Question about JVC SP-PW100 Subwoofer
Can a JVC Sp PWC5 Subwoofer work on a 8 ohm Sony receiver and if so, how do i hook it up
furion187
  • 54 Answers
SOURCE: 4 ohm and 8 ohm speakers
You can plug in higher ohm speakers , the higher the ohm the higher the resistance is, it is a danger when you plug lower ohm speakers into a higer ohm Amp , at a high volume that will cause them to blow , the center speaker would be fine to use a higer ohm speaker , your best choice is to buy a Active Subwoofer, which means the sub has it's own power supply , and u can blast the thing as much as u like , thn u can turn the bass down on all the other speaker's so u can play it louder , and have the sub turned up has high as u like , this is the best way to get great sound with high volume , buy a Active sub woofer , any active subwoofer is ok , a active sub woofer has its own volume and inputs on the speaker ,
Posted on Dec 09, 2007
SOURCE: Lost instructions
The 'Subwoofer' output on your receiver is used to connect to a powered subwoofer with a built in amplifier. Your KLH speakers use what is called a 'passive' subwoofer, it gets its power from the receiver and then passes the higher frequencies to the left and right front speakers after taking out the low frequencies for the subwoofer. A speaker system with a passive subwoofer is good for casual listening, but a powered subwoofer is required for really hearing low frequencies and rumble in movies. The KLH speakers you have were highly rated in their time for their price. The four satellite speakers and center channel speaker have very good sound compared to the little 'midget' surround sound speakers most people buy today.
Here's how you hook them up:
- The left and right front channels from your receiver terminals should go to the terminals on the subwoofer marked 'From Amplifier'
- Your left and right front speakers are then connected to the subwoofer terminals marked 'To Speakers', they do not connect directly to your receiver.
- Your center speaker is connected to your receiver terminals marked 'Center'
- Your rear speakers are connected to your receiver terminals marked 'Surround'
That should get you up and running. If the bass isn't good enough with the passive subwoofer, you can get a decent powered subwoofer like the Velodyne VX-10 for about $150 and 'kick it up a notch'. Good luck and enjoy....
Posted on Jan 09, 2008
  • 16 Answers
SOURCE: JVC Subwoofer problem.
You may have a break in the wire. You can find out by slowing moving your fingers down the wire until you notice sound coming from the subwoofer. You can fix it yourself by cutting about an inch away from the break both ways. Then cuttings some of the wire off, so the copperwire is exposed. then wrap the two copperwire ends together and seal it with elections tape. or Try replacing the 60 watt subwoofer wire.
Posted on Apr 16, 2008
  • 11 Answers
SOURCE: model.no sp-pwc5 the power wont come on at all how
sounds like the power supply you will need to change it or have it changed
Posted on Mar 19, 2010
mlapres
  • 757 Answers
SOURCE: i have a jvc sp-pw50 Subwoofer and i want to know if you can buy an adapter for the input so i can hook it up to my kenwood amp? my amp does have a regular audio jack
That would require you to disassemble the subwoofer cabinet and disconnect the the supplied amplifier.
Connecting this unit to a different amplifier would provide no benefit to you unless the on-board amplifier became damaged.
Posted on Dec 23, 2011
I recently got this jvc model number SP-PWC5, system number TH-C5, unfortunately I bought it from Craigslist and it did not come with the cables. I am wondering if a normal s-video cable will work?
Here is a link to the JVC support site where you can download a manual in PDF format to show you how to hook up you system.
resources.jvc.com/Resources/00/00/93/GVT0150-001D.pdf
Jul 23, 2015 | JVC Audio Players & Recorders
Whats a control jack on a sony SS-WG450 plug into if i'm hooking it to a JVC reciever?
That subwoofer is included in the MHC-GX450 system. I have the amp/CD/radio unit. but not the subwoofer. The control cable connects the LED on the Sub to the main unit. When the main unit detects this connection to the LED it switches on its internal subwoofer amp to drive the subwoofer.
Does the JVC receiver use a "control" circuit through its external subwoofer unit to signal that it is connected to the subwoofer? If not, you do not need to use the control jack on the
SS-WG450 to connect to the JVC receiver. Connecting the Sony subwoofer to a subwoofer output on the JVC unit may be enough. Do check the impedance required by your JVC receiver. Sony lists the SS-WG450 as having a Nominal impedance of 6 Ohms. Is this high enough for the JVC unit?
Feb 03, 2012 | Sony MHC-GX450 CD Shelf System
I have a jvc sp-pw50 Subwoofer and i want to know if you can buy an adapter for the input so i can hook it up to my kenwood amp? my amp does have a regular audio jack
Nov 16, 2011 | JVC SP-PW100 Subwoofer
I have a JVC Receiver that I'm trying to hook a
"[A] set of Sony Speakers" is meaningless. What model(s)? If they're part of an all-in-one system they may not be suitable for the JVC.
Manuals exist for everything. Read them.
http://www.retrevo.com/support/JVC-RX-5052S-Receivers-manual/id/315ci175/t/2/
This receiver is designed for standard commonly available 8-ohm (nominal) speakers that connect with common stripped end lamp cord or speaker wire.
Sep 03, 2011 | JVC Audio/video Receiver Rx-5052s -...
Ok i just got the sub from a sony sswg450 i want to know is there some way to hook it up to my Pioneer home Receiver
Did you get a manual with it? According to the Sony site this speaker originates in Sony MHC-GX450.
"This product bundle includes the following models:
HCD-GX450 - STEREO MINI SYSTEM
RM-SC3 - REMOTE CONTROL for Shelf Mini Systems
SSRG444 - FRONT SPEAKER FOR MHCGX450
SS-WG450 - SUBWOOFER FOR MHCGX450"
Find the manual here and learn a bit about your seprated sub...
http://esupport.sony.com/US/perl/model-documents.pl?mdl=MHCGX450
See page 7.
As can be seen, the subwoofer has two connections to the mothership, very unlike the standard speaker level (+/-) speaker wire or RCA-Line-Level subwoofer out that 'normal passive or active subwoofers use, respectively.
Not knowing which of those your unspecified Pioneer receiver supports, it is impossible to say. Does your Pioneer have that control jack?
Mini-systems are generally not designed to be pieced out and used with grown-up gear. The absence of standardized connections is the clue.
Apr 17, 2011 | Sony MHC-GX450 CD Shelf System
Model.no sp-pwc5 the power wont come on at all how cam I fix it
Mar 18, 2010 | JVC SP-PW100 Subwoofer
We have a jvc home theater surround sound system and the subwoofer just stopped working. the model number for the sub is sp-pwc30 and we want to just replace the subwoofer any ideas how to get one?
Depending of the type of Subwoofer that required your system.
A) Amplified Subwoofer. (With 110volts A.C. cord attached to the sub)
The subwoofer electronics circuit needs repair or change.
You will find a compatible subwoofer for this type of subwoofer in audio appliance stores.
B)Not amplified Subwoofer (No 110volts A.C. cord attached to the sub)
Bring your sound system to a technician to have the soldering remaked to the devices bolted on the main heatsink.
And have the Subwoofer checked too.
This type of subwoofer can mostly be buy in kit with the satellites speakers.
And need to match thee impedance of the output of your system.
Search for ( 4 ohm or 6 ohm 8 ohm ) near the Sub outlet behind your system.
Spider Guy
Mar 15, 2010 | Audio Players & Recorders
Where can i find an sp-pwc5 cable? cant really find it on the internet
Hey bro, if your looking for the "system cord" that says on the back of the unit TO: SP-PWC5. Look no further your part number is 6200044901 just type this into google or hand it over to you local electronics stores and they might be ablet order it for you! God Bless!!
Mar 07, 2010 | JVC TH-C5 System
How to add a subwoofer?
Car systems and home systems are different in the fact that the car system expects to receive 12 volts DC for power, and they are usually 8 ohm speakers. I would not recommend doing this unless you are in the mood for some serious config. Power converter from 110 AC-12v DC and big enough to handle the amperage. If it's not powered, then your going to be running a 4 ohm speaker on an 8 ohm amp output. Again, not recommended.
Oct 25, 2009 | JVC RX-717V
JVC SP-PW100 Subwoofer Logo
303 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
