Question about Cretors Goldrush Popcorn Maker
One of the doors cracked and I need A replacement
  • 1,557 Answers
As parts for these machines are very hard to find i would consult a glass repairer they should be able to replecate the door for a lot less $$
Posted on Jul 04, 2010
How can i replace the front door panel that has cracked at handle . it is whirlpool microwave over range
The parts are available from appliance parts houses. They do sell to the general public. I did one a few months ago. I think the outside door was around $30. It is not a difficult job. Just know that you have to take the entire door apart to do the job. 20-30 minutes.
Dec 10, 2014 | Whirlpool Microwave Ovens
Miele G2020 Advanta Dishwasher Leak Help
follow this steps and fix it. God bless you
Water Inlet Valve
If the dishwasher is leaking water the water inlet valve might be defective. If the water inlet valve sticks open, it will allow water to fill the dishwasher continuously. Some customers report that they see clean water filling the bottom of the dishwasher after it's been sitting all night or for a couple of days. If this happens, turn off the water that is supplying the dishwasher. This is normally a valve under the kitchen sink. Then, replace the water inlet valve, it cannot be repaired. The water valve needs at least 20 lbs pressure to shut off properly. If your water pressure is to low replacing the valve may not solve the problem.
Center Wash Arm Assembly
If the dishwasher is leaking water, the center wash arm assembly might be cracked or split. This can allow a jet of water to spray toward the door seal, causing a leak. If a crack or split in the center wash arm assembly is found, replace it. There isn't any glue that will hold the part together inside the dishwasher.
Lower Wash Arm Assembly
If the dishwasher is leaking water the lower wash arm assembly might be defective. If the lower wash arm has a crack or split on the end, it can force water to spray directly toward the lower part of the dishwasher door. Then, the water can be forced under the door and onto the floor. Check the lower wash arm for any cracks or splits and replace it if necessary. Also make sure the screws are tight in the wash arm support. If the screws are loose, water can spray out the side of the pump and cause a leak.
Upper Wash Arm Assembly
If the upper wash arm assembly is broken or cracked it can cause water to spray very forcefully toward the seams of the door, causing a leak.
Door Seal
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a dollar bill and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced.
Dishwasher Door Gasket
Jun 14, 2013 | Miele Dishwashers
Neff H7871 oven door does not stay closed. Catches do not appear to be working
The door latch is either cracked or broken.The door when gets closed the door latches clicks.But if the door latch is loose or cracked it will not click and door will not close.The door needs to be disassembled and the door latch has to be replaced, if the latch is cracked.Also to check the latch from inside the door needs to be removed.-------- This will help.thanks.Helpmech.
Jun 29, 2011 | Neff Microwave Ovens
Whirlpool gh7145xfq1 door cracked, how do I replace just the door?
You only need to replace the part that is cracked. I'm guessing that what is broken is the glass.Hope this helped.There are many parts to an oven door.You only replace the parts that are broken.
May 02, 2011 | Kitchen Ranges
Slight crack in oven door just below the handle. Should door be replaced?
It may be that the handle is getting loose, and cracked the outer door panel.
If so, the outer door panel and handle would need to be replaced.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
You can find handy exploded views and order parts by model number here.
Oct 07, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Drivers door can only open from out side
sounds like inner door handle cable or clip has broke or came loose
Aug 06, 2009 | 2001 Hyundai Elantra
FRONT GLASS DOOR HAS CRACKS
Sounds to me like the door needs to be replaced.
Jul 29, 2009 | Frigidaire FMV156DC Microwave Oven
Front Plastic door is cracked and needs replacement.
Do not use a microwave with a cracked door as it could be emitting dangerous microwaves.
Sadly the cost of replacing the door would be more that the cost of a new microwave. Look for a good sale and treat yourself.
Jun 11, 2009 | Microwave Ovens
My maytag side by side model #RSW22EODAM refrigerator door has a
If all you need are shims, use washers (either plastic or metal) with an interior hole large enough to go over hinge pin to raise door. However, in reading your complaint, I feel as though shims (or washers) may not solve your problem. You may have an issue with the door seal and or door liner. Sometimes a new seal will correct the problem but check for any cracks in the door liner. If cracks are evident, you will need to replace both. Putting a door seal on a cracked liner will NOT help. If you need to replace both, it can get a little costly. Good luck.
Dec 06, 2008 | Refrigerators
Cretors Goldrush Popcorn Maker Logo
101 people viewed this question
Top Cretors Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Cretors Kitchen Appliances - Other Expert? Answer questions, earn points and help others
