
Fujitsu Siemens - Easy Launch Keys - Wireless
go to network connections, right click on your wireless adapter and click enable or connect. Or go to my computer>right click>properties>device manager> hardware tab, look in list for wireless adapter, right click and select enable.
Oct 01, 2007 | Fujitsu Siemens AMILO Pro V2000 Notebook
Computers & Internet Logo
95 people viewed this question
David Payne
David Payne
